Continously running an linear actuator
I am trying to get a linear actuator to run continuously with an Arduino. The linear actuator that I have is this: https://www.progressiveautomations.com/products/linear-actuator-with-potentiometer
I was just going to connect the actuator directly into the Arduino and have a 12V power supply hooked up as well. I am thing that I would only to get a code to get the actuator to run continuously. The goal of this project is to open and close a door for 12 hours for testing purposes.
Will I need to get relays and an H-Bridge, or would this set up work?
Any help would be fantastic.
You'r funny!!! You expect to get 5 amperes+ from an Arduino pin?
Paul
And use 12 volt to the Arduino outputs? You will create a toaster.
You will need a 10 Amp power supply and motor driver (for safety). Pololu has the best selection of motor drivers.
That actuator has a 25% duty cycle, meaning you run it for X minutes, then let it cool down for 3X minutes.
X might be small.
