Continuous reporting Temperature and Humidity sensor
I want to continuously monitor the temp and humidity of a room in Home Assistant.
I was looking at si7021 on Amazon, and there appears to be a “sensor” which looks like a traditional sensor with a jack plug, and a breakout board.
Is the breakout board the actual sensor itself? It doesn’t look like a sensor.
Here’s the datasheet for the sensor that’s on that board. Si7021 datasheet
the square tab with the white face is the sensor
see also BMP280 pressure temp humidity sensor:
BMP280-Atmospheric-Pressure-Sensor-Temperature-Humidity-Sensor-BreakoutArduino
and MCP98908 temp sensor:
High-Accuracy-I2C-IIC-Temperature-Sensor-Module-MCP9808-Breakout-Board-G0S5/173648846015
