Hello,
I am struggling to compile my program and keep getting an error associated with one of my object constructors. I've posted my error and code below. Note that I did not include some of the 'Data Control' source code because I exceeded the character posting limit. Also, the 'CDOS_Info' is a struct that I created. Thanks for any help!
Error:
Arduino: 1.6.5 (Windows 7), Board: "Arduino Uno"
C:\Users\A5KW5ZZ\Desktop\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\CDOS\StateController.cpp: In constructor 'StateController::StateController(CDOS_Info*)':
C:\Users\A5KW5ZZ\Desktop\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\CDOS\StateController.cpp:19:58: error: no matching function for call to 'DataControl::DataControl()'
StateController::StateController(CDOS_Info *inputtedInfo)
C:\Users\A5KW5ZZ\Desktop\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\CDOS\StateController.cpp:19:58: note: candidates are:
In file included from C:\Users\A5KW5ZZ\Desktop\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\CDOS\StateController.h:16:0,
from C:\Users\A5KW5ZZ\Desktop\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\CDOS\StateController.cpp:13:
C:\Users\A5KW5ZZ\Desktop\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\CDOS\DataControl.h:19:3: note: DataControl::DataControl(CDOS_Info*)
DataControl(CDOS_Info *inputtedInfo);
C:\Users\A5KW5ZZ\Desktop\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\CDOS\DataControl.h:19:3: note: candidate expects 1 argument, 0 provided
C:\Users\A5KW5ZZ\Desktop\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\CDOS\DataControl.h:16:7: note: DataControl::DataControl(const DataControl&)
class DataControl
C:\Users\A5KW5ZZ\Desktop\arduino-1.6.5-r2-windows\arduino-1.6.5-r2\libraries\CDOS\DataControl.h:16:7: note: candidate expects 1 argument, 0 provided
Error compiling.
enabled in File > Preferences.
My code:
Main
*********** Import Libraries ******************
#include "CDOS_Definitions.h"
#include "ConfigInit.h"
#include "SensorSerialInterface.h"
#include "StateController.h"
#include "OutputInterface.h"
#include <SoftwareSerial.h>
******* Declare datatypes/objects *************
CDOS_Info info; // Datatype holds general information regarding the CDOS
CDOS_Info * infoPointer = &info; // Declare and define a pointer of the CDOS_Info datatype
ConfigInit configInit(infoPointer); // Configures & initializes the CDOS
SensorSerialInterface sensorInterface(infoPointer); // Controls the communications between the Arduino and IMU
StateController stateController(infoPointer); // Transitions the CDOS between various states
OutputInterface outputMessage(infoPointer); // Outputted serial message providing status information to a computer terminal
*************** Main Program *****************
void setup(){
configInit.config();
configInit.init();
sensorInterface.setAllOutput(); // Force IMU to output status of accelerometer, gyroscope, and magnetometer
void loop(){
sensorInterface.readAll(info.accelXYZ, info.gyroXYZ, info.magXYZ); // Get sensor data
stateController.routine(); // Jump into state transition logic
outputMessage.outputSerial(); // Output CDOS status info
State Controller Header
#ifndef StateController_h
#define StateController_h
#include "InputInterface.h"
#include "DataControl.h"
#include "LEDController.h"
class StateController
public:
StateController(CDOS_Info *inputtedInfo);
void routine(void);
private:
CDOS_Info *info; // create copy of CDOS_Info pointer that member functions can access and modify
InputInterface userInput; // Create input interface object
DataControl dataControl; // Create data control object
LEDController lightController; // Controls the LEDs on the CDOS
#endif
State Controller Source Code
info = inputtedInfo;
userInput = InputInterface();
dataControl = DataControl(info);
lightController = LEDController();
void StateController::routine(void)
int static previousTime;
int currentTime = millis();
bool static startTime = false;
int teachTime = 5000;
// State 0 - Start Up State
if(info->currentState == 0)
// Transition Case
if(userInput.getDigitalInput())
info->currentState = 3;
previousTime = currentTime;
// Lighting
lightController.setLightConfig0();
// State 1 - Disturbed State
else if(info->currentState == 1)
// Transition Case
// Compute vertical angle
dataControl.calculateVerticalAngle();
// Lighting
lightController.setLightConfig1();
// State 2 - Faulted State
else if(info->currentState == 2)
// Haven't created any cases where the system can fault yet, will finish later
// Lighting
lightController.setLightConfig2();
// State 3 - Teaching State
else if(info->currentState == 3)
// Transition Case
if(abs(currentTime - previousTime) > teachTime)
info->currentState = 4;
dataControl.teachNewPosition();
// Lighting
lightController.setLightConfig3();
// State 4 - Taught State
else if(info->currentState == 4)
// Transition Case
if(dataControl.checkPosition())
info->currentState = 1;
// Lighting
lightController.setLightConfig4();
Data Control Header
#ifndef DataControl_h
#define DataControl_h
class DataControl
public:
void teachNewPosition(void);
bool checkPosition(void);
void calculateVerticalAngle(void);
private:
#endif
Data Control Source Code
#include "Arduino.h"
DataControl::DataControl(CDOS_Info *inputtedInfo)
