contact closure to send usb keypad function
I am using an Arduino uno for my project. I am trying to use a contact closure to trigger the uno to send the charter 9. I have figured that digital pin 2 is what needs to be connected to the contact to trigger a response on the uno. By this the TX light flashes, but nothing happens. I am brand new at programming, and have learned a whole lot lately, but I need a little guidance to figure this out. Thanks.
#include <Keypad.h>
const byte ROWS = 1; //four rows
const byte COLS = 1; //three columns
char keys[ROWS][COLS] =
{‘9’},
byte rowPins[ROWS] = {2}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {6}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad(makeKeymap(keys), rowPins, colPins, ROWS, COLS );
char key = keypad.getKey();
if (int(key) != 0){
Serial.println(key);
Have you opened up the serial monitor to look at the output?
Is it set to the same baud rate?
Why are you using a matrix key pad code for just a simple contact closure? Just a digital read would do.
