Contest MKR Broken?
I'm worried. I just plugged in my MKR, I it's barely used so far (I've done code, etc. on it, but no hardware) and it [u]powers on but isn't detected by my computer[/u]. This is kinda stressing me out. Has anyone else had this problem, and is there a fix? NOTE: I am using a contest MKR1000. I have disconnected everything from it, still, nothing.
double tap the reset button. Also verify that your usb cord isn't a power only cord
Ok, I know the USB is data, used it with another device, worked fine. ERMYGERSH! Pressed the button twice. THANK. YOU. Now I can continue using it!
Smebdy: Ok, I know the USB is data, used it with another device, worked fine. ERMYGERSH! Pressed the button twice. THANK. YOU. Now I can continue using it!
Awesome! I had the same issue trying bad code a few times and had found the double tap trick buried in another post
