Continues Read inputs and retrieve data from menu choice too
Hello everyone! I've got a problem and i would like your help.
I've got a very simple source code:
void loop()  {
  cData = 0;
  while( cData <= 50 ){
      // read the analog in value:
      tempSensorValue = analogRead(analogInPin0);
      Serial.print("T");
      Serial.print(tempSensorValue);
      Serial.print("-");
      humdSensorValue = analogRead(analogInPin1);
      Serial.print("H");
      Serial.print("-");
      cData++;
And i want a function which retrieve preseted store inforemations from EEPROM like location,an ID etc.
Here is the function:
void __read_EEPROM( )  {
   _addrByte = 0;
  String str;
  int value;
  while( value != 255 )  {
    value = EEPROM.read( _addrByte );
     if( value == 0 ) {
     str += (char)(value);
    _addrByte++;
  Serial.print(str);
This two parts of code are the most important for an interface C# application.
My question:
Ok i'm reading data like temperature and others too, but i want with some way to retrieve this informations from eeprom whenever i want.
without any confuse on my data.
e.g See below:
void loop()  {
  cData = 0;
      Serial.print("T");
      Serial.print("-");
      Serial.print("H");
      Serial.print("-");
      cData++;
/*    if( Serial.available() > 0 )  {
          char choice = (char)Serial.read();
       __read_EEPROM();
     continue;
How to do something like that??
Attention: i'm reading for the 1st second 50 values, This is a continuesly job, because i create realtime graphs in C#, so i can't stop the values retrieving.
If I understand you correctly, you need to implement a protocol, with 2 messages. One message is for Temperature and Humidity, and the other is for the EEPROM memory. Currently you have a defined structure for your Temp+H, by adding T,-,H,- to the message, but you do not have any indication of EEPROM data. I would suggest to add E and - to the serial.print in the read_EEPROM function. Then you can move the if (serial.available) {...} clause to the inside of the while loop. On the computer side, you would need to decide if the message you are receiving is Temp + Humidity (Txx-Hxx-) or an EEPROM read result (Exx-) and process accordingly.
Your loop would look like this (and could be modified to just run forever):
while( cData <= 50 ){  //or change it to while (true)
      Serial.print("T");
      Serial.print("-");
      Serial.print("H");
      Serial.print("-");
      cData++;
       __read_EEPROM();
Yeah i understand!
And thank you very much about it!
