Contatore non si azzera
Salve, sapete dirmi perchè il contatore non si azzera con le ultime 2 righe di codice? Ho modificato l' esempio dell' IDE State change detection
Alla pressione del pulsante collegato al Pin 4 vorrei azzerare il buttonpushcounter.
Grazie.
[code]
  State change detection (edge detection)
  Often, you don't need to know the state of a digital input all the time, but
  you just need to know when the input changes from one state to another.
  For example, you want to know when a button goes from OFF to ON. This is called
  state change detection, or edge detection.
  This example shows how to detect when a button or button changes from off to on
  and on to off.
  The circuit:
  - pushbutton attached to pin 2 from +5V
  - 10 kilohm resistor attached to pin 2 from ground
  created  27 Sep 2005
  modified 30 Aug 2011
  by Tom Igoe
  This example code is in the public domain.
  http://www.arduino.cc/en/Tutorial/ButtonStateChange
// this constant won't change:
const int  buttonPin = 2;// the pin that the pushbutton is attached to
const int  buttonReset = 4;// the pin that the buttonreset is attached to
// Variables will change:
int buttonPushCounter = 0;   // counter for the number of button presses
int buttonState = 0;         // current state of the button
int lastButtonState = 0;     // previous state of the button
  // initialize the button pin as a input:
  pinMode(buttonPin, INPUT);
  pinMode(buttonReset, INPUT);
  // initialize serial communication:
  // read the pushbutton input pin:
  buttonState = digitalRead(buttonPin);
  // compare the buttonState to its previous state
  if (buttonState != lastButtonState) {
    // if the state has changed, increment the counter
    if (buttonState == HIGH) {
      // if the current state is HIGH then the button went from off to on:
      buttonPushCounter++;
      Serial.println("on");
      Serial.print("number of button pushes: ");
      Serial.println(buttonPushCounter);
      // if the current state is LOW then the button went from on to off:
      Serial.println("off");
    // Delay a little bit to avoid bouncing
    delay(50);
  // save the current state as the last state, for next time through the loop
  lastButtonState = buttonState;
  // if the buttonreset is pressed reset the buttonpushcounter
  if  (digitalRead(buttonReset) == HIGH){
      (buttonPushCounter == 0);
ciao
penso che il problema che tu non stia azzerando. per azzerare un solo =
con due == è un confronto, NON un'assegnazione :slight_smile:
Prova e fammi sapere :slight_smile:
MD
Hai ragione Matteo. Modificato e...funziona.
Grazie. :slight_smile: :slight_smile: :slight_smile:
bene son contento :slight_smile:
Buona continuazione :slight_smile:
MD
