I have a device which is normaly open which closes to create a continuity signal but I cant seem to connect this to the arduino...
I am currently connecting 0v - 5v switches to the arduino and these are working fine so dont understand why this will not work with the same connections...
I am a beginner with all of this so any obvious help would be appreciated!! ;D
So connect one to the arduino pin and the other end to ground.
Make the pin an input and then enable the internal pull up resistor by doing a digital write HIGH to the pin.
