Continuous serial read
I’m currently combining tutorials on motors with serial comms. Im trying to read the the value of the motorPin and println to serial. This seems to be working except for the fact that the value is only read at the end of the loop cycle. How can my code read the value and print to serial continuously as it changes rather than just at the end of the loop?
Thanks
//Define Pins
int motorPin = 9;
  //Set the PWM Motor pin as an output
  pinMode(motorPin, OUTPUT);
   //Increase Motor Speed from 0 -> 255
  for (int i=0; i<=255; i++)
    analogWrite(motorPin, i);
    delay(10);
  delay(0); //Hold it!
  //Decrease Motor Speed from 255 -> 0
  for(int i=255; i>=0; i--)
    delay(10);
  delay(0); //Hold it! ;
  //print value of motor to serial
  int val = analogRead(motorPin) ;
  while (Serial.available() ==1) ;
  Serial.println(val) ;
  delay(50) ;
 Serial.flush();
    Serial.println (analogRead (motorPin));
    delay(10);
Or, have a look at the Blink Without Delay example to see how to do it without delay.
(Should that be "Or, have a look at the Blink Without Delay example to see how to do it, without delay." ? Must ask Lynne Truss)
Look at the "Blink Without Delay" for an example of how to do scheduled things (like increasing and decreasing motor speed every 10 miliseconds) without putting in delays. Then you can do serial i/o at whatever interval you like while still making steady changes to the PWM output.
Note: analogRead() only works on the Analog Input pins, not the PWM Output pins. If you want to send the value you just sent to the PWM pin you should save that value:
if ('time to increase the motor speed)
    speed++;
    analogWrite(motorPin, speed);
if (time to send the speed value)
    Serial.println(speed);
oops - missed that biggy!
Lots of logical errors and unneeded statements. However the biggest problem is that you are trying to do a analogRead() on pin 9 ? There are only 6 analog input pins (0-5) and it's not clear what you might have wired to a analog input pin, if anything? Your pin 9 is being used as a PWM output pin to power a motor at variable speed. Reading back that value makes little sense as it's only a digital on/off signal of variable duty cycle that wouldn't signify anything even if you did a digitalRead of that pin.
So before even trying to clean up your sketch, what are you trying to read back in your analogRead() statement? Do you really have an external analog voltage avalible to read into your sketch?
Lefty
thank you :)
managed to get what I was looking and clean it up a little, gonna try the suggestions regarding avoiding the use of delays. Cheers all, really helpful!
//Define Pins
int motorPin = 9 ;
int i ;
    Serial.println(i) ;
    delay(10) ;
  delay(1000); //Hold it!
    analogWrite(motorPin, i) ;
    Serial.println(i) ;
    delay(10) ;
  delay(1000); //Hold it! ;
 analogRead(i) ;
You don't have 256 analogue inputs.
haha literately just took that line out too, I'm starting to get it a little bit, sure you have realised this is all pretty new to me. I cant code at all so i'm just ripping tutorials apart and trying to see how it all ticks.
