Hi all.
If i wanted to dim a lets say 10w led 10-12v forward voltage and 1a.
If i where to use a basic/cheap constant current like
Could i use a TIP120/TIP122 to dim with an arduino ?
Any help tips advise would be great?
Hi all.
Can you use PWM to control a power (logic level) MOSFET
For the LM2596-based driver, I don't know if a transistor would work with that to make a dimmable driver.
For the MR16-shaped driver, that is based on the PT4115 chip and is dimmable if you just tap into the right pin on the driver. See DX New Forum – Discuss Cheap Electronics and Find Smart Tech Here. Note that his experience with being unable to dim it below ~20% is normal for the PT4115.
