I'm new to the arduino and was unsure of what parameters you can control when programming a continuous rotation servo. I am aware you can control the speed at which it spins but that is all i know. Are you able to control the duration the servo runs for as well? And if so what would be the command code for this? Thanks in advance.
bbqbrett:
You can control speed and direction using the "Servo" library, then directly control duration by telling it when to stop.
ie
myServo.write(135); // Will start it turning anti-clockwise at about half speed.
delay(250); // Will wait for 250mS
myServo.write(90); // Will stop the servo
Note that this is just a simple example using 'delay()'. In reality, it's better to use 'millis()'-based timing, as shown in the "BlinkWithoutDelay" example provided with the IDE.
Thanks OldSteve. Forgive my ignorance I don't know what IDE stands for, so there is a command code i can put in that just tells the device to run for a given time as opposed to telling it to delay for a time then making it stop. Does anyone know what that command would be?
bbqbrett:
IDE is Integrated Development Environment
No, there isn't such a thing. I told you how it's done.
Edit: I also told you there's an alternative to using 'delay()'.
