I'm having a problem with my continuous servo's. They move irregular and not smooth, especially at lower speeds.
I apply an external powersource of 6V and use simple code with writeMicroseconds to test it. However, it seems that the servo is accelerating and at a certain point it jumps to a lower speed.
Video of problem explains enough I think: - YouTube
It's not the problem of the servo being broke, as it happens with multiple.
Hope somebody knows what the problem could be.
Thanks!
The myservo1.writeMicroseconds(1520); sets the stop state for the servo and you will have to find the exact microsecond value for each specific servo you use for it's exact stop value. It's nominally 1500 usec but will vary a little + or - for each servo.
Servo test code you might try to see if the speed issue occurrs with this code.
//zoomkat 11-22-12 simple delimited ',' string parce
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod; // create servo object to control a servo
//myservoa.writeMicroseconds(1500); //set initial servo position if desired
myservoa.attach(6); //the pin for the servoa control
myservob.attach(7); //the pin for the servob control
myservoc.attach(8); //the pin for the servoc control
myservod.attach(9); //the pin for the servod control
Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
//expect single strings like 700a, or 1500c, or 2000d,
//or like 30c, or 90a, or 180d,
//or 30c,180b,70a,120d,
if (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
if (c == ',') {
if (readString.length() >1) {
Serial.println(readString); //prints string to serial port out
int n = readString.toInt(); //convert readString into a number
// auto select appropriate value, copied from someone elses code.
if(n >= 500)
Serial.print("writing Microseconds: ");
Serial.println(n);
if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
Serial.print("writing Angle: ");
Serial.println(n);
if(readString.indexOf('a') >0) myservoa.write(n);
if(readString.indexOf('b') >0) myservob.write(n);
if(readString.indexOf('c') >0) myservoc.write(n);
if(readString.indexOf('d') >0) myservod.write(n);
readString=""; //clears variable for new input
else {
readString += c; //makes the string readString
@Lefty, I am well aware of this fact that each servo has it's own stop value, but this was not my problem. My problem occures when I want to drive my servo slowly, so with a value close to the stop value. When I do this it starts of slow but it speeds up which it shouldn't suppose to do. The speed is irregular at almost every speed except for the maximum speed. It's strange, it slows down and speeds up, slows down and speeds up.
@zoomkat, Thanks for the help but the code you gave didn't work.
I figured that it might have to do something with the servo circuit itself. I think the controlling mechanism malfunctioning. It almost seems like the internal capacitor of the servo are getting 'filled' which give the acceleration during the movement. What I did was 'fooling' the servo by the following code:
This resulted into a smooth, slow and steady movement BUT now the servo get's hot after a moment. I think due to the quick sequence of writeMicrosecond commands in the void loop the pulsewidth is being distorted, which causes the pulsewidt to be larger than 2.4ms (basically the limit for every servo).
The trick with writing the microSeconds in sequence worked.
I also have the feeling that the heat is less when putting the sequence of commands in a for loop
This workaround works good enough for me.
In the end it was a simple solution/trick, but I couldn't find anybody with similar problems.
