Here is the code, hope I am posting it correctly...
//------------- MMA7455 3 Axis Accel -----------
// 26 Apr 2014 debug SP
//#include <SD.h> // SD and RTC commented out
//#include "RTClib.h"
#include <Wire.h>
#include <SoftwareSerial.h>
#define I2C_ADDRESS 0x1D // accel address
#define MMA7455_XOUTL 0x00 // MMA7455 Registers
#define MMA7455_XOUTH 0x01
#define MMA7455_YOUTL 0x02
#define MMA7455_YOUTH 0x03
#define MMA7455_ZOUTL 0x04
#define MMA7455_ZOUTH 0x05
#define MMA7455_XOUT8 0x06
#define MMA7455_YOUT8 0x07
#define MMA7455_ZOUT8 0x08
#define MMA7455_STATUS 0x09
#define MMA7455_DETSRC 0x0A
#define MMA7455_TOUT 0x0B
#define MMA7455_I2CAD 0x0D
#define MMA7455_USRINF 0x0E
#define MMA7455_WHOAMI 0x0F
#define MMA7455_XOFFL 0x10
#define MMA7455_XOFFH 0x11
#define MMA7455_YOFFL 0x12
#define MMA7455_YOFFH 0x13
#define MMA7455_ZOFFL 0x14
#define MMA7455_ZOFFH 0x15
#define MMA7455_MCTL 0x16
#define MMA7455_INTRST 0x17
#define MMA7455_CTL1 0x18
#define MMA7455_CTL2 0x19
#define MMA7455_LDTH 0x1A
#define MMA7455_PDTH 0x1B
#define MMA7455_PW 0x1C
#define MMA7455_LT 0x1D
#define MMA7455_TW 0x1E
#define greenLED 8 // "L1" Green
#define redLED 9 // "L2" Red
//RTC_DS1307 RTC; // define the Real Time Clock
const int chipSelect = 10; // 10;
SoftwareSerial mySerial(6,7); // RX, TX, LCD
//File logfile; // the logging file
String m;
byte xval, yval, zval, sval, mval, r, d;
double dX,dY,dZ, ix, iy, iz, hx, hy, hz;
int Loop;
void error(char *str)
Serial.print("error: ");
Serial.println(str);
while(1);
//* Setup *
Wire.begin(); // join i2c bus
pinMode(redLED, OUTPUT);
pinMode(greenLED, OUTPUT);
pinMode(chipSelect, OUTPUT);
Serial.begin(9600); // start serial for output
mySerial.begin(9600);
mySerial.write(12); // clear LCD
mySerial.write(22); // backlight on
digitalWrite(chipSelect, HIGH); // tried CS both ways..
//digitalWrite(chipSelect, LOW);
digitalWrite(redLED, LOW);
digitalWrite(greenLED, HIGH);
WriteReg(MMA7455_MCTL, B00101); // I2C, 2g range, Reg 0x16
delay(200);
mval = ReadReg(MMA7455_MCTL); // Read Mode Control Register
mySerial.write(128);
mySerial.print("MODE: ");
mySerial.print(mval, HEX);
sval = ReadReg(MMA7455_STATUS); // Read Status Register
mySerial.print(" STATUS: ");
mySerial.println(sval, HEX);
delay(2000);
/* // RTC stuff commented out
RTC.begin();
if (! RTC.isrunning()) {
Serial.println("RTC is NOT running!");
// Sets RTC date & time when sketch is compiled.
// Uncomment it to set the time & date.
//RTC.adjust(DateTime(__DATE__, __TIME__));
// SD card stuff commented out
mySerial.write(168); // for LCD position 0,0
if (!SD.begin(chipSelect)) { // card is present & can be initialized
error("Card failed, or not present");
mySerial.println("Card initialized");
delay(1200);
char filename[] = "LOGGER00.CSV"; // create a new file
for (uint8_t i = 0; i < 100; i++) {
filename[6] = i/10 + '0';
filename[7] = i%10 + '0';
if (! SD.exists(filename)) {
logfile = SD.open(filename, FILE_WRITE);
break; // leave the loop
if (! logfile) {error("couldnt create file");}
delay(2000);
Loop=0; // Loop flag
hx = -10; // init max reading variables
hy = -10;
hz = -10;
//* Read *
unsigned char ReadReg(unsigned char reg)
Wire.beginTransmission(I2C_ADDRESS); // write register address first
Wire.write(reg);
Wire.endTransmission();
Wire.requestFrom(I2C_ADDRESS, 1); // read the data back
if(Wire.available())
return Wire.read();
return 0; // return zero if no data
//* Write *
void WriteReg(unsigned char reg, unsigned char value)
Wire.write(reg);
Wire.write(value); // and then write data
//* Loop *
digitalWrite(redLED, HIGH);
/* commented out RTC stuff
mySerial.write(128); // for LCD position 0,0
DateTime now;
now = RTC.now(); // fetch the time
mySerial.print(now.month(), DEC);
mySerial.print("/");
m = String(now.day());
if (m.length() < 2) mySerial.print("0" + m);
if (m.length() > 1) mySerial.print(m);
mySerial.print(now.year(), DEC);
mySerial.print(" ");
m = String(now.hour());
mySerial.print(":");
m = String(now.minute());
xval = ReadReg(MMA7455_XOUT8); // only using X axis for now
//yval = ReadReg(MMA7455_YOUT8);
//zval = ReadReg(MMA7455_ZOUT8);
dX = (double) xval / 64.0; // calculate the 'g' values
//dY = (double) yval / 64.0;
//dZ = (double) zval / 64.0;
if (Loop == 0) // check loop flag
ix = dX; // save initial offset
//iy = dY;
//iz = dZ;
dX = dX - ix; // zero out readings
//dY = dY - iy;
//dZ = dZ - iz;
if (dX > hx) hx = dX; // save maximum reading
//if (dY > hy) hy = dY;
//if (dZ > hz) hz = dZ;
mySerial.write(148);
mySerial.print("X: ");
mySerial.print(dX, 1); // display the current reading
mySerial.print(" hx: "); // and max reading
mySerial.print(hx, 1);
delay(100);
mySerial.print("Y: ");
mySerial.println(dY, 1);
mySerial.print(" hy: ");
mySerial.print(hy, 1);
mySerial.write(188);
mySerial.print("Z: ");
mySerial.println(dZ, 1);
mySerial.print(" hz: ");
mySerial.print(hz, 1);
Serial.print(F("x: "));
Serial.print(dx, 2);
Serial.print(F("y: "));
Serial.print(dy, 2);
Serial.print(F("z: "));
Serial.println(dz, 2);
Serial.println("........");
delay(0);
Loop = Loop + 1; // increment loop counter
//---------------------------- end --------------------------
