Constructed String does not allow well functioning Stringoperations
Hello, I am reading from my serial and write / collect it to a string. AUnfortunaly i can not work with stringoperaters afterwards. I made a tiny debug-version with some (mainly) outputs to see what I mean.
I am getting crazy - did I do something wrong? and if so What did I forget to google for ? ;) Tbh: I have no Idea Please have a look at my code and take for Example aa11aa as input
#include "Arduino.h"
String readString;
bool lineComplete = 0;
  Serial.println("serial initialized");
  while ( (Serial.available()>0)  & (!lineComplete) )
    char c = Serial.read();
    if (c == 10 )
      lineComplete=true;
      Serial.print("linecomplete; Readstring ln = ");
      Serial.println(readString.length());
      readString+=c;
  if (lineComplete)
    if (readString.length() >0)
      readString.trim();
      Serial.print("*****String: ");
      Serial.println(readString);
      Serial.print("Length: ");
      Serial.println(String(readString.length()));
      Serial.print("String(readString[0]): ");
      Serial.println(String(readString[0]));
      // prints the correct 1'st char of the String
      Serial.print("is myString equals 'a' on Position 0? ");
      Serial.println(readString[0]=='a');
      // prints 0 but should be 1
      Serial.print("is myString equals ''a'' on Position 0? ");
      Serial.println(String(readString[0])=="a");
      Serial.print("LastIndex of ''a''? ");
      Serial.println(String(readString.lastIndexOf("a")));
      // prints -1 but should be >0
      // and so on with other string operators or even whole strings with more than one character
      lineComplete=false;
Thanks Nils
You're the one with the Arduino, the sample input, and the problem. You show us your output.
Yellow is a crappy color. That text is completely unreadable.
There is no reason to create a String to print one character.
This won't tell you a lot about what is in the String object.
      Serial.print("String: [");
      Serial.print(readString);
      Serial.println("]");
would be a lot better.
PaulS:
==> I chnaged it :zipper_mouth_face:
PaulS:
The casting was only a test from former times - you are right
PaulS:
This won’t tell you a lot about what is in the String object.
[…]would be a lot better.
Good Idea to make it better visible with brackets-
As far as I undersood you’d like to see my output explicitly - here we go
linecomplete; Readstring ln = 6<\r><\n>
*****String:[aa11aa]<\r><\n>
Length:6<\r><\n>
String(readString[0]): a<\r><\n>
is myString equals 'a' on Position 0? 0<\r><\n>
is myString equals ''a'' on Position 0? 0<\r><\n>
LastIndex of ''a''? -1<\r><\n>
As far as I undersood you'd like to see my output explicitly - here we go
Next step is to add some debug statements to WString.cpp, and see what is happening in the class.
Don't do this, though:
The Serial class derives from Stream which derives from Print. The Print class has an overloaded version of println() that knows how to print an integer. Making a String of the int is not necessary.
This concerns me though:
With two major oops in that little bit of code, it tells me that you don't understand what a resource hog the String class is, or how it can fragment memory, leading to all kinds of problems.
Everything that the String class can do can be done with char arrays and string functions (from string.h). At a far lower overall cost.
PaulS:
Wow - unfortunately I am not so deep in c++ (this is quite a long time ago) - If you could introduce me I would appreciate
Don’t do this, though:
[…]The Serial class derives from Stream which derives from Print. The Print class has an overloaded version of println() that knows how to print an integer. Making a String of the int is not necessary.
good to know - thx
no- I did not know that. OK I tried to solute this via an char-array parallel now - with the same effect -
#include "string.h"
String readString;
char readChar[11];
int charCounter = 0;
    if (c == 10 )
      lineComplete=true;
      readString+=c;
      readChar[charCounter]=c;
      charCounter++;
  if (lineComplete)
      readChar[charCounter+1]=0;
      readString.trim();
      Serial.print("*****String:[");
      Serial.print("*****CharArr:[");
      Serial.print(readChar);
      Serial.print("Length of String:");
      Serial.print("Length of CharArr:");
      Serial.println(strlen(readChar));
      Serial.print("CharArr[0]:");
      Serial.println(readChar[0]);
      Serial.print("Is myChar equals 'a' on Position 0?");
      Serial.println(readChar[0]=='a');
      // prints 0 but schould be 1
      Serial.print("Is myChar containing 'a' ?");
      Serial.print(strchr(readChar,'a')));
      Serial.print("String Index ''a''? ");
      Serial.println(readString.indexOf("a"));
      Serial.print("Char FirstIndex of ''a''? ");
      Serial.println(strstr(readChar,"a"));
      // andso on
      lineComplete=false;
      charCounter=0;
The output on “11aa11” is:
*****String:[11aa11]<\r><\n>
*****CharArr:[11aa11]<\r><\n>
Length of String:6<\r><\n>
Length of CharArr:6<\r><\n>
<\r><\n>
String(readString[0]): 1<\r><\n>
CharArr[0]:1<\r><\n>
<\r><\n>
Is myChar equals 'a' on Position 0?0<\r><\n>
<\r><\n>
Is myChar containing 'a' ?0<\r><\n>
String Index ''a''? -1<\r><\n>
Char FirstIndex of ''a''? 0<\r><\n>
SOLUTION
This strange behavior was gone after I moved my Dev-Environment and Sketchbook away from my SD-Card to my harddrive I can not explain why - but it works !
I can't even imagine why.
