Constructor, Destructor or Type Conversion.
So, I amended part of my sketch and ended up with an error report related to the command wire.begin() in setup().
I guess it has something to do with my function to update the RTC but what? I can’t see any difference with the amended code cpmpared to the original code.
The error report is 'expected constructor, destructor or type conversion before ‘;’ token on the ‘wire.begin()’ command.
What is a constructor, destructor or type conversion?
I can’t get all the code on one post so the second part follows.
#include <Wire.h>
#include<LiquidCrystal_I2C.h>
#include <OneWire.h>
#include <DHT.h>
#include <BH1750.h>
BH1750 lightMeter;
#define DS1307_ADDRESS 0x68
#define BACKLIGHT_PIN 3
#define DHTPIN 4
#define DHTTYPE DHT11
DHT dht(DHTPIN, DHTTYPE);
// DS18S20 Temperature chip i/o
  OneWire ds(10);  // on pin 10
LiquidCrystal_I2C lcd(0x3F,2,1,0,4,5,6,7); // 0x3F is the LCD address
byte date;
byte day=0;
byte hour;
byte h;
byte minute;
byte month;
byte No=7;
byte Reset=6;
byte RS=0;
byte second;
byte year=14;
byte Yes=8;
byte zero=0x00;  //Workround for issue #527
//SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
void setup(){
Wire.begin();
lcd.begin(20,4);
dht.begin();
lightMeter.begin();
lcd.setBacklightPin(BACKLIGHT_PIN,POSITIVE);
lcd.setBacklight(HIGH);
pinMode(2,OUTPUT); //Heat
pinMode(6,INPUT);  //reset
pinMode(7,INPUT);  //the no switch
pinMode(8,INPUT);  //the yes switch
pinMode(13,OUTPUT); //Rain
//End Setup
//LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL
void loop(){
   if(digitalRead(Reset)==HIGH)timerReset();
   displayTime();
   heating();
   humidity();
   //displayTime();   //only necessary if accurate seconds display is needed
   light();
   atmosphere();
// Emd of loop
//BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB
timerReset(){
    lcd.setCursor(0,2);
       lcd.clear();
              lcd.print(" Change Date/Time?");
                  lcd.setCursor(0,3);
                      lcd.print("No               Yes");
   wait=millis();
   while (digitalRead(Yes)==LOW &&(digitalRead(No)==LOW){  //wait 5 seconds for switch press
      n=digitalRead(No);
         if((millis()-wait>5000 || n==HIGH)return;
   RS=1;
   resetTimer();
   // end of timerReset
timerReset () doesn't have a type.
(it's "void" BTW)
#include <Wire.h>
#include <DHT.h>
#include <BH1750.h>
Consistency is good. ALWAYS use a space after the include statement, before the file name,
ONE statement per line!
timerReset(){
    lcd.setCursor(0,2);
       lcd.clear();
                  lcd.setCursor(0,3);
Drinking
and
coding
is
a
bad
idea.
Use Tools + Auto Format so your drinking problem is hidden better.
You could have, by attaching it. The stickies at the top of forum explain how.
You gave all those pins names, so why not use them?
    n=digitalRead(No);
I can't see where "n" is defined.
OK, AWOL. Just as I was about to post part two (which looks like it may extend to part three!) !!!
I used to know what that meant but it has left me. Remind me please what a type is.
void timerReset ()
How on earth did I miss that AWOL! Thanks a bunch.
The next problem is with the conversion of decimal to binary. I have been advised by Septillion to make my fragments compile-able but this takes a long time with this sketch because it's big and I'm slow.
If I just show the relevant fragment perhaps someone might see an error.
The error report details objects to the first conversion (second) but I expect it won't like any of them.
  case 6: //reset RTC
    Wire.beginTransmission(DS1307_ADDRESS);  //this is okay
      Wire.write(zero);
        Wire.write (decToBcd(second));
          Wire.write (decToBcd(minute));
            Wire.write (decToBcd(hour));
              Wire.write (decToBcd(day));
                Wire.write (decToBcd(date));
                  Wire.write (decToBcd(month));
                    Wire.write (decToBcd(year));
                      Wire.write(zero);
                        Wire.endTransmission();
      byte decToBcd(byte val){
       return((val/10*16)+(val%10));
      byte bcdToDec(byte val){
       return ((val/16*10)+(val%16));
I'm not sure I can see an error report
You can't define functions INSIDE of other functions.
