Continuous Motor & PIR Sensor
Hello Everyone,
I am trying to research how to get my project working and I am having the hardest time following everything. I am trying to activate a continuous motor when a PIR sensor detects movement. I know that it is impossible to do a specific angle. I am trying to trigger the motor for 15seconds and then have it stop until the PIR sensor is triggered again. I followed a feed on here that used a servo and when I plug in the code my motor continuously runs and doesn’t shut off.
Here is the code that I used:
/* This code sweeps a servo from 0 degrees to 180 when the PIR sensor detects motion.
Special thanks goes to the author of the PIR sensor code, whose code helped tremendously
in the making of this code and Instructable.
author of PIR sensor code: Kristian Gohlke / krigoo () gmail () com / http://krx.at
#include <Servo.h>
Servo myservo; //creates a servo object
//a maximum of eight servo objects can be created
int pos = 0; //variable to store servo position
//amount of time we give the sensor to calibrate(10-60 secs according to the datasheet)
int calibrationTime = 30;
//the time when the sensor outputs a low impulse
long unsigned int lowIn;
//the amount of milliseconds the sensor has to be low
//before we assume all motion has stopped
long unsigned int pause = 5000;
boolean lockLow = true;
boolean takeLowTime;
int pirPin = 12; //digital pin connected to the PIR’s output
int pirPos = 13; //connects to the PIR’s 5V pin
void setup(){
myservo.attach(4); //attaches servo to pin 4
Serial.begin(9600); //begins serial communication
pinMode(pirPin, INPUT);
pinMode(pirPos, OUTPUT);
digitalWrite(pirPos, HIGH);
//give the sensor time to calibrate
Serial.println(“calibrating sensor “);
for(int i = 0; i < calibrationTime; i++){
Serial.print(calibrationTime - i);
Serial.print(”-”);
Serial.println(“done”);
//while making this Instructable, I had some issues with the PIR’s output
//going HIGH immediately after calibrating
//this waits until the PIR’s output is low before ending setup
while (digitalRead(pirPin) == HIGH) {
Serial.print(".");
Serial.print(“SENSOR ACTIVE”);
void loop(){
if(digitalRead(pirPin) == HIGH){ //if the PIR output is HIGH, turn servo
/*turns servo from 0 to 180 degrees and back
it does this by increasing the variable “pos” by 1 every 5 milliseconds until it hits 180
and setting the servo’s position in degrees to “pos” every 5 milliseconds
it then does it in reverse to have it go back
to learn more about this, google “for loops”
to change the amount of degrees the servo turns, change the number 180 to the number of degrees you want it to turn
for(pos = 0; pos < 180; pos += 1) //goes from 0 to 180 degrees
{ //in steps of one degree
myservo.write(pos); //tells servo to go to position in variable “pos”
delay(5); //waits for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) //goes from 180 to 0 degrees
myservo.write(pos); //to make the servo go faster, decrease the time in delays for
delay(5); //to make it go slower, increase the number.
if(lockLow){
//makes sure we wait for a transition to LOW before further output is made
lockLow = false;
Serial.println("—");
Serial.print(“motion detected at “);
Serial.print(millis()/1000);
Serial.println(” sec”);
delay(50);
takeLowTime = true;
if(digitalRead(pirPin) == LOW){
if(takeLowTime){
lowIn = millis(); //save the time of the transition from HIGH to LOW
takeLowTime = false; //make sure this is only done at the start of a LOW phase
//if the sensor is low for more than the given pause,
//we can assume the motion has stopped
if(!lockLow && millis() - lowIn > pause){
//makes sure this block of code is only executed again after
//a new motion sequence has been detected
lockLow = true;
Serial.print(“motion ended at “); //output
Serial.print((millis() - pause)/1000);
delay(50);
O.k. if you're using a continuous rotation (not really a servo any more) servo then that code is useless. Generally write(90) or something value close will stop the rotation, write(180) will go full speed one way and write(0) will go full speed in reverse.
And you should be using State Change techniques with the PIR so when the PIR GOES high (not just it IS HIGH), write(180) to the motor. 15 second later write(90) to stop the motor whether the PIR is HIGH or LOW. See the StateChangeDetection example in the IDE.
Steve
I know this is probably a lot to ask but do you think you could help explain how to do this? I am REALLY new to this.
slipstick:
Steve
Do you think you could help explain how to do this?
I thought I was helping. But if you mean you want someone to write all the code for then sorry that's not what I do.
Have you looked at the StateChangeDetection example I suggested? That would be a good start so give it a try.
Then if you have a potentiometer you can try the Knob example from the Servo library to check exactly what the various write() command values will do.
Steve
