Continuous rotation servo doesn't work when i use the attach() function
Hi, i have been having a problem with using the attach() function from the servo library in Arduino Uno. Last time i used my servos they where working fine but now each time i use the attach() on them they just start rotating even if i don't write to the servo. I have already tried with various continuous rotation servos and they all present the same problem.
Code:
#include<Servo.h>
Servo blue;
void setup(){
  blue.attach(6);
void loop(){
I really don't understand why this happens, I would really appreciate the help, thanks.
When the servo is attached, the pulses for the servo motor is started. I think the servo motor will go to a central position. It is not possible to activate a servo motor and keep the current position.
The default pulse width sent after an attach is 1500us and is only nominally the 0 speed value for a continuous rotation servo.
I've never used a continuous one, but I gather that they can vary in the value that actually keeps them still. I believe some have an adjusting screw that you can turn until it stops. Alternatively, experiment with servo.write()'s degrees or servo.writeMicrosecond()'s microseconds until you find a value at which motion stops.
edit... these two lines in Servo.h are important:
#define DEFAULT_PULSE_WIDTH  1500     // default pulse width when servo is attached
#define REFRESH_INTERVAL    20000     // minumim time to refresh servos in microseconds
If you know the pulse width that makes the servo stop moving you can use
servo.writeMicroseconds(stopValue);
before
servo.attach();
...R
Servo test code you can use to determine the current stopped us command position for the servo.
// zoomkat 3-28-14 serial servo incremental test code
// using serial monitor type a character (s to increase or a
// to decrease) and enter to change servo position
// (two hands required, one for letter entry and one for enter key)
// use strings like 90x or 1500x for new servo position
// for IDE 1.0.5 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
#include<Servo.h>
String readString;
Servo myservo;
int pos=1500; //~neutral value for continous rotation servo
//int pos=90;
  myservo.attach(7, 400, 2600); //servo control pin, and range if desired
  Serial.println("serial servo incremental test code");
  Serial.println("type a character (s to increase or a to decrease)");
  Serial.println("and enter to change servo position");
  Serial.println("use strings like 90x or 1500x for new servo position");
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    if(readString.indexOf('x') >0) {
      pos = readString.toInt();
    if(readString =="a"){
      (pos=pos-1); //use larger numbers for larger increments
      if(pos<0) (pos=0); //prevent negative number
    if (readString =="s"){
      (pos=pos+1);
    if(pos >= 400) //determine servo write method
      Serial.println(pos);
      myservo.writeMicroseconds(pos);
      myservo.write(pos);
  readString=""; //empty for next input
