i ask this because i use some constrain for my throttle ,, but when i switch to a other mode it stil use the constrain used in the sketch ,
i post the sketch , and i mean in the below part ,, one constrain
this is the one sys = constrain(system,1000,1725); ,,,
this one i onley need in the part its in , but it seems to run true the hole sketch ,,
// dexters KK2.0 automatic flight system //
// debug sketch 5-8-2014 //
#include <Servo.h>
#include <NewPing.h>
#define TRIGGER_PIN 3 // Arduino pin tied to trigger pin on the ultrasonic sensor.
#define ECHO_PIN 2 // Arduino pin tied to echo pin on the ultrasonic sensor.
#define MAX_DISTANCE 600 // max sensor value 400 means 4 meter
NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE); // NewPing setup of pins and maximum distance.
// set height here //
const int height =6000; // is digital value for height
const int auxset =1800; // aux output to kk2.0 for setting auto level onboard on or off !
const int decent =400; // decent delay time this is the hard part depents on survace and height set //
// the above values need to be tuned //
int cm ; //incoming value of sensor 0-100000
int sensor;// sensor cm values in centimeter
int safety =1; // safety switch value//
int auxv ; // Here's where we'll keep our aux channel values 1400 < autolevel off 1400 > = on
int auxs ; // Here i store input aux to servo output numbers
int throtv ; // Here's where we'll keep our throttle channel values
int throts ; // Here i store input throttle to servo output numbers
int system ; // system for do stuf with throttle and height //
int mem1;
int sys;
int led = 13;
int piezo = 10;
// gimbal to horizontal and vertical pos readout //
// normal when start flying on the kk 2.0 the gimbal wil center its pos if used right //
int horim ; // using this for boxing the horizontal value from kk2.0
int horiz ;
Servo throttle; // make servo output to kk2.0 throttle input
Servo aux; // make servo output to kk2.0 aux input
int signal =0; // signal procces
Serial.begin(57600); // starting serial port for APC220 wireles tx rx baud rate 57600
aux.attach(7); // servo conection out pin 7 to kk2.0 aux input //
throttle.attach(8); // servo conection out pin 8 to kk2.0 throttle input //
aux.writeMicroseconds(auxset); // set aux output to autolevel on on kk2.0 //
pinMode(led, OUTPUT);
pinMode(piezo,OUTPUT);
pinMode(4, INPUT); // NEW HORIZ INPUT CHANNEL
pinMode(5, INPUT); // Set input channel for aux on pin 5 from rx //
pinMode(6, INPUT); // Set input channel for throttle on pin 6 from rx //
pinMode(9, INPUT); // Set input channel from gimbal horizontal pin 9 from rx for reading level //
pinMode(10, INPUT); // Set input channel from gimbal vertical pin 10 from rx for reading level //
// some indication light or piezo
digitalWrite(led, LOW); // turn the LED on
digitalWrite(piezo, LOW); // turn the PIEZO on
delay(1000); // wait for a second
digitalWrite(led, HIGH); // turn the LED on
digitalWrite(piezo, HIGH); // turn the PIEZO on
system = 0;
throtv = pulseIn(6, HIGH, 20000); //checking throttle input from rx
auxv = pulseIn(5, HIGH, 20000); //checking throttle input from rx
if (throtv > 1025){ // if throttle is higher then 1025 then safety goes first //
throttle.writeMicroseconds(1000); // throttle on 0 before start
delay (1000);
safety =1; // safety wil be fase 1 = disable trhottle input , and output 0 throttle = disabled mode //
return;
else if (throtv < 1025)
safety =2; // if input throttle = near 0 then safety wil be fase 2 = working quadcopter going to safety fase 3 later = flight mode //
sensor = cm/ US_ROUNDTRIP_CM;
Serial.flush();
Serial.print((char)1);
Serial.print (throts);
Serial.print((char)2);
Serial.print (throtv);
Serial.print((char)3);
Serial.print (height);
Serial.print((char)4);
Serial.print (auxv);
Serial.print((char)5);
Serial.print (auxset);
Serial.print((char)6);
Serial.print (cm);
Serial.print((char)7);
Serial.print (sensor);
Serial.print((char)8);
Serial.print (safety);
Serial.print((char)9);
Serial.print (horiz);
Serial.print((char)10);
Serial.print (0);
Serial.print((char)11);
Serial.print (decent);
Serial.flush();
// vertm = pulseIn(10, HIGH, 20000); //checking gimbal vertical input
horim = pulseIn(4, HIGH, 20000); //checking gimbal horizontal input
horiz =map(horim, 1600, 1400,100,0);
cm = sonar.ping();
if (safety ==1){ // checking startup safety fase ,if fase = 1 then throttle wil be 0 and wil loop till reset button //
delay (3000);
return;
aux.writeMicroseconds(auxset); // aux ON for autolevel kk2.0 conected to aux input //
throtv = pulseIn(6, HIGH, 20000); //checking throttle input pwm
auxv = pulseIn(5, HIGH, 20000); // Read the pulse width of AUX input on pin 5 and reads input pwm//
if (auxv<1300){
system =throtv ; // telling the system the value of the throtle input
throttle.writeMicroseconds(throtv); // write system speed to servo //
// if aux is off the input throttle = equal to input //
sys =throtv;
mem1 =sys;
if(height<cm){ // if sensor is lower then height value //
system = sys -1;// take speed DOWN by 1 digit of the system //
throts = mem1;
sys = constrain(system,1000,2000);
throttle.writeMicroseconds(sys); // write system speed to servo //
delay (decent);
if(height>cm){ // if sensor is lower then height value //
system = sys +4 ;// take speed up by 4 digit of the system //
throts = mem1;
