Hello to All,
I am using the attached Code for measuring the capacitance of a capacitor. The results are in floating number like “50.231 pF”. The Sketch is working fine, EXCEPT at low capacitance values (in Picco Farads) its output is varying /changing very fast.
As the measuring process of capacitance is based on the timings (charging/discharging Time of Capacitor/voltage) so I want to avoid Delay in the Sketch.
I have tried to use the Smooting code, which is given at https://www.arduino.cc/en/tutorial/smoothing , but unable to get proper output.
So I need your kind guidance regarding the code, to take the Average/Mean of around last 10 measured values of Serial.print(capacitance, 3); (a Floating Number) to get a smooth output Continuously.
Please guide me, how to take average of last floating values of ‘say last 10 or 20 serial print results’ i.e. Serial.print(capacitance, 3).
Thanks in Advance,
const int OUT_PIN = A2;
const int IN_PIN = A0;
const float IN_STRAY_CAP_TO_GND = 24.48;
const float IN_CAP_TO_GND = IN_STRAY_CAP_TO_GND;
const float R_PULLUP = 34.8;
const int MAX_ADC_VALUE = 1023;
pinMode(OUT_PIN, OUTPUT);
pinMode(IN_PIN, OUTPUT);
pinMode(IN_PIN, INPUT);
digitalWrite(OUT_PIN, HIGH);
int val = analogRead(IN_PIN);
digitalWrite(OUT_PIN, LOW);
if (val < 1000)
float capacitance = (float)val * IN_CAP_TO_GND / (float)(MAX_ADC_VALUE - val);
Serial.print(F("Capacitance Value = "));
Serial.print(F(" pF ("));
Serial.print(val);
Serial.println(F(") "));
delay(1);
pinMode(OUT_PIN, INPUT_PULLUP);
unsigned long u1 = micros();
unsigned long t;
int digVal;
do
digVal = digitalRead(OUT_PIN);
unsigned long u2 = micros();
t = u2 > u1 ? u2 - u1 : u1 - u2;
} while ((digVal < 1) && (t < 400000L));
pinMode(OUT_PIN, INPUT);
val = analogRead(OUT_PIN);
digitalWrite(IN_PIN, HIGH);
int dischargeTime = (int)(t / 1000L) * 5;
delay(dischargeTime);
digitalWrite(IN_PIN, LOW);
float capacitance = -(float)t / R_PULLUP / log(1.0 - (float)val / (float)MAX_ADC_VALUE);
if (capacitance > 1000.0)
Serial.print(capacitance / 1000.0, 2);
Serial.print(F(" uF"));
Serial.print(capacitance, 2);
Serial.print(F(" nF"));
Serial.print(F(" ("));
Serial.print(digVal == 1 ? F("Normal") : F("HighVal"));
Serial.print(F(", t= "));
Serial.print(t);
Serial.print(F(" us, ADC= "));
Serial.print(val);
Serial.println(F(")"));
while (millis() % 1000 != 0)
