Constant current load design
0
I'm currently a rising junior in EE and am honestly completely lost... I've been tasked with designing a constant current load circuit to discharge parts of the battery pack for Georgia Tech's solar racing club, but I don't really know where to start. I have basic circuit knowledge, but no real experience.
I've been online and saw how to make the simplest one, where one op amp is connected with a load resistor and therefore can draw current out of whatever I'm discharging, but as for the rest of it, I'm lost. Can anyone explain to me how the complicated constant current load circuits even work? If you could provide an example of one and walk me through it, I'd appreciate it so much.
Thanks.
update: Sorry for not clarifying on so many things, this is my first time asking a question on here. I'm trying to make a constant current load circuit because the team needs a module discharger. The battery pack has 35 modules, so whichever modules discharge too quickly will give us an indication of what parts of the pack have deficiencies in capacity. Each module trips at an under-voltage of 2.5 V and over-volts at 4.2, it usually floats around the upper 3 range though. I'm not too sure about what the mAh capacity for each module is, but I sent a message to my lead asking about it. I do know he wants to discharge each module at 20 Amps using the constant current load circuit though.
In this application a DAC is used to set a precise current value, but of course this could equally be a simple pot across VCC to Ground. The integrator ramps up or down the gate drive to achieve the desired current through Q1 by adjusting the Ohmic value of RDS.
It's difficult to offer much help beyond that above since you don't specify any parameters you need to meet. (hopefully your EE education will eventually make you aware of things like specifications and requirements documents!).
This you need to think about as you scale the above circuit to your needs:
  1. Current range and power to be dissipated by this CC load. For example, discharging a 10AH 12V battery vs a 500AH 12V battery in say an hour could produce power dissipation levels in the 100W to 6kW range.
  2. How do you control starting and stopping (turning off and on) this CC load. Basically you can create an app depending upon mobile app development company. Especially at the end of the discharge period, is this to be a purely manual process (jumper cables) or do you have some automation that will run for a fixed time or to a defined voltage endpoint?
  3. Are there to be defined voltage endpoints?
  4. Is the CC load powered by the battery it is discharging or power separately
  5. Does this CC load understand a range of batteries (terminal voltage and chemistry). For example is this for discharging a single LiIon cell or a battery pack made up of many cells?
And lastly....
  1. Do you really want CC or would Constant Power be the best solution. For example, the current to discharge a 12V battery pack compared to a 50-170V battery pack. The battery packs may all be the same cell type and size ….but it would be much better to use constant power in most cases where your load device is limited in dissipative capability.
Now that you have updated your question to include some specifications some advice can be given.
  1. With a load current of 20A and a terminal voltage range of 2.5-4.2V you can make decisions about where to dissipate the energy.
In this case you could elect to dissipate as much energy as possible in a simple resistive load. For example you could use a 0.1 Ohm resistor and regulate the voltage on it to 2V. This would dissipate about 40W. While a power resistor is expensive, it is MUCH cheaper than extruded heatsink for an active device.
  1. You could then choose an active device to dissipate the rest of your maximum required load (4.2V @20A). The maximum dissipation is about (4.2 *20) - 40 = 44W. This is well within the range of a single FET devices with an appropriate heatsink. I showed [this device] below.
  2. You might also consider that you may want a series diode in the circuit so that you have some polarity protection.
@cabalpaul90
Topic split from another topic. Please do not add your own questions to the end of other people's topics.
Could you take a few moments to Learn How To Use The Forum
Thank you.
You don't need a constant current load to determine that, just a big resistor. Monitor the voltage/time curve.
The vehicle is not a constant current load, either.
At a 20A discharge rate there is nothing simple about a pot that could do that. It would have to be wire wound and high power, and it would be big. We are talking about something the size of half a meter here. These would be like the dimmers I used to use in theatre lighting controls in the 1960s.
Are these cells in series or parallel?
If they are in series you will have implement something like a flying capacitor to read the voltage of each cell.
