Hello!
For a school project i am trying to make a system whit a temperature sensor. The idea is to power a led via a relay when a certain value is above the current temp. The input is done through typing the value in the serial monitor. But it is checking the value only once. And i want it to continuously check if the value is below or above the given value.
Is this possible and if it is how?
I am very new to arduino so if there are ways to improve my code let me know!
here is the code
int sensorPin = A0;
int sensorInput;
double temp;
int reading = 0;
String readString;
int n = 0;
int value;
int relay = A1;
pinMode(A0, INPUT);
pinMode(LED_BUILTIN, OUTPUT);
pinMode(A1,OUTPUT);
sensorInput = analogRead(A0);
temp = (double)sensorInput / 1024; // sensor waarde
temp = temp * 5;
temp = temp - 0.5;
temp = temp *100;
Serial.print("Tempratuur': ");
Serial.println(temp);
Serial:
if (Serial.available()){ // als er iets is getyped in de serial buffer
char c = Serial.read(); // leest 1 karakter van de monitor, opgelsagen als c variabel
if (c >= '0' && c <= '9') { // cijfer tussen 0 en 9 ontvangen ( eigenlijk ASCII48 tot ASCII57)
n = n * 10; // pas als "d" is ontvangen getal vermedigvuldigen met 10
n = n + (c - '0'); // zet "c" om tot decimalen en telt dit op bij n
if (c == 'd') {
if (n > 125) {
Serial.println("moet zijn <= 125 graden Celcius");
value = n; // Nieuw set waarde sensor
Serial.print("n-waarde: ");
Serial.println(n);
if (value > temp){//als de ingetypte waarde hoger is dan de tempratuur LED aan
digitalWrite(LED_BUILTIN, HIGH);
Serial.println(value);
digitalWrite(relay, HIGH);
else {
if (temp > value);
digitalWrite(LED_BUILTIN, LOW);
digitalWrite(relay, LOW);
while (c == 'r') {
n = 0;
Serial.println("Reset");
if(digitalRead(relay) == HIGH);
goto Serial;
