Contapezzi con display 7 segment
Flavi71:
Scusa Torn o sono "de coccio" io o ... ho sostituito la porzione di codice esattamente uguale alla tua, ma non cambia nulla, appare solo il numero 001 e poi non va più avanti.
 //State change detection (edge detection)
//We always have to include the library
#include "LedControl.h"
Now we need a LedControl to work with.
pin 12 is connected to the DataIn
pin 11 is connected to the CLK
pin 10 is connected to LOAD
We have only a single MAX72XX.
LedControl lc=LedControl(12,11,10,1);
/*  The circuit:
  • buttonpin attached to pin 2 from +5V
  • buttonreset attached to pin 4 from +5V
  • 10 kilohm resistor attached to pin 2&4 from ground
    // this constant won't change:
    const int  buttonPin = 2;// the pin that the pushbutton is attached to
    const int  buttonReset = 4;// the pin that the buttonreset is attached to
// Variables will change:
int contatore = 0;  // counter for the number of button presses
int buttonState = 0;        // current state of the button
int lastButtonState = 0;    // previous state of the button
int unita = 0;
int decine = 0;
int centinaia = 0;
void setup(){
  The MAX72XX is in power-saving mode on startup,
  we have to do a wakeup call
  lc.shutdown(0,false);
Set the brightness to a medium values /
  lc.setIntensity(0,8);
and clear the display */
  lc.clearDisplay(0);
// initialize the button pin as a input:
  pinMode(buttonPin, INPUT);
  pinMode(buttonReset, INPUT);
  // read the pushbutton input pin:
  buttonState = digitalRead(buttonPin);
// compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH) {
      // if the current state is HIGH then the button went from off to on:
      contatore++;
unita=contatore%10;
contatore=contatore/10;
decine=contatore%10;
centinaia=contatore/10;
lc.setDigit(0,2,(byte)centinaia,false);
      lc.setDigit(0,1,(byte)decine,false);
      lc.setDigit(0,0,(byte)unita,false);
    // Delay a little bit to avoid bouncing
    delay(50);
  // save the current state as the last state, for next time through the loop
  lastButtonState = buttonState;
// if the buttonreset is pressed reset the buttonpushcounter
  if  (digitalRead(buttonReset) == HIGH){
      (contatore = 0);
      lc.clearDisplay(0);
ma non è che te non hai ancora afferrato qualcosa :o :confused:
non puoi mettere la variabile contatore direttamente attraverso il ...contatore%10.. dopo pochi microsecondi l'avrai divisa per 10 migliaia di volte
elrospo:
E quindi? Spiegati meglio, cosa dovrei fare...?
Creare all'inizio del ciclo di scrittura su 7s una variabile ausiliaria (contatore2) resa uguale a contatore. Successivamente usi questultima invece di contatore per le varie divisioni. Così facendo non tocchi contatore, il quale resta dek suo valore, mentre la variabile nuova che usi viene resa ogni ciclo uguale a contatore.
Grazie elrospo, non ci sarei mai arrivato
Be questo era un problema che non avevo pensato!BISOGNA USARE UNA VARIABILE DI APPOGGIO
int tmp=contatatore;
e poi fare i calcoli con la variabile temporanea cosi da non modificare contatore.
Fino a 99 funziona perchè non dividiamo contatore per 10, non facciamo contatore=contatore/10
Mentre per contare le centinaia dividiamo per 10
Dovrebbe essere quello il problema! ESEMPIO Conti uno poi lo dividiamo per 10 e poi aggiungi uno, quindi hai sempre un unita, con la variabile di appoggio invece contatore arriva a 999
Per quanto riguarda fare calcoli li ho provati e sono corretti! Se devi valutare solo codice C e non usare librerie di arduino o elettronica, allora un qualunque compilatore C va bene.
Esempio qui dobbiamo fare dei calcoli, questo è C puro, per cui lo si può provare su qualunque compilatore,
io per provare piccoli pezzi di codice uso l'ide online IDEONE.
Con variabile di appoggio Modifica:
/*  The circuit:
 - buttonpin attached to pin 2 from +5V
 - buttonreset attached to pin 4 from +5V
 - 10 kilohm resistor attached to pin 2&4 from ground
int unita = 0;
int decine = 0;
int centinaia = 0;
int tmp=0;
void setup(){
  /* Set the brightness to a medium values */
  /* and clear the display */
  lc.clearDisplay(0);
    if (digitalRead(buttonPin)==HIGH){
        contatore++;
        tmp=contatore;
        unita=tmp%10;
        tmp=tmp/10;
        decine=tmp%10;
        centinaia=tmp/10;
        Serial.print(centinaia);
        Serial.print("-");
        Serial.print(decine);
        Serial.print("-");
        Serial.print(unita);
        Serial.println(" ");
    if(contatore>999) contatore=0; // Ritorna a zero quando deve contare 1000
    delay(200);
        (contatore = 0);
         lc.clearDisplay(0);
Ok grazie, complimenti a tutti...problema risolto, testato e funziona ;D
Ora un ultima domanda: alimentando questo aggeggio con una pila da 9V, quanto tempo può durare?
Uso un arduino nano e un display 7 segment MAX7219. Vedi schema allegato.
un paio d'ore?...
NON é risposta alla domanda, ma si potrebbe ottimizzare un po il calcolo del contatore. Credo di poter eliminare i due if.
contatore=((contatore+letturapulsanteaggiungi)*(!letturapulsanteazzeramento))%100;
Inoltre credo che se metto prima di tutta la pappardella variabilediappoggio= ho ridotto di un'altra riga.
Potrei anche evitare il calcolo delle unità e delle decine ecc. come variabili singole, e passare direttamente alla funzione il calcolo. E inoltre se usassi un ciclo for potrei, con due righe di codice, stampare tutte le cifre che voglio:
for (byte numcifra=0;numcifra<massiko+1;numcifra++)
lcd.setdigit (0,numcifra,variabilediappoggio%10,0);
variabilediappoggio/=10;
Quello del fare calcoli con un ciclo è un idea furba! Mi è già capitato di calcolare le cifre di un numero in altri linguaggi!
Forse serve un cast a byte, (byte)variabile%10, visto che variabile deve essere di tipo int.
E' una questione di necessità o meno che porta all'adozione di una soluzione o un altra! Esempio per calcolare unità,decine e centinaia abbiamo scritto 5 righe di codice, ottimizzarla è un bene ma non una necessità. Se invece avessimo dovuto calcolare le cifre di valori di miliardi avremmo dovuto scrivere decine di righe di codice ,probabilmente di fronte a questo problema sarebbe nato spontaneamente l'idea di usare un ciclo, perché la necessità portava a quella soluzione.
Salve, sono anche io interessato al contapezzi .. ma se invece di incrementare volessi decrementare facendo partire il contatore da 300? Il codice come varia? E volendo posso sostituire il pulsante fisico con un sensore IR singolo ? Proiettando su di esso un fascio luminoso cosi ad ogni passaggio di un oggetto si ha l interruzione di tale fascio e automaticamente mi decrementa a 299 poi 298 e cosi via?
Se vuoi andare a decrementare imposti il contatore iniziale a 300 poi con il pulsante (o col sensore come vuoi fare tu) al posto di contatore++ metti contatore--.
Per il sensore potresti usare anche uno a ultrasuoni, meno influenzabile dalla luce.
ho Caricato il codice di TORN24 il risultato è display spento e non vuole funzionare, cosa ho sbagliato?
Mi da questo Problema..qualcuno sa spiegarmi come mai?
Fury_man:
Puoi postare uno schema dei collegamenti che hai fatto? E anche il codice che hai caricato.
Questo è il codice che ho inserito. ho usato un arduino nano, un integrato max 7219 e un display a 7 segmenti a 3 cifre a catodo comune, ho collegato i rispettivi pin del display al max7219 e poi al nano datain al pin 12, clk al pin 11 e il load al pin 10 di arduino come scritto nel codice. una volta caricato non funziona, il led rimane spento..
/*  The circuit:
int unita = 0;
int decine = 0;
int centinaia = 0;
int tmp=0;
void setup(){
  lc.clearDisplay(0);
        contatore++;
        tmp=contatore;
        unita=tmp%10;
        tmp=tmp/10;
        decine=tmp%10;
        centinaia=tmp/10;
        Serial.print("-");
        Serial.print("-");
    delay(200);
        (contatore = 0);
         lc.clearDisplay(0);
Se hai fatto i collegamenti come lo schema allegato (lascia stare il buzzer) deve almeno accendersi. Comunque io ho usato il modulo già assemblato (vedi foto allegata), posta qualche foto/schema del tuo circuito.
Questo è il circuito, scusate per il disegno pessimo, comunque ho notato che nello schema con il buzzer non hai collegato i piedini D10, D11 e D12 ma bensì altri anche se nel programma sta citato che hai utilizzato quei piedini li d10, d11 e d12. Non riesco proprio a capire dove sbaglio... ah i pulsanti non li ho disegnati ma sono stati collegati al piedino D2 e D3.
Ma la resistenza tra ISET e il positivo, ce l'hai messa ?
Ahm no, non ho messo la resistenza tra iset e positivo.. di quanto gliela devo mettere? E a cosa serve la
Resistenza su quel pin?
Fury_man:
scusa ma ho fatto talmente tante prove/modifiche a quel circuito che non ricordo più quale è quello definitivo ::slight_smile: domani controllo poi ti dico.
Flaviano
Fammi sapere perché davvero non so come farlo funzionare :confused:
