const int a=a;
The following compiles without a comment in Arduino 1.6.7:
const int a = a;
void setup () {}
void loop () {}
The following also compiles, so I don’t think it is simply an optimizer issue:
const int ledPin = ledPin;
 pinMode (ledPin, OUTPUT);
void loop() { }
This does not compile:
void loop() { }
avr-gcc -Wall -Wextra -Os -Wl,–gc-sections -mmcu=atmega328p -o […]
The variable a has an apparent resulting value of 0. Is this a known behavior of C++ or is it a bug?
  • Bruce
Moderator edit:
</mark> <mark>[code]</mark> <mark>
</mark> <mark>[/code]</mark> <mark>
tags added.
bdhubbard: This does not compile:
You forgot "static"...
  static const int ledPin = ledPin;
Without the "static" ledPin is a pointless thing. Neither a constant nor a variable. With or without the "self initializer".
bdhubbard: The variable a has an apparent resulting value of 0. Is this a known behavior of C++ or is it a bug?
Same with Visual Studio 2008 so I'm going with "known behaviour".
