i've been trying to figure out what's wrong with it and I can't wrap my head around there, any guidance would be much appreciated! I'm pretty much a noob when it comes to coding. i tried to do an ultrasound sensor that changes the led rgb light once you get close, Here's the code.
//comments in Spanish
const int EchoPin = 5;
const int TriggerPin = 6;
const int dist[] = {100, 200, 300};
const String colors[] = {"blau", "vermell", "verd"};
const int delay = 3000;
int PIN=6; //Pin donde está conectada la tira de leds
int NUMPIXELS=30; //Número de leds conectados
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
pinMode(TriggerPin, OUTPUT);
pinMode(EchoPin, INPUT);
int cm = ping(TriggerPin, EchoPin);
Serial.print("Distancia: ");
Serial.println(cm);
startSequence (cm)
int ping(int TriggerPin, int EchoPin) {
long duration, distanceCm;
sendPing
duration = pulseIn(EchoPin, HIGH); //medir temps ms
distanceCm = duration * 10 / (292 * 2); //calcular a cm
return distanceCm;
void sendPing () {
digitalWrite(TriggerPin, LOW); //generar puls
delayMicroseconds(4);
digitalWrite(TriggerPin, HIGH); //Trigger
delayMicroseconds(10);
void startSequence (int cm) {
String color;
Switch (cm) {
case dist [0]:
color = colors [0];
case dist [1]:
color = colors [1];
case dist [2]:
color = colors [2];
switchOnLights (color);
void switchOnLights (String color) {
// encendre leds (buscar llibreria - demanar joan)
delay (delay)
// apagar leds
pixels.begin(); // Inicialización
pixels.show(); // Inicialitza tots els pixels apagats
pixels.setPixelColor(0,0,0,255);
pixels.show();
delay (1000);
pixels.setPixelColor(0,0,0,0);
pixels.show();
pixels.setPixelColor(1,0,0,255);
pixels.show();
delay (1000);
pixels.setPixelColor(1,0,0,0);
pixels.show();
pixels.setPixelColor(2,0,0,255);
pixels.show();
delay (1000);
pixels.setPixelColor(2,0,0,0);
pixels.show();
