Hi all, I have been working on this for quite a while, and wondering what is going on. I am taking a robotics course online through my school and have been given two motors for the final project (they are for the wheels). Unfortunately it doesn't want to work. I have a program that I had to write, just to get a feel for the servo motors. However I write the program, and nothing happens! So I check the connections, everything seems good, Brown -GND Red - 5V Orange -Digital Pin 9. So then I check the code, I tried Digital and Analog Here is the code, tried multiple different code patterns:
#include <Servo.h>
//Includes the Servo.h file for easier programming.
Servo myServo; //Setting up the servo name.
int servoPin = 9;//Setting the servo pin, I've tried digital AND analog.
myServo.attach(servoPin);//Telling arduino that myServo uses servoPin
myServo.write(90);//
myServo.write(0);
By now you may be thinking, so you've only told me what you've tried, what actually happened!?! What happens:
Upload sketch to Arduino Uno
It compiles fine
It uploads and... sometimes it spins on for a second, sometimes nothing.
It just doesn't do anything.
Things I've tried that sorta work:
same as steps 1-4 above
I disconnect any 1 cord that is plugged in to either the Arduino Uno or the Continuous Servo.
I connect then disconnect the plugged in cord over and over again
By doing step 3 over and over again it makes the Continuous Servo crudely move and doesn't work very well at all.
Things that work but not in the way I want them to:
For some reason the "Sweep" example code in File->Examples->Servo->Sweep Works great.
The Continuous Servos I have tried:
TowerProtm Micro Servo 9G SG90
Moxietm Mox M9
Please help.
Servo test code that might be of use testing your servo. Note that powering a servo from an arduino often causes issues.
// zoomkat 3-28-14 serial servo incremental test code
// using serial monitor type a character (s to increase or a
// to decrease) and enter to change servo position
// use strings like 90x or 1500x for new servo position
// for IDE 1.0.5 and later
// Powering a servo from the arduino usually *DOES NOT WORK*.
#include<Servo.h>
String readString;
Servo myservo;
int pos=1500; //~neutral value for continous rotation servo
//int pos=90;
myservo.attach(7, 400, 2600); //servo control pin, and range if desired
Serial.println("serial servo incremental test code");
Serial.println("type a character (s to increase or a to decrease)");
Serial.println("and enter to change servo position");
Serial.println("use strings like 90x or 1500x for new servo position");
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the string readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
if(readString.indexOf('x') >0) {
pos = readString.toInt();
if(readString =="a"){
(pos=pos-1); //use larger numbers for larger increments
if(pos<0) (pos=0); //prevent negative number
if (readString =="s"){
(pos=pos+1);
if(pos >= 400) //determine servo write method
Serial.println(pos);
myservo.writeMicroseconds(pos);
myservo.write(pos);
readString=""; //empty for next input
Thanks Zoomkat,
I uploaded it(A bit tricky to understand)
put in some random numbers, doesn't work. The odd number turns it for a second then it turns off. Powering a servo from an Arduino usually does not work? What might the side effects be? Will try with a battery, which battery would work ?(BTW I'm a n00b to Arduino, robotics etc.).
All help appreciated.
If you power a servo from the Arduino 5v pin and it draws too much current (so the Arduino 5v is no longer 5v) the Arduino can behave very strangely - perhaps resetting over and over - and may also be damaged.
Use a separate 5v or 6v power supply with about 1 amp of current for each servo. Connect the servo power supply ground to the Arduino ground. 4 AA NiMh cells would work fine.
Hi, An easy way to supply separate power to servos is to use a Sensor Shield version that has the ability to SEPARATE the power to the 3-pin servo connectors from the Arduino power. Example HERE:
Robin2:
Hi Robin2,
4 AA NiMh cells, so basically 4 AA rechargeable battery's? How would I go about setting this up? Could I just link all four battery's together, attach the power to the plus end of the battery, and the ground to the negative end of the battery's? How could I do this easily without purchasing anything.
Hi all,
Thanks for all your help, I found out some of the kits had by accident normal servos rather than continuous. I'm being sent two continuous servos.
Over and out, Hcorion
