Consulta
Arduino: 1.8.6 (Windows Store 1.8.14.0) (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, Flash, ck, 26 MHz, 40MHz, QIO, 512K (no SPIFFS), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
Sketch uses 247952 bytes (49%) of program storage space. Maximum is 499696 bytes.
Global variables use 28016 bytes (34%) of dynamic memory, leaving 53904 bytes for local variables. Maximum is 81920 bytes.
C:\Users\ingri\Documents\ArduinoData\packages\esp8266\tools\esptool\0.4.13/esptool.exe -vv -cd ck -cb 115200 -cp COM4 -ca 0x00000 -cf C:\Users\ingri\AppData\Local\Temp\arduino_build_340455/modulowifi.ino.bin
esptool v0.4.13 - (c) 2014 Ch. Klippel ck@atelier-klippel.de
setting board to ck
setting baudrate from 115200 to 115200
setting port from COM1 to COM4
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
espcomm_upload_mem
setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
An error occurred while uploading the sketch
flush start
setting serial port timeouts to 1 ms
flush complete
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
resetting board
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
resetting board
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
warning: espcomm_sync failed
error: espcomm_open failed
error: espcomm_upload_mem failed
option enabled in File -> Preferences.
@ingrid_rpm a description of what you are trying to do would help.
...R
Have you looked at the stickies which deal with posting questions?
https://forum.arduino.cc/index.php?topic=149014.0
