continuous servo does not stop after getting input from photoresistor
Hi, I'm trying to stop my continuous servo from rotating.
I've got a SM-S4315R servo hooked up to the arduino sensor shield 4.0.
I've got a usb cable and 9 volt battery hooked up to the arduino uno r3.
I know for continuous servos if I input a value of 90 it should stop.
I tried this on its own and it worked.
However, after I used the if and elseif statements the continuous servo keeps spinning even though my photosensor values are above requirements to make it stop rotating.
Is there something wrong with the way my if and elseif statements are structured?
Thanks
#include <Servo.h>
Servo myservo;  //continuous rotation servo SM-4315R
int photosensorpin = 0;
  Serial.begin(9600);  //Begin serial communcation
  myservo.attach(9);
  Serial.println(analogRead(photosensorpin));
  if (analogRead(photosensorpin > 15))
  myservo.write(90);
  else if (analogRead(photosensorpin < 15))
  myservo.write(87);
photosensor.rotate.continuous.servo.ino (396 Bytes)
  if (analogRead(photosensorpin > 15))Check where you have the braces for the analogRead()
A tip. Whenever you have problems with testing values then print them to see what you are testing.
Also read the analog pin once and assign that value to a variable.
Then test the variable. That way you know that each test is testing the same value.
Tom... :slight_smile:
Hi I'm checking the braces you mentioned but don't know what is wrong.
The only thing I can think of is changing the variable and just using the analog pin value in the code but I don't think that will do anything.
I am using the serial monitor to monitor my values.
If a place a dark black object over the photoresistor my values are in the low 10s and won't exceed 15.
If I leave it alone the values just spike up in the hundreds but the motor keeps spinning.
I've attached a picture of my setup.
I just turned my resistor the other way to determine if that is the cause of the problem.
Pay careful attention to the pin you are reading from. It is NOT the pin who's number is stored in photosensorpin.
Hi thanks it seems like in my photo I'm reading from pin 1 but I am reading from pin 0. Checked it. Based on other examples online the orientation of my resistor appears to be right.
I saw the analogread examples on the arduino site and have modified my code.
So the code works initially when my values are > 30
but after I cover the photosensor up and uncover again it continues to spin slowly.
#include <Servo.h>
int val = 0;
  myservo.attach(9);  // servo attached to pin 9
  Serial.println(val);
  if (val = analogRead(0) > 30)  // read values from analog pin 0 if > 30 servo motor will stop rotating
  myservo.write(90);
  else if (val = analogRead(0) < 30)  // read values from analog pin 0 if < 30 servo motor will continue rotating
  myservo.write(87);
Well I've simplified my code and got it to work. Thanks everybody for all the help!
It's weird sometimes it continues to spin even though the photoresistor is not covered.
What is even more weird is that when I removed power to the photoresistor and feedback to the analog pin it kept on spinning.
#include <Servo.h>
// goal of code is to have a continuous servo rotate until a photoresistor sees light then it will stop rotating.
// for a continuous servo: 0 = full speed rotation in one direction, 180 = full speed in other direction, 90 = no movement
  Serial.begin(9600);  //Begin serial communication
  Serial.println(analogRead(0));
  if (analogRead(0) > 30)  // read values from analog pin 0 if > 30 servo motor will stop rotating
  myservo.write(90);
  else   // for all values less than 30 servo will move
  myservo.write(87);
Below is some servo test code you can use to find the servo's microsecond command position for stopping, which usually has better resolution than writing degrees. If the servo keeps drifting, you might use the servo attach/detach function.
// zoomkat 3-28-14 serial servo incremental test code
// using serial monitor type a character (s to increase or a
// to decrease) and enter to change servo position
// (two hands required, one for letter entry and one for enter key)
// use strings like 90x or 1500x for new servo position
// for IDE 1.0.5 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
#include<Servo.h>
String readString;
Servo myservo;
int pos=1500; //~neutral value for continous rotation servo
//int pos=90;
  myservo.attach(7, 400, 2600); //servo control pin, and range if desired
  Serial.println("serial servo incremental test code");
  Serial.println("type a character (s to increase or a to decrease)");
  Serial.println("and enter to change servo position");
  Serial.println("use strings like 90x or 1500x for new servo position");
  while (Serial.available()) {
    char c = Serial.read();  //gets one byte from serial buffer
    readString += c; //makes the string readString
    delay(2);  //slow looping to allow buffer to fill with next character
  if (readString.length() >0) {
    if(readString.indexOf('x') >0) {
      pos = readString.toInt();
    if(readString =="a"){
      (pos=pos-1); //use larger numbers for larger increments
      if(pos<0) (pos=0); //prevent negative number
    if (readString =="s"){
      (pos=pos+1);
    if(pos >= 400) //determine servo write method
      Serial.println(pos);
      myservo.writeMicroseconds(pos);
      myservo.write(pos);
  readString=""; //empty for next input
The value that you print and the value that you use are not the same value. That makes NO sense.
I see you using the 9V "battery" , its not going to help you, it is too small.
Tom.... :slight_smile:
PS zoomkat your diagram please..
Hi all thanks for all the advice.
I found out what was the problem.
It was a hardware issue.
The code works great.
I had to fine tune the rest-point adjustment potentiometer on the continuous servo.
I'm lucky I bought two and the other motor worked fine for a while.
So I was able to narrow down the issue this way.
Now I'm going to fine tune both servo motors so that they don't spin while the photoresistor is uncovered.
