Hi
I have a certain need, and I think Arduino can help me. I have no experience in programming so I'm looking for somebody to help me and I will pay the helper. Electro in general I am skilled.
I will make 2 complete setts.
My idea for a helper and me:
Set 1:
A helper will make, he needs to order parts for himself, and do the programming and then send it to me.
Set 2:
I will build in parallel, this way i can do the same job home as the helper do, and i can test it.
The project is described in my sketch and:
How it works:
I determine number of cycles pr 24h, and I determine runtime in seconds and i program the timer with push buttons.
Power button + LED indicator.
Display:
2 digts for cycles pr 24h
2 digits for runtime i seconds
This appliance will use a SSR to switch a AC 230V pump on (and off).
It must be encapsulated in IP66 (waterproof)
When everything is finished i own the code and can reuse it as I like, and also make it open source.
If somebody can direct me to a finished set/description i will be happy and i probably dont need to develop this.
If i cant find a working set to buy i asks you programmers to help me out, please send me an PM.
If this works out, I have another project that is slightly bigger, variable pump speed AC 230 V pump based on measured water level. But first project Timer.
Thanks
