Console.print("test") not working
I have an Arduino Yun. I can run the http client example
and I change all the Serial to Console and remove the Serial.flush(); completely. It works as it is supposed to work. So I assume my setup is basically correct.
Now I tried this
#include <Bridge.h>
  Bridge.begin();
Console.begin();
Console.print("test");
I guess it is as simple as it gets, nothing is printed. Simple question: Why?
Thanks!
Hello and welcome,
Maybe this will help? http://arduino.cc/en/Guide/ArduinoYun#toc17
yes that helps. When I ssh to the Yun and then telnet to the console I see the output. So if there is no trick I assume the IDE (1.6.1) has a bug that it cannot get the console output in some cases.
Any comments on that?
