Hi, I need to run a program when it is stopped due to power down and when it's got power back it should continue where it stopped
If I was to use a program to save its current state when main power is lost, I'd start with an electronic circuit that would do 2 things.
Thing1 detect when power is lost and send a signal to the MCU to save save save.
Thing2 keep the MCU powered long enough for the save save save then remove power after the save save save.
Have you made your Loss Of Power Detection and Keep Alive circuit? Does you circuit have a trigger to let the MCU know it's time to save save save?
thanks for the reply ,
No, i don't know that
But I need to run where it stopped when power is on, I have tried to save the previous state on External memory and read from memory when once power back, but it didn't work for me
any simple steps to do that
Please post the full sketch that didn't work and describe what went wrong
Without a LOP (Loss Of Power) circuit, getting your code to work will be problematic. Perhaps even futile.
#define buttonPin 2
#define ledPin 13
int buttonState = 0;
int count;
pinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT);
void loop(){
buttonState = digitalRead(buttonPin);
if (buttonState == HIGH) {
count++;
delay(100);
if(count==1)
digitalWrite(ledPin, HIGH);
if (count==2) {
digitalWrite ledPin, LOW);
delay(300);
count=0;
for this program I need to turn on the led based on previous state
Post a schematic of your loss of power detection circuit. Working on your code will be futile till the LOP circuit is working.
I already did it (in assembler) this way:
1- Have a non volatile memory. I used a battery backed memory as RAM in the project.
2- Early detection of power failure. (PWF)
3- Keep the processor alive long enough after PWF, to get enough energy to write its registers to the battery backed memory. The processor idles, waiting for the final PWF.
4- When the power restores, the processor verifies its former registers exist as back-up on RAM, if so registers are reloaded and the program resumes. If not, a normal reset is done.
Not an easy operation. I needed an interrupt routine.
here Assume, if the LED state is ON then power is lost, when the power got back then the LED state should be ON. I need solution for this
You could save the state of the LED to EEPROM when the state changes and read it back in setup() to set the state back to the last state saved. You will need to detect when the change of state occurs to avoid writing to the EEPROM continuously
You need to detect when the button becomes pressed rather than when it is pressed
See the StateChangeDetection example in the IDE
How is the input wired ? Have you got a pulldown resistor in place to keep it in a known state at all times when the button is not pressed ?
#include <EEPROM.h>
#define buttonPin 2
#define ledPin 13
const int COUNT_ADDR = 1;
int count;
for (int i = 0 ; i < EEPROM.length() ; i++) {
EEPROM.write(i, 0);
//count=EEPROM.get(COUNT_ADDR, count);
count= EEPROM.read(COUNT_ADDR);
void loop(){
count++;
EEPROM.put(COUNT_ADDR, count);
delay(100);
if(count==1)
EEPROM.update(COUNT_ADDR, count);
if (count==2) {
digitalWrite (ledPin, LOW);
delay(300);
count=0;
is this program is correct ..?
yes, I'm using a resistor.
No
What do you think the value of count will be after
EEPROM.write(i, 0);
count = EEPROM.read(COUNT_ADDR);
Apart from any other problem (there is at least one), count is an int and needs 2 bytes of storage but EEPROM.write() and EEPROM.read() only write and read a single byte
what if i delete for loop
#include <ESP8266WiFi.h>
#include <Espalexa.h>
#include <IRremote.h>
#include <AceButton.h>
using namespace ace_button;
Espalexa espalexa;
// define the GPIO connected with Relays and switches
#define RelayPin1 5 //D23
#define RelayPin2 22 //D22
#define RelayPin3 21 //D21
#define RelayPin4 19 //D19
#define RelayPin5 18 //D18
#define RelayPin6 5 //D5
#define RelayPin7 25 //D25
#define RelayPin8 26 //D26
#define SwitchPin1 14 //D13
#define SwitchPin2 12 //D12
#define SwitchPin3 14 //D14
#define SwitchPin4 27 //D27
#define SwitchPin5 33 //D33
#define SwitchPin6 32 //D32
#define SwitchPin7 15 //D15
#define SwitchPin8 4 //D4
#define wifiLed 2 //D2
#define IR_RECV_PIN 35 //D35
// WiFi Credentials
const char* ssid ="ssid";
const char* password = "password";
// device names
String Device_1_Name = "Study Lamp";
String Device_2_Name = "Fan";
String Device_3_Name = "light";
String Device_4_Name = "Projector";
String Device_5_Name = "Studio Light";
String Device_6_Name = "Outdoor Light";
String Device_7_Name = "Kitchen Light";
String Device_8_Name = "Room Light";
int toggleState_1 = 0; //Define integer to remember the toggle state for relay 1
int toggleState_2 = 0; //Define integer to remember the toggle state for relay 2
int toggleState_3 = 0; //Define integer to remember the toggle state for relay 3
int toggleState_4 = 0; //Define integer to remember the toggle state for relay 4
int toggleState_5 = 0; //Define integer to remember the toggle state for relay 5
int toggleState_6 = 0; //Define integer to remember the toggle state for relay 6
int toggleState_7 = 0; //Define integer to remember the toggle state for relay 7
int toggleState_8 = 0; //Define integer to remember the toggle state for relay 8
IRrecv irrecv(IR_RECV_PIN);
decode_results results;
// prototypes
boolean connectWifi();
//callback functions
void firstLightChanged(uint8_t brightness);
void secondLightChanged(uint8_t brightness);
void thirdLightChanged(uint8_t brightness);
void fourthLightChanged(uint8_t brightness);
void fifthLightChanged(uint8_t brightness);
void sixthLightChanged(uint8_t brightness);
void senventhLightChanged(uint8_t brightness);
void eighthLightChanged(uint8_t brightness);
ButtonConfig config1;
AceButton button1(&config1);
ButtonConfig config2;
AceButton button2(&config2);
ButtonConfig config3;
AceButton button3(&config3);
ButtonConfig config4;
AceButton button4(&config4);
ButtonConfig config5;
AceButton button5(&config5);
ButtonConfig config6;
AceButton button6(&config6);
ButtonConfig config7;
AceButton button7(&config7);
ButtonConfig config8;
AceButton button8(&config8);
void handleEvent1(AceButton*, uint8_t, uint8_t);
void handleEvent2(AceButton*, uint8_t, uint8_t);
void handleEvent3(AceButton*, uint8_t, uint8_t);
void handleEvent4(AceButton*, uint8_t, uint8_t);
void handleEvent5(AceButton*, uint8_t, uint8_t);
void handleEvent6(AceButton*, uint8_t, uint8_t);
void handleEvent7(AceButton*, uint8_t, uint8_t);
void handleEvent8(AceButton*, uint8_t, uint8_t);
boolean wifiConnected = false;
//our callback functions
//Control the device
if (brightness == 255)
digitalWrite(RelayPin1, LOW);
Serial.println("Device1 ON");
toggleState_1 = 1;
digitalWrite(RelayPin1, HIGH);
Serial.println("Device1 OFF");
toggleState_1 = 0;
digitalWrite(RelayPin2, LOW);
Serial.println("Device2 ON");
toggleState_2 = 1;
digitalWrite(RelayPin2, HIGH);
Serial.println("Device2 OFF");
toggleState_2 = 0;
digitalWrite(RelayPin3, LOW);
Serial.println("Device3 ON");
toggleState_3 = 1;
digitalWrite(RelayPin3, HIGH);
Serial.println("Device3 OFF");
toggleState_3 = 0;
digitalWrite(RelayPin4, LOW);
Serial.println("Device4 ON");
toggleState_4 = 1;
digitalWrite(RelayPin4, HIGH);
Serial.println("Device4 OFF");
toggleState_4 = 0;
digitalWrite(RelayPin5, LOW);
Serial.println("Device5 ON");
toggleState_5 = 1;
digitalWrite(RelayPin5, HIGH);
toggleState_5 = 0;
digitalWrite(RelayPin6, LOW);
Serial.println("Device6 ON");
toggleState_6 = 1;
digitalWrite(RelayPin6, HIGH);
Serial.println("Device6 OFF");
toggleState_6 = 0;
void seventhLightChanged(uint8_t brightness)
digitalWrite(RelayPin7, LOW);
Serial.println("Device7 ON");
toggleState_7 = 1;
digitalWrite(RelayPin7, HIGH);
Serial.println("Device7 OFF");
toggleState_7 = 0;
digitalWrite(RelayPin8, LOW);
Serial.println("Device8 ON");
toggleState_8 = 1;
digitalWrite(RelayPin8, HIGH);
Serial.println("Device8 OFF");
toggleState_8 = 0;
void relayOnOff(int relay){
EspalexaDevice* d = espalexa.getDevice(relay-1); //the index is zero-based
switch(relay){
case 1:
if(toggleState_1 == 0){
d->setPercent(100); //set value "brightness" in percent
digitalWrite(RelayPin1, LOW); // turn on relay 1
toggleState_1 = 1;
else{
d->setPercent(0); //set value "brightness" in percent
digitalWrite(RelayPin1, HIGH); // turn off relay 1
toggleState_1 = 0;
case 2:
if(toggleState_2 == 0){
d->setPercent(100);
digitalWrite(RelayPin2, LOW); // turn on relay 2
toggleState_2 = 1;
else{
d->setPercent(0);
digitalWrite(RelayPin2, HIGH); // turn off relay 2
toggleState_2 = 0;
case 3:
if(toggleState_3 == 0){
d->setPercent(100);
digitalWrite(RelayPin3, LOW); // turn on relay 3
toggleState_3 = 1;
else{
d->setPercent(0);
digitalWrite(RelayPin3, HIGH); // turn off relay 3
toggleState_3 = 0;
case 4:
if(toggleState_4 == 0){
d->setPercent(100);
digitalWrite(RelayPin4, LOW); // turn on relay 4
toggleState_4 = 1;
else{
d->setPercent(0);
digitalWrite(RelayPin4, HIGH); // turn off relay 4
toggleState_4 = 0;
case 5:
if(toggleState_5 == 0){
d->setPercent(100);
digitalWrite(RelayPin5, LOW); // turn on relay 5
toggleState_5 = 1;
else{
d->setPercent(0);
digitalWrite(RelayPin5, HIGH); // turn off relay 5
toggleState_5 = 0;
Serial.println("Device5 OFF");
case 6:
if(toggleState_6 == 0){
d->setPercent(100);
digitalWrite(RelayPin6, LOW); // turn on relay 6
toggleState_6 = 1;
else{
d->setPercent(0);
digitalWrite(RelayPin6, HIGH); // turn off relay 6
toggleState_6 = 0;
case 7:
if(toggleState_7 == 0){
d->setPercent(100);
digitalWrite(RelayPin7, LOW); // turn on relay 7
toggleState_7 = 1;
else{
d->setPercent(0);
digitalWrite(RelayPin7, HIGH); // turn off relay 7
toggleState_7 = 0;
case 8:
if(toggleState_8 == 0){
d->setPercent(100);
digitalWrite(RelayPin8, LOW); // turn on relay 8
toggleState_8 = 1;
else{
d->setPercent(0);
digitalWrite(RelayPin8, HIGH); // turn off relay 8
toggleState_8 = 0;
default : break;
delay(300);
// connect to wifi – returns true if successful or false if not
boolean state = true;
int i = 0;
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.println("");
Serial.println("Connecting to WiFi");
// Wait for connection
Serial.print("Connecting...");
Serial.print(".");
if (i > 20) {
state = false; break;
i++;
Serial.println("");
if (state) {
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
else {
Serial.println("Connection failed.");
return state;
void addDevices(){
// Define your devices here.
espalexa.addDevice(Device_1_Name, firstLightChanged); //simplest definition, default state off
espalexa.addDevice(Device_2_Name, secondLightChanged);
espalexa.addDevice(Device_3_Name, thirdLightChanged);
espalexa.addDevice(Device_4_Name, fourthLightChanged);
espalexa.addDevice(Device_5_Name, fifthLightChanged);
espalexa.addDevice(Device_6_Name, sixthLightChanged);
espalexa.addDevice(Device_7_Name, seventhLightChanged);
espalexa.addDevice(Device_8_Name, eighthLightChanged);
espalexa.begin();
void ir_remote(){
if (irrecv.decode(&results)) {
switch(results.value){
case 0x80BF49B6: relayOnOff(1); break;
case 0x80BFC936: relayOnOff(2); break;
case 0x80BF33CC: relayOnOff(3); break;
case 0x80BF718E: relayOnOff(4); break;
case 0x80BFF10E: relayOnOff(5); break;
case 0x80BF13EC: relayOnOff(6); break;
case 0x80BF51AE: relayOnOff(7); break;
case 0x80BFD12E: relayOnOff(8); break;
default : break;
//Serial.println(results.value, HEX);
irrecv.resume();
irrecv.enableIRIn(); // Start the receiver
pinMode(RelayPin1, OUTPUT);
pinMode(RelayPin2, OUTPUT);
pinMode(RelayPin3, OUTPUT);
pinMode(RelayPin4, OUTPUT);
pinMode(RelayPin5, OUTPUT);
pinMode(RelayPin6, OUTPUT);
pinMode(RelayPin7, OUTPUT);
pinMode(RelayPin8, OUTPUT);
pinMode(wifiLed, OUTPUT);
pinMode(SwitchPin1, INPUT_PULLUP);
pinMode(SwitchPin2, INPUT_PULLUP);
pinMode(SwitchPin3, INPUT_PULLUP);
pinMode(SwitchPin4, INPUT_PULLUP);
pinMode(SwitchPin5, INPUT_PULLUP);
pinMode(SwitchPin6, INPUT_PULLUP);
pinMode(SwitchPin7, INPUT_PULLUP);
pinMode(SwitchPin8, INPUT_PULLUP);
//During Starting all Relays should TURN OFF
config1.setEventHandler(button1Handler);
config2.setEventHandler(button2Handler);
config3.setEventHandler(button3Handler);
config4.setEventHandler(button4Handler);
config5.setEventHandler(button5Handler);
config6.setEventHandler(button6Handler);
config7.setEventHandler(button7Handler);
config8.setEventHandler(button8Handler);
button1.init(SwitchPin1);
button2.init(SwitchPin2);
button3.init(SwitchPin3);
button4.init(SwitchPin4);
button5.init(SwitchPin5);
button6.init(SwitchPin6);
button7.init(SwitchPin7);
button8.init(SwitchPin8);
// Initialise wifi connection
wifiConnected = connectWifi();
if (wifiConnected)
addDevices();
Serial.println("Cannot connect to WiFi. So in Manual Mode");
ir_remote();
if (WiFi.status() != WL_CONNECTED)
//Serial.print("WiFi Not Connected ");
digitalWrite(wifiLed, LOW); //Turn off WiFi LED
//Serial.print("WiFi Connected ");
digitalWrite(wifiLed, HIGH);
//WiFi Control
if (wifiConnected){
espalexa.loop();
delay(1);
else {
wifiConnected = connectWifi(); // Initialise wifi connection
if(wifiConnected){
addDevices();
button1.check();
button2.check();
button3.check();
button4.check();
button5.check();
button6.check();
button7.check();
button8.check();
void button1Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT1");
relayOnOff(1);
void button2Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT2");
relayOnOff(2);
void button3Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT3");
relayOnOff(3);
void button4Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT4");
relayOnOff(4);
void button5Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT5");
relayOnOff(5);
void button6Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT6");
relayOnOff(6);
void button7Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT7");
relayOnOff(7);
void button8Handler(AceButton* button, uint8_t eventType, uint8_t buttonState) {
Serial.println("EVENT8");
relayOnOff(8);
here I need to track the previous state to control home appliances for smart home automation
That would be a step in the right direction
Then deal with the fact that count is an int
Why is it an int ?
Then make your code more sensible by using the StateChangeDetecton principle
What about the pulldown resistor in the input ?
It would be easier to use INPUT_PULLUP in pinMode() and change the program logic and wiring to that the input goes LOW when the button is pressed and you detect that instead of HIGH
It appears to me nobody has pointed out that most/all AVR processors have a BOD (Brown-Out Detect) feature, for exactly this purpose..
Thank you all,
I got solution ![]()
Would you care to share it to help others ?
