Hello i was wondering if i had a continuous rotation servo if i could set a range of motion for it, say 0-360 degrees as an example. I am not sure how the coding for it would work.
Thank You,
Easton
Thank You,
Easton
You could do it with some sort of limit switch or encoder, either mechanical or optical.
But i cannot define it within the code?
Assuming you're talking about a modded R/C servo, and not a true continuous rotation servo, no, there's nothing you can do purely in code.
The device has no feedback mechanism, so has no idea "where" it is.
That's why you need a limit switch or encoder.
