I'm not sure what I did either. I did have two Arduino IDE instances open though.
PS C:\Users\piter\AppData\Local\Programs\Arduino IDE> & ".\Arduino IDE"
Starting backend process. PID: 12716
Using browser-only version of superagent in non-browser environment
Configuring to accept webviews on '^.+\.webview\..+$' hostname.
root INFO Configuration directory URI: 'file:///c%3A/Users/piter/.theia'
root INFO Backend Object.initialize: 5.3 ms [Finished 1.447 s after backend start]
root INFO Backend Object.configure: 4.0 ms [Finished 1.447 s after backend start]
root INFO Backend MessagingContribution.onStart: 1.8 ms [Finished 1.447 s after backend start]
root INFO Backend OSBackendApplicationContribution.configure: 0.5 ms [Finished 1.502 s after backend start]
root INFO Backend DefaultWorkspaceServer.onStart: 0.4 ms [Finished 1.502 s after backend start]
root INFO Backend LocalizationBackendContribution.configure: 0.3 ms [Finished 1.503 s after backend start]
root WARN Backend LocalizationBackendContribution.initialize took longer than the expected maximum 50 milliseconds: 55.3 ms [Finished 1.503 s after backend start]
root INFO Backend TaskBackendApplicationContribution.onStart: 0.4 ms [Finished 1.503 s after backend start]
root INFO Backend ElectronTokenBackendContribution.configure: 1.3 ms [Finished 1.505 s after backend start]
root INFO Backend PluginDeployerContribution.initialize: 0.5 ms [Finished 1.505 s after backend start]
root INFO Backend ConfigServiceImpl.onStart: 0.9 ms [Finished 1.505 s after backend start]
root INFO Backend WebviewBackendSecurityWarnings.initialize: 0.4 ms [Finished 1.507 s after backend start]
root INFO Backend ArduinoDaemonImpl.onStart: 1.1 ms [Finished 1.507 s after backend start]
root INFO Backend NodeFileUploadService.configure: 2.2 ms [Finished 1.508 s after backend start]
daemon INFO Starting daemon from C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\arduino-ide-extension\build\arduino-cli.exe...
discovery-log INFO start
discovery-log INFO start new deferred
root INFO Backend BoardDiscovery.onStart: 0.9 ms [Finished 1.509 s after backend start]
root INFO Backend FileDownloadEndpoint.configure: 0.6 ms [Finished 1.509 s after backend start]
root INFO Backend AuthenticationServiceImpl.onStart: 0.5 ms [Finished 1.511 s after backend start]
root INFO Backend PluginApiContribution.configure: 0.6 ms [Finished 1.511 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.5 ms [Finished 1.512 s after backend start]
root INFO Backend HostedPluginReader.configure: 0.1 ms [Finished 1.513 s after backend start]
root INFO Backend PlotterBackendContribution.configure: 1.1 ms [Finished 1.514 s after backend start]
root INFO Theia app listening on http://localhost:1459.
root INFO Finished starting backend application: 6.3 ms [Finished 1.518 s after backend start]
root WARN The local plugin referenced by local-dir:/c%3A/Users/piter/.arduinoIDE/plugins does not exist.
root WARN The local plugin referenced by local-dir:/c%3A/Users/piter/.arduinoIDE/extensions does not exist.
root WARN The local plugin referenced by local-dir:C:\Users\piter\.arduinoProIDE\plugins does not exist.
Restoring workspace roots: e:\Projects\Electronics\Arduino sketches\Bimetallic switch tester_phaseCompletion_detecting
isTempSketch: false. Input was e:\Projects\Electronics\Arduino sketches\Bimetallic switch tester_phaseCompletion_detecting
root INFO PluginTheiaDirectoryHandler: accepting plugin with path
root INFO Resolved "cortex-debug" to a VS Code extension "cortex-debug@0.3.10" with engines:
root INFO Resolved "vscode-arduino-tools" to a VS Code extension "vscode-arduino-tools@0.0.2-beta.5" with engines:
root INFO Resolved "vscode-builtin-cpp" to a VS Code extension "cpp@1.52.1" with engines:
root INFO Resolved "vscode-builtin-json" to a VS Code extension "json@1.46.1" with engines:
root INFO Resolved "vscode-builtin-json-language-features" to a VS Code extension "json-language-features@1.46.1" with engines:
root INFO Resolved "vscode-language-pack-cs" to a VS Code extension "vscode-language-pack-cs@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-de" to a VS Code extension "vscode-language-pack-de@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-es" to a VS Code extension "vscode-language-pack-es@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-fr" to a VS Code extension "vscode-language-pack-fr@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-it" to a VS Code extension "vscode-language-pack-it@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-ja" to a VS Code extension "vscode-language-pack-ja@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-nl" to a VS Code extension "vscode-language-pack-nl@1.48.3" with engines:
root INFO Resolved "vscode-language-pack-pt-BR" to a VS Code extension "vscode-language-pack-pt-BR@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-ru" to a VS Code extension "vscode-language-pack-ru@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-tr" to a VS Code extension "vscode-language-pack-tr@1.69.0" with engines:
root INFO Resolved "vscode-language-pack-zh-hans" to a VS Code extension "vscode-language-pack-zh-hans@1.69.0" with engines:
root INFO ---- DURATION: loadCliConfig took 71.034 ms. Args: [] ----
root INFO Resolve plugins list: 96.2 ms [Finished 1.606 s after backend start]
root INFO Deployed backend plugin "cortex-debug@0.3.10" from "C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\plugins\cortex-debug\extension\dist\extension": 5.9 ms [Finished 1.612 s after backend start]
root INFO Deployed backend plugin "vscode-arduino-tools@0.0.2-beta.5" from "C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle": 4.8 ms [Finished 1.617 s after backend start]
root INFO Deployed backend plugin "cpp@1.52.1" from "C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-cpp\extension": 12.5 ms [Finished 1.629 s after backend start]
root INFO Deployed backend plugin "json@1.46.1" from "C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json\extension": 2.8 ms [Finished 1.632 s after backend start]
root INFO Deployed backend plugin "json-language-features@1.46.1" from "C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain": 1.0 ms [Finished 1.633 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-cs@1.69.0" from "C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-cs\extension": 133.2 ms [Finished 1.767 s after backend start]
daemon INFO {"level":"info","msg":"Using config file: c:\\Users\\piter\\.arduinoIDE\\arduino-cli.yaml","time":"2022-09-25T22:22:51+01:00"}
{"level":"info","msg":"arduino-cli.exe version 0.27.1","time":"2022-09-25T22:22:51+01:00"}
{"level":"info","msg":"Executing `arduino-cli daemon`","time":"2022-09-25T22:22:51+01:00"}
{"IP":"127.0.0.1","Port":"1460"}
daemon INFO Daemon is running.
root INFO Deployed backend plugin "vscode-language-pack-de@1.69.0" from "C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-de\extension": 141.1 ms [Finished 1.908 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-es@1.69.0" from "C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-es\extension": 140.6 ms [Finished 2.048 s after backend start]
daemon INFO {"level":"info","msg":"Loading hardware from: c:\\Users\\piter\\AppData\\Local\\Arduino15\\packages","time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Loading package LGT8fx Boards from: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\LGT8fx Boards\\hardware","time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Adding monitor tool","protocol":"serial","time":"2022-09-25T22:22:52+01:00","tool":"builtin:serial-monitor"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"LGT8fx Boards:avr","Installed":"1.0.5","Latest":"1.0.5","Name":"Logic Green Arduino AVR Compatible Boards"},"time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Loading package STMicroelectronics from: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\hardware","time":"2022-09-25T22:22:52+01:00"}
{"error":"opening signature file: open C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\hardware\\stm32\\2.3.0\\installed.json.sig: The system cannot find the file specified.","index":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\hardware\\stm32\\2.3.0\\installed.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\hardware\\stm32\\2.3.0\\installed.json.sig","time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"STMicroelectronics:stm32","Installed":"2.3.0","Latest":"2.3.0","Name":"STM32 MCU based boards"},"time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\tools","time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\tools","time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:22:52+01:00","tool":{"version":"5.7.0","systems":[{"os":"i686-mingw32","Resource":{"URL":"https://github.com/stm32duino/ArduinoModule-CMSIS/releases/download/5.7.0/CMSIS-5.7.0.tar.bz2","ArchiveFileName":"CMSIS-5.7.0.tar.bz2","Checksum":"SHA-256:0b04b0f214e483bcc360cda985cddc0de8031714019ceabcda4770d510b82bfe","Size":26151901,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/stm32duino/ArduinoModule-CMSIS/releases/download/5.7.0/CMSIS-5.7.0.tar.bz2","ArchiveFileName":"CMSIS-5.7.0.tar.bz2","Checksum":"SHA-256:0b04b0f214e483bcc360cda985cddc0de8031714019ceabcda4770d510b82bfe","Size":26151901,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/stm32duino/ArduinoModule-CMSIS/releases/download/5.7.0/CMSIS-5.7.0.tar.bz2","ArchiveFileName":"CMSIS-5.7.0.tar.bz2","Checksum":"SHA-256:0b04b0f214e483bcc360cda985cddc0de8031714019ceabcda4770d510b82bfe","Size":26151901,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/stm32duino/ArduinoModule-CMSIS/releases/download/5.7.0/CMSIS-5.7.0.tar.bz2","ArchiveFileName":"CMSIS-5.7.0.tar.bz2","Checksum":"SHA-256:0b04b0f214e483bcc360cda985cddc0de8031714019ceabcda4770d510b82bfe","Size":26151901,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/stm32duino/ArduinoModule-CMSIS/releases/download/5.7.0/CMSIS-5.7.0.tar.bz2","ArchiveFileName":"CMSIS-5.7.0.tar.bz2","Checksum":"SHA-256:0b04b0f214e483bcc360cda985cddc0de8031714019ceabcda4770d510b82bfe","Size":26151901,"CachePath":"packages"}},{"os":"all","Resource":{"URL":"https://github.com/stm32duino/ArduinoModule-CMSIS/releases/download/5.7.0/CMSIS-5.7.0.tar.bz2","ArchiveFileName":"CMSIS-5.7.0.tar.bz2","Checksum":"SHA-256:0b04b0f214e483bcc360cda985cddc0de8031714019ceabcda4770d510b82bfe","Size":26151901,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:22:52+01:00","tool":{"version":"2.1.1","systems":[{"os":"i686-mingw32","Resource":{"URL":"https://github.com/stm32duino/Arduino_Tools/releases/download/2.1.1/STM32Tools-2.1.1-windows.tar.bz2","ArchiveFileName":"STM32Tools-2.1.1-windows.tar.bz2","Checksum":"SHA-256:385f1495a70613ca6771c0f824e420f44e27b1433b0b449aaade1dde63b35e68","Size":2587832,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/stm32duino/Arduino_Tools/releases/download/2.1.1/STM32Tools-2.1.1-mac.tar.bz2","ArchiveFileName":"STM32Tools-2.1.1-mac.tar.bz2","Checksum":"SHA-256:417bc75ebf19060083e29cf65f7a9f71a6903b7fd158c154057ed723c5e847a1","Size":486815,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/stm32duino/Arduino_Tools/releases/download/2.1.1/STM32Tools-2.1.1-linux.tar.bz2","ArchiveFileName":"STM32Tools-2.1.1-linux.tar.bz2","Checksum":"SHA-256:35ecc3914e8a0a45de229111cc45b8cb39a8e0a8c66313562fd51977a7ab3dee","Size":480360,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/stm32duino/Arduino_Tools/releases/download/2.1.1/STM32Tools-2.1.1-linux.tar.bz2","ArchiveFileName":"STM32Tools-2.1.1-linux.tar.bz2","Checksum":"SHA-256:35ecc3914e8a0a45de229111cc45b8cb39a8e0a8c66313562fd51977a7ab3dee","Size":480360,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:22:52+01:00","tool":{"version":"10.3.1-2.3","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/xpack-dev-tools/arm-none-eabi-gcc-xpack/releases/download/v10.3.1-2.3/xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-arm.tar.gz","ArchiveFileName":"xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-arm.tar.gz","Checksum":"SHA-256:cf152bb008697143b802a85fffffc2c9b562bc1e6d0984ad02d4ee1f1bb91790","Size":169168939,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/xpack-dev-tools/arm-none-eabi-gcc-xpack/releases/download/v10.3.1-2.3/xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-arm64.tar.gz","ArchiveFileName":"xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-arm64.tar.gz","Checksum":"SHA-256:6e3ee605079ba084836cd057022e16c28605f4068042cd14397976b836ea1a21","Size":174454524,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/xpack-dev-tools/arm-none-eabi-gcc-xpack/releases/download/v10.3.1-2.3/xpack-arm-none-eabi-gcc-10.3.1-2.3-win32-ia32.zip","ArchiveFileName":"xpack-arm-none-eabi-gcc-10.3.1-2.3-win32-ia32.zip","Checksum":"SHA-256:c98fc443d7ef3524d42a40b6635e8b99c736efac77729f8a70463bb9ba19bc85","Size":180590105,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/xpack-dev-tools/arm-none-eabi-gcc-xpack/releases/download/v10.3.1-2.3/xpack-arm-none-eabi-gcc-10.3.1-2.3-darwin-x64.tar.gz","ArchiveFileName":"xpack-arm-none-eabi-gcc-10.3.1-2.3-darwin-x64.tar.gz","Checksum":"SHA-256:eb9218eaafb74a05fab9cbbeb49fd4fe7b85c6ba411aefc66f681a5a862e8d8e","Size":173440158,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/xpack-dev-tools/arm-none-eabi-gcc-xpack/releases/download/v10.3.1-2.3/xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-x64.tar.gz","ArchiveFileName":"xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-x64.tar.gz","Checksum":"SHA-256:559dcf1c2dfddac513110fe23da0ef254032c09967eaa901f075515d51818719","Size":175646740,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/xpack-dev-tools/arm-none-eabi-gcc-xpack/releases/download/v10.3.1-2.3/xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-ia32.tar.gz","ArchiveFileName":"xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-ia32.tar.gz","Checksum":"SHA-256:8a6621590ac2f0b33fc71f1c501af6b60e900fc3d895a11f20de850cd4f55ca3","Size":179184840,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loading package arduino from: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware","time":"2022-09-25T22:22:52+01:00"}
{"error":"opening signature file: open C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json.sig: The system cannot find the file specified.","index":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json.sig","time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:avr","Installed":"1.8.5","Latest":"1.8.5","Name":"Arduino AVR Boards"},"time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:megaavr","Installed":"1.8.7","Latest":"1.8.7","Name":"Arduino megaAVR Boards"},"time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:22:52+01:00","tool":{"version":"1.3.0","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_386.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_386.tar.bz2","Checksum":"SHA-256:3e7f59d6fbc7a724598303f0d3289d0c4fd137a8973437980658379a024887b2","Size":2633516,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_amd64.tar.bz2","Checksum":"SHA-256:aa45ee2441ffc3a122daec5802941d1fa2ac47adf5c5c481b5e0daa4dc259ffa","Size":2716248,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm.tar.bz2","Checksum":"SHA-256:1888587409b56aef4ba0ab0e6703b3dccba7cc3a022756ba9b908247e5d5a656","Size":2567435,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm64.tar.bz2","Checksum":"SHA-256:835ed8f37cffac37e979d1b0f6041559592d3d98be52f0e8611b76c4858e4113","Size":2472427,"CachePath":"packages"}},{"os":"i386-apple-darwin11","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-darwin_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-darwin_amd64.tar.bz2","Checksum":"SHA-256:d5d0f82ff829c0e434d12a2ee640a6fbd78f893ab37782edbb8b5bf2359d119e","Size":2766116,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-windows_386.zip","ArchiveFileName":"arduinoOTA-1.3.0-windows_386.zip","Checksum":"SHA-256:051943844eee442460d2c709edefadca184287fffd2b6c100dd53aa742aa05f6","Size":2768948,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:22:52+01:00","tool":{"version":"4.8.3-2014q1","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/gcc-arm-none-eabi-4.8.3-2014q1-arm.tar.bz2","ArchiveFileName":"gcc-arm-none-eabi-4.8.3-2014q1-arm.tar.bz2","Checksum":"SHA-256:ebe96b34c4f434667cab0187b881ed585e7c7eb990fe6b69be3c81ec7e11e845","Size":44423906,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/gcc-arm-none-eabi-4.8.3-2014q1-windows.tar.gz","ArchiveFileName":"gcc-arm-none-eabi-4.8.3-2014q1-windows.tar.gz","Checksum":"SHA-256:fd8c111c861144f932728e00abd3f7d1107e186eb9cd6083a54c7236ea78b7c2","Size":84537449,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"http://downloads.arduino.cc/gcc-arm-none-eabi-4.8.3-2014q1-mac.tar.gz","ArchiveFileName":"gcc-arm-none-eabi-4.8.3-2014q1-mac.tar.gz","Checksum":"SHA-256:3598acf21600f17a8e4a4e8e193dc422b894dc09384759b270b2ece5facb59c2","Size":52518522,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/gcc-arm-none-eabi-4.8.3-2014q1-linux64.tar.gz","ArchiveFileName":"gcc-arm-none-eabi-4.8.3-2014q1-linux64.tar.gz","Checksum":"SHA-256:d23f6626148396d6ec42a5b4d928955a703e0757829195fa71a939e5b86eecf6","Size":51395093,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/gcc-arm-none-eabi-4.8.3-2014q1-linux32.tar.gz","ArchiveFileName":"gcc-arm-none-eabi-4.8.3-2014q1-linux32.tar.gz","Checksum":"SHA-256:ba1994235f69c526c564f65343f22ddbc9822b2ea8c5ee07dd79d89f6ace2498","Size":51029223,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:22:52+01:00","tool":{"version":"7.3.0-atmel3.6.1-arduino5","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino5-arm-linux-gnueabihf.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino5-arm-linux-gnueabihf.tar.bz2","Checksum":"SHA-256:f4acd5531c6b82c715e2edfa0aadb13fb718b4095b3ea1aa1f7fbde680069639","Size":34462042,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino5-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino5-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:dd9c70190be370a44fb47dab1514de6d8852b861dfa527964b65c740d8d50c10","Size":39381972,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino5-x86_64-apple-darwin14.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino5-x86_64-apple-darwin14.tar.bz2","Checksum":"SHA-256:f48706317f04452544ab90e75bd1bb193f8af2cb1002f53aa702f27202c1b38f","Size":38492678,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino5-i686-w64-mingw32.zip","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino5-i686-w64-mingw32.zip","Checksum":"SHA-256:6d4a5d089a36e5b5252befc73da204555b49e376ce7577ee19ca7f028b295830","Size":53727984,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino5-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino5-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:2ff12739d7ed09688d6b3c2c126e8df69b5bda1a07ab558799f0e576571e0e1d","Size":38710087,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino5-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino5-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:3effed8ffa1978b6e4a46f1aa2acc629e440b4d77244f71f9b79a916025206fb","Size":39114120,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:22:52+01:00","tool":{"version":"7.3.0-atmel3.6.1-arduino7","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","Checksum":"SHA-256:3903553d035da59e33cff9941b857c3cb379cb0638105dfdf69c97f0acc8e7b5","Size":34683056,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:03d322b9df6da17289e9e7c6233c34a8535d9c645c19efc772ba19e56914f339","Size":38045723,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","Checksum":"SHA-256:f6ed2346953fcf88df223469088633eb86de997fa27ece117fd1ef170d69c1f8","Size":36684546,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","Checksum":"SHA-256:a54f64755fff4cb792a1495e5defdd789902a2a3503982e81b898299cf39800e","Size":52519412,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:954bbffb33545bcdcd473af993da2980bf32e8461ff55a18e0eebc7b2ef69a4c","Size":37176991,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:bd8c37f6952a2130ac9ee32c53f6a660feb79bee8353c8e289eb60fdcefed91e","Size":37630618,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:22:52+01:00","tool":{"version":"6.3.0-arduino17","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:2a8e68c5d803aa6f902ef219f177ec3a4c28275d85cbe272962ad2cd374f50d1","Size":219631,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:6cf948f751acfe7b96684537f2291c766ec8b54b4f7dc95539864821456fa9fc","Size":229852,"CachePath":"packages"}},{"os":"x86_64-apple-darwin12","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","Checksum":"SHA-256:120cc9edaae699e7e9ac50b1b8eb0e7d51fdfa555bac54233c2511e6ee5418c9","Size":279045,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:accdfb920af2aabf4f7461d2ac73c0751760f525216dc4e7657427a78c60d13d","Size":254271,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:5c8cc6c17db9300e1451fe41cd7178b0442b4490ee6fdbc0aed9811aef96c05f","Size":244550,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","Checksum":"SHA-256:e99188873c7c5ad8f8f906f068c33600e758b2e36cce3adbd518a21bd266749d","Size":328460,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loading package builtin from: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\builtin","time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:22:52+01:00","tool":{"version":"5.8-arduino11","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:22:52+01:00","tool":{"version":"1.0.6","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:22:52+01:00","tool":{"version":"1.3.2","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:22:52+01:00","tool":{"version":"0.10.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:22:52+01:00","tool":{"version":"0.9.1","systems":null}}
{"level":"info","msg":"Loading package stm32duino from: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\stm32duino\\hardware","time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"stm32duino:STM32F1","Installed":"2021.2.27","Latest":"2021.2.27","Name":"STM32F1 Boards (Arduino_STM32)"},"time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\stm32duino\\tools","time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\stm32duino\\tools","time":"2022-09-25T22:22:52+01:00"}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:22:52+01:00","tool":{"version":"2021.2.27","systems":null}}
{"index":"c:\\Users\\piter\\AppData\\Local\\Arduino15\\package_index.json","level":"info","msg":"Checking signature","signatureFile":"c:\\Users\\piter\\AppData\\Local\\Arduino15\\package_index.json.sig","time":"2022-09-25T22:22:52+01:00","trusted":true}
{"error":"opening signature file: open c:\\Users\\piter\\AppData\\Local\\Arduino15\\package_stmicroelectronics_index.json.sig: The system cannot find the file specified.","index":"c:\\Users\\piter\\AppData\\Local\\Arduino15\\package_stmicroelectronics_index.json","level":"info","msg":"Checking signature","signatureFile":"c:\\Users\\piter\\AppData\\Local\\Arduino15\\package_stmicroelectronics_index.json.sig","time":"2022-09-25T22:22:52+01:00"}
{"dir":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\hardware\\stm32\\2.3.0\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-25T22:22:52+01:00"}
{"dir":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-25T22:22:52+01:00"}
{"dir":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-25T22:22:52+01:00"}
{"dir":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\stm32duino\\hardware\\STM32F1\\2021.2.27\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-25T22:22:52+01:00"}
{"dir":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\LGT8fx Boards\\hardware\\avr\\1.0.5\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-25T22:22:52+01:00"}
{"index":"c:\\Users\\piter\\AppData\\Local\\Arduino15\\library_index.json","level":"info","msg":"Loading libraries index file","time":"2022-09-25T22:22:52+01:00"}
root INFO Deployed backend plugin "vscode-language-pack-fr@1.69.0" from "C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-fr\extension": 108.6 ms [Finished 2.157 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-it@1.69.0" from "C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-it\extension": 86.0 ms [Finished 2.243 s after backend start]
daemon INFO {"dir":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-09-25T22:22:52+01:00"}
{"dir":"e:\\Projects\\Electronics\\Arduino sketches\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-09-25T22:22:52+01:00"}
root INFO Deployed backend plugin "vscode-language-pack-ja@1.69.0" from "C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ja\extension": 85.1 ms [Finished 2.328 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-nl@1.48.3" from "C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-nl\extension": 28.7 ms [Finished 2.357 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-pt-BR@1.69.0" from "C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-pt-BR\extension": 120.4 ms [Finished 2.477 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-ru@1.69.0" from "C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-ru\extension": 137.0 ms [Finished 2.614 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-tr@1.69.0" from "C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-tr\extension": 78.1 ms [Finished 2.692 s after backend start]
root INFO Deployed backend plugin "vscode-language-pack-zh-hans@1.69.0" from "C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-language-pack-zh-hans\extension": 75.0 ms [Finished 2.767 s after backend start]
root INFO Deploy plugins list: 96.2 ms [Finished 2.775 s after backend start]
root WARN Frontend s.configure took longer than the expected maximum 100 milliseconds: 208.5 ms [Finished 2.063 s after frontend start]
discovery-log INFO start request start watch
discovery-log INFO start requested start watch
discovery-log INFO start resolved watching
daemon INFO {"level":"info","msg":"starting discovery builtin:mdns-discovery process","time":"2022-09-25T22:22:54+01:00"}
daemon INFO {"level":"info","msg":"starting discovery builtin:serial-discovery process","time":"2022-09-25T22:22:54+01:00"}
daemon INFO {"level":"info","msg":"started discovery builtin:serial-discovery process","time":"2022-09-25T22:22:54+01:00"}
daemon INFO {"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:serial-discovery","time":"2022-09-25T22:22:54+01:00"}
{"level":"info","msg":"started discovery builtin:mdns-discovery process","time":"2022-09-25T22:22:54+01:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:mdns-discovery","time":"2022-09-25T22:22:54+01:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-09-25T22:22:54+01:00"}
daemon INFO {"level":"info","msg":"sending command START_SYNC to discovery builtin:serial-discovery","time":"2022-09-25T22:22:54+01:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: start_sync, message: OK","time":"2022-09-25T22:22:54+01:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-09-25T22:22:54+01:00"}
{"level":"info","msg":"sending command START_SYNC to discovery builtin:mdns-discovery","time":"2022-09-25T22:22:54+01:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:mdns-discovery received message type: start_sync, message: OK","time":"2022-09-25T22:22:54+01:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: COM1","time":"2022-09-25T22:22:54+01:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: COM6","time":"2022-09-25T22:22:54+01:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: COM8","time":"2022-09-25T22:22:54+01:00"}
discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM1","label":"COM1","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[]}},"error":""}
discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM6","label":"COM6","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[]}},"error":""}
discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM8","label":"COM8","protocol":"serial","protocolLabel":"Serial Port","propertiesMap":[]}},"error":""}
root WARN Frontend C.onStart took longer than the expected maximum 100 milliseconds: 116.4 ms [Finished 2.353 s after frontend start]
app-state-change >>> new app state <started_contributions was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <started_contributions> for window <1>
root INFO Start frontend contributions: 614.3 ms [Finished 2.404 s after frontend start]
root INFO Changed application state from 'init' to 'started_contributions'.
app-state-change >>> new app state <attached_shell was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <attached_shell> for window <1>
root INFO Changed application state from 'started_contributions' to 'attached_shell'.
root INFO >>> Restoring the layout state...
root INFO ------- SERIALIZED LAYOUT DATA -------
root INFO {"version":5,"mainPanel":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"code-editor-opener","options":{"kind":"navigatable","uri":"file:///e%3A/Projects/Electronics/Arduino%20sketches/Bimetallic%20switch%20tester_phaseCompletion_detecting/Bimetallic%20switch%20tester_phaseCompletion_detecting.ino","counter":0}},"innerWidgetState":"{\"cursorState\":[{\"inSelectionMode\":false,\"selectionStart\":{\"lineNumber\":181,\"column\":36},\"position\":{\"lineNumber\":181,\"column\":36}}],\"viewState\":{\"scrollLeft\":0,\"firstPosition\":{\"lineNumber\":157,\"column\":1},\"firstPositionDeltaTop\":-3},\"contributionsState\":{\"editor.contrib.folding\":{\"lineCount\":319,\"provider\":\"indent\",\"foldedImports\":false},\"editor.contrib.wordHighlighter\":false}}"}],"currentIndex":0}},"mainPanelPinned":[false],"bottomPanel":{"config":{"main":{"type":"tab-area","widgets":[{"constructionOptions":{"factoryId":"outputView"},"innerWidgetState":"{\"locked\":false}"},{"constructionOptions":{"factoryId":"serial-monitor"}}],"currentIndex":1}},"pinned":[false,false],"size":232,"expanded":true},"leftPanel":{"type":"sidepanel","items":[{"widget":{"constructionOptions":{"factoryId":"arduino-sketchbook-widget"}},"rank":1,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"boards-list-widget"}},"rank":2,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"library-list-widget"}},"rank":3,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"debug"},"innerWidgetState":"{\"parts\":[{\"partId\":\"debug:threads:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:frames:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:variables:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:watch:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"debug:breakpoints:-1\",\"collapsed\":false,\"hidden\":false,\"relativeSize\":1.384,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}},{\"partId\":\"plugin-view:cortex-debug.peripherals\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.peripherals\",\"viewId\":\"cortex-debug.peripherals\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Peripherals\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}},{\"partId\":\"plugin-view:cortex-debug.registers\",\"collapsed\":true,\"hidden\":true,\"originalContainerId\":\"debug:view-container:-1\",\"originalContainerTitle\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"plugin-view\",\"options\":{\"id\":\"plugin-view:cortex-debug.registers\",\"viewId\":\"cortex-debug.registers\"}},\"innerWidgetState\":\"{\\\"label\\\":\\\"Cortex Registers\\\",\\\"widgets\\\":[],\\\"suppressUpdateViewVisibility\\\":false,\\\"currentViewContainerId\\\":\\\"debug\\\"}\"}}],\"title\":{\"label\":\"debug\",\"iconClass\":\"codicon codicon-debug-alt\",\"closeable\":true}}"},"rank":4,"expanded":false,"pinned":false},{"widget":{"constructionOptions":{"factoryId":"search-view-container"},"innerWidgetState":"{\"parts\":[{\"partId\":\"search-in-workspace\",\"collapsed\":false,\"hidden\":false,\"originalContainerId\":\"search-view-container\",\"originalContainerTitle\":{\"label\":\"Search\",\"iconClass\":\"codicon codicon-search\",\"closeable\":true},\"widget\":{\"constructionOptions\":{\"factoryId\":\"search-in-workspace\"},\"innerWidgetState\":\"{\\\"matchCaseState\\\":{\\\"className\\\":\\\"codicon codicon-case-sensitive\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Case\\\"},\\\"wholeWordState\\\":{\\\"className\\\":\\\"codicon codicon-whole-word\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Match Whole Word\\\"},\\\"regExpState\\\":{\\\"className\\\":\\\"codicon codicon-regex\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Use Regular Expression\\\"},\\\"includeIgnoredState\\\":{\\\"className\\\":\\\"codicon codicon-eye\\\",\\\"enabled\\\":false,\\\"title\\\":\\\"Include Ignored Files\\\"},\\\"showSearchDetails\\\":false,\\\"searchInWorkspaceOptions\\\":{\\\"matchCase\\\":false,\\\"matchWholeWord\\\":false,\\\"useRegExp\\\":false,\\\"includeIgnored\\\":false,\\\"include\\\":[],\\\"exclude\\\":[],\\\"maxResults\\\":2000},\\\"searchTerm\\\":\\\"\\\",\\\"replaceTerm\\\":\\\"\\\",\\\"showReplaceField\\\":false,\\\"searchHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0},\\\"replaceHistoryState\\\":{\\\"history\\\":[],\\\"index\\\":0}}\"}}],\"title\":{\"label\":\"Search\",\"iconClass\":\"fa fa-arduino-search\",\"closeable\":true}}"},"rank":5,"expanded":false,"pinned":false}],"size":347},"rightPanel":{"type":"sidepanel","items":[]},"activeWidgetId":"serial-monitor"}
root INFO ------- END SERIALIZED LAYOUT DATA -------
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b] Waiting for backend deployment: 139.4 ms [Finished 2.539 s after frontend start]
root ERROR ---- !!!SLOW!!! DURATION: getSketchesNew took 481.088 ms. Args: [{"uri":"file:///e%3A/Projects/Electronics/Arduino%20sketches"}] ----
root INFO [hosted-plugin: 19496] PLUGIN_HOST(19496) starting instance
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b] Sync of 16 plugins: 829.4 ms [Finished 3.368 s after frontend start]
root INFO <<< The layout has been successfully restored.
app-state-change >>> new app state <initialized_layout was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <initialized_layout> for window <1>
root INFO Initialize the workbench layout: 1249.0 ms [Finished 3.693 s after frontend start]
root INFO Changed application state from 'attached_shell' to 'initialized_layout'.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][marus25.cortex-debug]: Loaded contributions.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][arduino.vscode-arduino-tools]: Loaded contributions.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][vscode.cpp]: Loaded contributions.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][vscode.json]: Loaded contributions.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][vscode.json-language-features]: Loaded contributions.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-cs]: Loaded contributions.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-de]: Loaded contributions.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-es]: Loaded contributions.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-fr]: Loaded contributions.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-it]: Loaded contributions.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-ja]: Loaded contributions.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-nl]: Loaded contributions.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-pt-br]: Loaded contributions.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-ru]: Loaded contributions.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-tr]: Loaded contributions.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-zh-hans]: Loaded contributions.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b] Load contributions of 16 plugins: 103.5 ms [Finished 3.797 s after frontend start]
root WARN Frontend I.onDidInitializeLayout took longer than the expected maximum 100 milliseconds: 107.3 ms [Finished 3.800 s after frontend start]
root WARN 'cpp' language is remapped from 'source.cpp.embedded.macro' to 'source.cpp' scope
root WARN a registered grammar configuration for 'cpp' language is overridden
root INFO [hosted-plugin: 19496] PLUGIN_HOST(19496): PluginManagerExtImpl/init()
root INFO [hosted-plugin: 19496] PLUGIN_HOST(19496): initializing(cortex-debug@0.3.10 with C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 19496] Debugger contribution has been registered: cortex-debug
PLUGIN_HOST(19496): initializing(vscode-arduino-tools@0.0.2-beta.5 with C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 19496] PLUGIN_HOST(19496): initializing(cpp@1.52.1 with C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(19496): initializing(json@1.46.1 with C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 19496] PLUGIN_HOST(19496): initializing(json-language-features@1.46.1 with C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(19496): initializing(vscode-language-pack-cs@1.69.0 with C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 19496] PLUGIN_HOST(19496): initializing(vscode-language-pack-de@1.69.0 with C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(19496): initializing(vscode-language-pack-es@1.69.0 with C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(19496): initializing(vscode-language-pack-fr@1.69.0 with C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 19496] PLUGIN_HOST(19496): initializing(vscode-language-pack-it@1.69.0 with C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(19496): initializing(vscode-language-pack-ja@1.69.0 with C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 19496] PLUGIN_HOST(19496): initializing(vscode-language-pack-nl@1.48.3 with C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(19496): initializing(vscode-language-pack-pt-BR@1.69.0 with C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(19496): initializing(vscode-language-pack-ru@1.69.0 with C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 19496] PLUGIN_HOST(19496): initializing(vscode-language-pack-tr@1.69.0 with C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
PLUGIN_HOST(19496): initializing(vscode-language-pack-zh-hans@1.69.0 with C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@theia\plugin-ext-vscode\lib\node\plugin-vscode-init)
root INFO [hosted-plugin: 19496] PLUGIN_HOST(19496): PluginManagerExtImpl/loadPlugin(C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-builtin-json-language-features\extension\client\dist\jsonMain)
root INFO [hosted-plugin: 19496] PLUGIN_HOST(19496): PluginManagerExtImpl/loadPlugin(C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\plugins\vscode-arduino-tools\extension\dist\bundle)
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][marus25.cortex-debug]: Started plugin.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][arduino.vscode-arduino-tools]: Started plugin.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][vscode.cpp]: Started plugin.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][vscode.json]: Started plugin.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][vscode.json-language-features]: Started plugin.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-cs]: Started plugin.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-de]: Started plugin.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-es]: Started plugin.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-fr]: Started plugin.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-it]: Started plugin.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-ja]: Started plugin.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-nl]: Started plugin.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-pt-br]: Started plugin.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-ru]: Started plugin.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-tr]: Started plugin.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b][ms-ceintl.vscode-language-pack-zh-hans]: Started plugin.
root INFO [2ceff7df-8426-406b-8bdd-3ed11d8e2a5b] Start of 16 plugins: 783.9 ms [Finished 4.592 s after frontend start]
app-state-change >>> new app state <ready was received from sender <1>. current window ID: 1
app-state-change <<< new app state is <ready> for window <1>
root INFO Frontend application start: 3074.4 ms [Finished 6.682 s after backend start]
root INFO Replace loading indicator with ready workbench UI (animation): 912.6 ms [Finished 4.715 s after frontend start]
root INFO Changed application state from 'initialized_layout' to 'ready'.
root INFO Executing startup tasks: []
root INFO ---- DURATION: installed took 96.059 ms. Args: [{}] ----
root ERROR ---- !!!SLOW!!! DURATION: getSketchesNew took 113.878 ms. Args: [{}] ----
root INFO ---- DURATION: installed took 23.269 ms. Args: [{"fqbn":"STMicroelectronics:stm32:GenF1"}] ----
root INFO ---- DURATION: installed took 23.719 ms. Args: [{"fqbn":"STMicroelectronics:stm32:GenF1"}] ----
root INFO Starting language server: STMicroelectronics:stm32:GenF1
daemon INFO {"level":"info","msg":"Searching tools required for board STMicroelectronics:stm32:GenF1","time":"2022-09-25T22:22:58+01:00"}
daemon INFO {"level":"info","msg":"Required tool","time":"2022-09-25T22:22:58+01:00","tool":{"ToolName":"CMSIS","ToolVersion":"5.7.0","ToolPackager":"STMicroelectronics"}}
{"level":"info","msg":"Required tool","time":"2022-09-25T22:22:58+01:00","tool":{"ToolName":"STM32Tools","ToolVersion":"2.1.1","ToolPackager":"STMicroelectronics"}}
{"level":"info","msg":"Required tool","time":"2022-09-25T22:22:58+01:00","tool":{"ToolName":"xpack-arm-none-eabi-gcc","ToolVersion":"10.3.1-2.3","ToolPackager":"STMicroelectronics"}}
{"dir":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-09-25T22:22:58+01:00"}
{"dir":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\hardware\\stm32\\2.3.0\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-25T22:22:58+01:00"}
daemon INFO {"dir":"e:\\Projects\\Electronics\\Arduino sketches\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-09-25T22:22:58+01:00"}
daemon INFO {"level":"info","msg":"Resolving include SrcWrapper.h for arch stm32","time":"2022-09-25T22:22:59+01:00"}
{"level":"info","lib":"SrcWrapper","msg":" found better lib","prio":"64C","time":"2022-09-25T22:22:59+01:00"}
daemon INFO {"level":"info","msg":"Updating libraries index","time":"2022-09-25T22:23:04+01:00"}
daemon INFO {"level":"info","msg":"URL: https://downloads.arduino.cc/packages/package_index.tar.bz2","time":"2022-09-25T22:23:04+01:00"}
{"level":"info","msg":"Updating index","time":"2022-09-25T22:23:04+01:00","url":{"Scheme":"https","Opaque":"","User":null,"Host":"downloads.arduino.cc","Path":"/packages/package_index.tar.bz2","RawPath":"","ForceQuery":false,"RawQuery":"","Fragment":"","RawFragment":""}}
root INFO core-client-provider [platform-index]
daemon INFO {"level":"info","msg":"URL: https://github.com/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json","time":"2022-09-25T22:23:04+01:00"}
{"level":"info","msg":"Updating index","time":"2022-09-25T22:23:04+01:00","url":{"Scheme":"https","Opaque":"","User":null,"Host":"github.com","Path":"/stm32duino/BoardManagerFiles/raw/main/package_stmicroelectronics_index.json","RawPath":"","ForceQuery":false,"RawQuery":"","Fragment":"","RawFragment":""}}
root INFO core-client-provider [library-index]
daemon INFO {"level":"info","msg":"Loading hardware from: c:\\Users\\piter\\AppData\\Local\\Arduino15\\packages","time":"2022-09-25T22:23:04+01:00"}
daemon INFO {"level":"info","msg":"Loading package LGT8fx Boards from: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\LGT8fx Boards\\hardware","time":"2022-09-25T22:23:04+01:00"}
daemon INFO {"level":"info","msg":"Adding monitor tool","protocol":"serial","time":"2022-09-25T22:23:04+01:00","tool":"builtin:serial-monitor"}
daemon INFO {"level":"info","msg":"Loaded platform","platform":{"ID":"LGT8fx Boards:avr","Installed":"1.0.5","Latest":"1.0.5","Name":"Logic Green Arduino AVR Compatible Boards"},"time":"2022-09-25T22:23:04+01:00"}
daemon INFO {"level":"info","msg":"Loading package STMicroelectronics from: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\hardware","time":"2022-09-25T22:23:04+01:00"}
daemon INFO {"error":"opening signature file: open C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\hardware\\stm32\\2.3.0\\installed.json.sig: The system cannot find the file specified.","index":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\hardware\\stm32\\2.3.0\\installed.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\hardware\\stm32\\2.3.0\\installed.json.sig","time":"2022-09-25T22:23:04+01:00"}
daemon INFO {"level":"info","msg":"Loaded platform","platform":{"ID":"STMicroelectronics:stm32","Installed":"2.3.0","Latest":"2.3.0","Name":"STM32 MCU based boards"},"time":"2022-09-25T22:23:04+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\tools","time":"2022-09-25T22:23:04+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\tools","time":"2022-09-25T22:23:04+01:00"}
daemon INFO {"level":"info","msg":"Loaded tool","time":"2022-09-25T22:23:04+01:00","tool":{"version":"5.7.0","systems":[{"os":"i686-mingw32","Resource":{"URL":"https://github.com/stm32duino/ArduinoModule-CMSIS/releases/download/5.7.0/CMSIS-5.7.0.tar.bz2","ArchiveFileName":"CMSIS-5.7.0.tar.bz2","Checksum":"SHA-256:0b04b0f214e483bcc360cda985cddc0de8031714019ceabcda4770d510b82bfe","Size":26151901,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/stm32duino/ArduinoModule-CMSIS/releases/download/5.7.0/CMSIS-5.7.0.tar.bz2","ArchiveFileName":"CMSIS-5.7.0.tar.bz2","Checksum":"SHA-256:0b04b0f214e483bcc360cda985cddc0de8031714019ceabcda4770d510b82bfe","Size":26151901,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/stm32duino/ArduinoModule-CMSIS/releases/download/5.7.0/CMSIS-5.7.0.tar.bz2","ArchiveFileName":"CMSIS-5.7.0.tar.bz2","Checksum":"SHA-256:0b04b0f214e483bcc360cda985cddc0de8031714019ceabcda4770d510b82bfe","Size":26151901,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/stm32duino/ArduinoModule-CMSIS/releases/download/5.7.0/CMSIS-5.7.0.tar.bz2","ArchiveFileName":"CMSIS-5.7.0.tar.bz2","Checksum":"SHA-256:0b04b0f214e483bcc360cda985cddc0de8031714019ceabcda4770d510b82bfe","Size":26151901,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/stm32duino/ArduinoModule-CMSIS/releases/download/5.7.0/CMSIS-5.7.0.tar.bz2","ArchiveFileName":"CMSIS-5.7.0.tar.bz2","Checksum":"SHA-256:0b04b0f214e483bcc360cda985cddc0de8031714019ceabcda4770d510b82bfe","Size":26151901,"CachePath":"packages"}},{"os":"all","Resource":{"URL":"https://github.com/stm32duino/ArduinoModule-CMSIS/releases/download/5.7.0/CMSIS-5.7.0.tar.bz2","ArchiveFileName":"CMSIS-5.7.0.tar.bz2","Checksum":"SHA-256:0b04b0f214e483bcc360cda985cddc0de8031714019ceabcda4770d510b82bfe","Size":26151901,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:23:04+01:00","tool":{"version":"2.1.1","systems":[{"os":"i686-mingw32","Resource":{"URL":"https://github.com/stm32duino/Arduino_Tools/releases/download/2.1.1/STM32Tools-2.1.1-windows.tar.bz2","ArchiveFileName":"STM32Tools-2.1.1-windows.tar.bz2","Checksum":"SHA-256:385f1495a70613ca6771c0f824e420f44e27b1433b0b449aaade1dde63b35e68","Size":2587832,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/stm32duino/Arduino_Tools/releases/download/2.1.1/STM32Tools-2.1.1-mac.tar.bz2","ArchiveFileName":"STM32Tools-2.1.1-mac.tar.bz2","Checksum":"SHA-256:417bc75ebf19060083e29cf65f7a9f71a6903b7fd158c154057ed723c5e847a1","Size":486815,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/stm32duino/Arduino_Tools/releases/download/2.1.1/STM32Tools-2.1.1-linux.tar.bz2","ArchiveFileName":"STM32Tools-2.1.1-linux.tar.bz2","Checksum":"SHA-256:35ecc3914e8a0a45de229111cc45b8cb39a8e0a8c66313562fd51977a7ab3dee","Size":480360,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/stm32duino/Arduino_Tools/releases/download/2.1.1/STM32Tools-2.1.1-linux.tar.bz2","ArchiveFileName":"STM32Tools-2.1.1-linux.tar.bz2","Checksum":"SHA-256:35ecc3914e8a0a45de229111cc45b8cb39a8e0a8c66313562fd51977a7ab3dee","Size":480360,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:23:04+01:00","tool":{"version":"10.3.1-2.3","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/xpack-dev-tools/arm-none-eabi-gcc-xpack/releases/download/v10.3.1-2.3/xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-arm.tar.gz","ArchiveFileName":"xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-arm.tar.gz","Checksum":"SHA-256:cf152bb008697143b802a85fffffc2c9b562bc1e6d0984ad02d4ee1f1bb91790","Size":169168939,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/xpack-dev-tools/arm-none-eabi-gcc-xpack/releases/download/v10.3.1-2.3/xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-arm64.tar.gz","ArchiveFileName":"xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-arm64.tar.gz","Checksum":"SHA-256:6e3ee605079ba084836cd057022e16c28605f4068042cd14397976b836ea1a21","Size":174454524,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/xpack-dev-tools/arm-none-eabi-gcc-xpack/releases/download/v10.3.1-2.3/xpack-arm-none-eabi-gcc-10.3.1-2.3-win32-ia32.zip","ArchiveFileName":"xpack-arm-none-eabi-gcc-10.3.1-2.3-win32-ia32.zip","Checksum":"SHA-256:c98fc443d7ef3524d42a40b6635e8b99c736efac77729f8a70463bb9ba19bc85","Size":180590105,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/xpack-dev-tools/arm-none-eabi-gcc-xpack/releases/download/v10.3.1-2.3/xpack-arm-none-eabi-gcc-10.3.1-2.3-darwin-x64.tar.gz","ArchiveFileName":"xpack-arm-none-eabi-gcc-10.3.1-2.3-darwin-x64.tar.gz","Checksum":"SHA-256:eb9218eaafb74a05fab9cbbeb49fd4fe7b85c6ba411aefc66f681a5a862e8d8e","Size":173440158,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/xpack-dev-tools/arm-none-eabi-gcc-xpack/releases/download/v10.3.1-2.3/xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-x64.tar.gz","ArchiveFileName":"xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-x64.tar.gz","Checksum":"SHA-256:559dcf1c2dfddac513110fe23da0ef254032c09967eaa901f075515d51818719","Size":175646740,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/xpack-dev-tools/arm-none-eabi-gcc-xpack/releases/download/v10.3.1-2.3/xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-ia32.tar.gz","ArchiveFileName":"xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-ia32.tar.gz","Checksum":"SHA-256:8a6621590ac2f0b33fc71f1c501af6b60e900fc3d895a11f20de850cd4f55ca3","Size":179184840,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loading package arduino from: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware","time":"2022-09-25T22:23:04+01:00"}
daemon INFO {"error":"opening signature file: open C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json.sig: The system cannot find the file specified.","index":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json","level":"info","msg":"Checking signature","signatureFile":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\installed.json.sig","time":"2022-09-25T22:23:04+01:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:avr","Installed":"1.8.5","Latest":"1.8.5","Name":"Arduino AVR Boards"},"time":"2022-09-25T22:23:04+01:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"arduino:megaavr","Installed":"1.8.7","Latest":"1.8.7","Name":"Arduino megaAVR Boards"},"time":"2022-09-25T22:23:04+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-09-25T22:23:04+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\arduino\\tools","time":"2022-09-25T22:23:04+01:00"}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:23:04+01:00","tool":{"version":"1.3.0","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_386.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_386.tar.bz2","Checksum":"SHA-256:3e7f59d6fbc7a724598303f0d3289d0c4fd137a8973437980658379a024887b2","Size":2633516,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_amd64.tar.bz2","Checksum":"SHA-256:aa45ee2441ffc3a122daec5802941d1fa2ac47adf5c5c481b5e0daa4dc259ffa","Size":2716248,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm.tar.bz2","Checksum":"SHA-256:1888587409b56aef4ba0ab0e6703b3dccba7cc3a022756ba9b908247e5d5a656","Size":2567435,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm64.tar.bz2","Checksum":"SHA-256:835ed8f37cffac37e979d1b0f6041559592d3d98be52f0e8611b76c4858e4113","Size":2472427,"CachePath":"packages"}},{"os":"i386-apple-darwin11","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-darwin_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-darwin_amd64.tar.bz2","Checksum":"SHA-256:d5d0f82ff829c0e434d12a2ee640a6fbd78f893ab37782edbb8b5bf2359d119e","Size":2766116,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-windows_386.zip","ArchiveFileName":"arduinoOTA-1.3.0-windows_386.zip","Checksum":"SHA-256:051943844eee442460d2c709edefadca184287fffd2b6c100dd53aa742aa05f6","Size":2768948,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:23:04+01:00","tool":{"version":"4.8.3-2014q1","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/gcc-arm-none-eabi-4.8.3-2014q1-arm.tar.bz2","ArchiveFileName":"gcc-arm-none-eabi-4.8.3-2014q1-arm.tar.bz2","Checksum":"SHA-256:ebe96b34c4f434667cab0187b881ed585e7c7eb990fe6b69be3c81ec7e11e845","Size":44423906,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/gcc-arm-none-eabi-4.8.3-2014q1-windows.tar.gz","ArchiveFileName":"gcc-arm-none-eabi-4.8.3-2014q1-windows.tar.gz","Checksum":"SHA-256:fd8c111c861144f932728e00abd3f7d1107e186eb9cd6083a54c7236ea78b7c2","Size":84537449,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"http://downloads.arduino.cc/gcc-arm-none-eabi-4.8.3-2014q1-mac.tar.gz","ArchiveFileName":"gcc-arm-none-eabi-4.8.3-2014q1-mac.tar.gz","Checksum":"SHA-256:3598acf21600f17a8e4a4e8e193dc422b894dc09384759b270b2ece5facb59c2","Size":52518522,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/gcc-arm-none-eabi-4.8.3-2014q1-linux64.tar.gz","ArchiveFileName":"gcc-arm-none-eabi-4.8.3-2014q1-linux64.tar.gz","Checksum":"SHA-256:d23f6626148396d6ec42a5b4d928955a703e0757829195fa71a939e5b86eecf6","Size":51395093,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/gcc-arm-none-eabi-4.8.3-2014q1-linux32.tar.gz","ArchiveFileName":"gcc-arm-none-eabi-4.8.3-2014q1-linux32.tar.gz","Checksum":"SHA-256:ba1994235f69c526c564f65343f22ddbc9822b2ea8c5ee07dd79d89f6ace2498","Size":51029223,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:23:04+01:00","tool":{"version":"7.3.0-atmel3.6.1-arduino5","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino5-arm-linux-gnueabihf.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino5-arm-linux-gnueabihf.tar.bz2","Checksum":"SHA-256:f4acd5531c6b82c715e2edfa0aadb13fb718b4095b3ea1aa1f7fbde680069639","Size":34462042,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino5-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino5-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:dd9c70190be370a44fb47dab1514de6d8852b861dfa527964b65c740d8d50c10","Size":39381972,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino5-x86_64-apple-darwin14.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino5-x86_64-apple-darwin14.tar.bz2","Checksum":"SHA-256:f48706317f04452544ab90e75bd1bb193f8af2cb1002f53aa702f27202c1b38f","Size":38492678,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino5-i686-w64-mingw32.zip","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino5-i686-w64-mingw32.zip","Checksum":"SHA-256:6d4a5d089a36e5b5252befc73da204555b49e376ce7577ee19ca7f028b295830","Size":53727984,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino5-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino5-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:2ff12739d7ed09688d6b3c2c126e8df69b5bda1a07ab558799f0e576571e0e1d","Size":38710087,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino5-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino5-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:3effed8ffa1978b6e4a46f1aa2acc629e440b4d77244f71f9b79a916025206fb","Size":39114120,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:23:04+01:00","tool":{"version":"7.3.0-atmel3.6.1-arduino7","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","Checksum":"SHA-256:3903553d035da59e33cff9941b857c3cb379cb0638105dfdf69c97f0acc8e7b5","Size":34683056,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:03d322b9df6da17289e9e7c6233c34a8535d9c645c19efc772ba19e56914f339","Size":38045723,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","Checksum":"SHA-256:f6ed2346953fcf88df223469088633eb86de997fa27ece117fd1ef170d69c1f8","Size":36684546,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","Checksum":"SHA-256:a54f64755fff4cb792a1495e5defdd789902a2a3503982e81b898299cf39800e","Size":52519412,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:954bbffb33545bcdcd473af993da2980bf32e8461ff55a18e0eebc7b2ef69a4c","Size":37176991,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:bd8c37f6952a2130ac9ee32c53f6a660feb79bee8353c8e289eb60fdcefed91e","Size":37630618,"CachePath":"packages"}}]}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:23:04+01:00","tool":{"version":"6.3.0-arduino17","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:2a8e68c5d803aa6f902ef219f177ec3a4c28275d85cbe272962ad2cd374f50d1","Size":219631,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:6cf948f751acfe7b96684537f2291c766ec8b54b4f7dc95539864821456fa9fc","Size":229852,"CachePath":"packages"}},{"os":"x86_64-apple-darwin12","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","Checksum":"SHA-256:120cc9edaae699e7e9ac50b1b8eb0e7d51fdfa555bac54233c2511e6ee5418c9","Size":279045,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:accdfb920af2aabf4f7461d2ac73c0751760f525216dc4e7657427a78c60d13d","Size":254271,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:5c8cc6c17db9300e1451fe41cd7178b0442b4490ee6fdbc0aed9811aef96c05f","Size":244550,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","Checksum":"SHA-256:e99188873c7c5ad8f8f906f068c33600e758b2e36cce3adbd518a21bd266749d","Size":328460,"CachePath":"packages"}}]}}
daemon INFO {"level":"info","msg":"Loading package builtin from: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\builtin","time":"2022-09-25T22:23:04+01:00"}
{"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-09-25T22:23:04+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\builtin\\tools","time":"2022-09-25T22:23:04+01:00"}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:23:04+01:00","tool":{"version":"5.8-arduino11","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:23:04+01:00","tool":{"version":"1.0.6","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:23:04+01:00","tool":{"version":"1.3.2","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:23:04+01:00","tool":{"version":"0.10.0","systems":null}}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:23:04+01:00","tool":{"version":"0.9.1","systems":null}}
{"level":"info","msg":"Loading package stm32duino from: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\stm32duino\\hardware","time":"2022-09-25T22:23:04+01:00"}
{"level":"info","msg":"Loaded platform","platform":{"ID":"stm32duino:STM32F1","Installed":"2021.2.27","Latest":"2021.2.27","Name":"STM32F1 Boards (Arduino_STM32)"},"time":"2022-09-25T22:23:04+01:00"}
daemon INFO {"level":"info","msg":"Checking existence of 'tools' path: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\stm32duino\\tools","time":"2022-09-25T22:23:04+01:00"}
{"level":"info","msg":"Loading tools from dir: C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\stm32duino\\tools","time":"2022-09-25T22:23:04+01:00"}
{"level":"info","msg":"Loaded tool","time":"2022-09-25T22:23:04+01:00","tool":{"version":"2021.2.27","systems":null}}
daemon INFO {"index":"c:\\Users\\piter\\AppData\\Local\\Arduino15\\package_index.json","level":"info","msg":"Checking signature","signatureFile":"c:\\Users\\piter\\AppData\\Local\\Arduino15\\package_index.json.sig","time":"2022-09-25T22:23:04+01:00","trusted":true}
daemon INFO {"error":"opening signature file: open c:\\Users\\piter\\AppData\\Local\\Arduino15\\package_stmicroelectronics_index.json.sig: The system cannot find the file specified.","index":"c:\\Users\\piter\\AppData\\Local\\Arduino15\\package_stmicroelectronics_index.json","level":"info","msg":"Checking signature","signatureFile":"c:\\Users\\piter\\AppData\\Local\\Arduino15\\package_stmicroelectronics_index.json.sig","time":"2022-09-25T22:23:05+01:00"}
daemon INFO {"dir":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\LGT8fx Boards\\hardware\\avr\\1.0.5\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-25T22:23:15+01:00"}
daemon INFO {"dir":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\avr\\1.8.5\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-25T22:23:15+01:00"}
daemon INFO {"dir":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\arduino\\hardware\\megaavr\\1.8.7\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-25T22:23:15+01:00"}
daemon INFO {"dir":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\stm32duino\\hardware\\STM32F1\\2021.2.27\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-25T22:23:15+01:00"}
daemon INFO {"dir":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\hardware\\stm32\\2.3.0\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-25T22:23:15+01:00"}
{"index":"c:\\Users\\piter\\AppData\\Local\\Arduino15\\library_index.json","level":"info","msg":"Loading libraries index file","time":"2022-09-25T22:23:15+01:00"}
daemon INFO {"dir":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-09-25T22:23:15+01:00"}
daemon INFO {"dir":"e:\\Projects\\Electronics\\Arduino sketches\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-09-25T22:23:15+01:00"}
daemon INFO {"level":"info","msg":"Searching tools required for board STMicroelectronics:stm32:GenF1","time":"2022-09-25T22:23:16+01:00"}
daemon INFO {"level":"info","msg":"Required tool","time":"2022-09-25T22:23:16+01:00","tool":{"ToolName":"CMSIS","ToolVersion":"5.7.0","ToolPackager":"STMicroelectronics"}}
{"level":"info","msg":"Required tool","time":"2022-09-25T22:23:16+01:00","tool":{"ToolName":"STM32Tools","ToolVersion":"2.1.1","ToolPackager":"STMicroelectronics"}}
{"level":"info","msg":"Required tool","time":"2022-09-25T22:23:16+01:00","tool":{"ToolName":"xpack-arm-none-eabi-gcc","ToolVersion":"10.3.1-2.3","ToolPackager":"STMicroelectronics"}}
discovery-log INFO restarting before stop
discovery-log INFO stop
discovery-log INFO >>> Stopping boards watcher...
discovery-log INFO Canceling boards watcher...
discovery-log INFO disposing requesting cancel
discovery-log INFO disposing canceled
discovery-log INFO error received
discovery-log INFO cancel error received!
discovery-log INFO stop received event: either end or cancel
discovery-log INFO stop stopped
discovery-log INFO received end
discovery-log INFO restarting after stop
discovery-log INFO start new deferred
daemon INFO {"level":"info","msg":"boards watcher stream closed","time":"2022-09-25T22:23:17+01:00"}
daemon INFO {"level":"info","msg":"starting discovery builtin:mdns-discovery process","time":"2022-09-25T22:23:17+01:00"}
daemon INFO {"level":"info","msg":"starting discovery builtin:serial-discovery process","time":"2022-09-25T22:23:17+01:00"}
daemon INFO {"level":"info","msg":"started discovery builtin:mdns-discovery process","time":"2022-09-25T22:23:17+01:00"}
{"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:mdns-discovery","time":"2022-09-25T22:23:17+01:00"}
daemon INFO {"level":"info","msg":"started discovery builtin:serial-discovery process","time":"2022-09-25T22:23:17+01:00"}
daemon INFO {"level":"info","msg":"sending command HELLO 1 \"arduino-cli 0.27.1\" to discovery builtin:serial-discovery","time":"2022-09-25T22:23:17+01:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:mdns-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-09-25T22:23:17+01:00"}
daemon INFO {"level":"info","msg":"sending command START_SYNC to discovery builtin:mdns-discovery","time":"2022-09-25T22:23:17+01:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:mdns-discovery received message type: start_sync, message: OK","time":"2022-09-25T22:23:17+01:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: hello, message: OK, protocol version: 1","time":"2022-09-25T22:23:17+01:00"}
{"level":"info","msg":"sending command START_SYNC to discovery builtin:serial-discovery","time":"2022-09-25T22:23:17+01:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: start_sync, message: OK","time":"2022-09-25T22:23:17+01:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: COM1","time":"2022-09-25T22:23:17+01:00"}
discovery-log WARN Port 'COM1 Serial Port' was already available. Known boards before override: []
discovery-log WARN Port 'COM6 Serial Port' was already available. Known boards before override: []
discovery-log WARN Port 'COM8 Serial Port' was already available. Known boards before override: []
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: COM6","time":"2022-09-25T22:23:17+01:00"}
{"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: COM8","time":"2022-09-25T22:23:17+01:00"}
root INFO Attached boards and available ports changed:
root INFO No changes.
root INFO ------------------------------------------
daemon INFO {"level":"info","msg":"Searching tools required for board STMicroelectronics:stm32:GenF1","time":"2022-09-25T22:24:14+01:00"}
{"level":"info","msg":"Required tool","time":"2022-09-25T22:24:14+01:00","tool":{"ToolName":"CMSIS","ToolVersion":"5.7.0","ToolPackager":"STMicroelectronics"}}
{"level":"info","msg":"Required tool","time":"2022-09-25T22:24:14+01:00","tool":{"ToolName":"STM32Tools","ToolVersion":"2.1.1","ToolPackager":"STMicroelectronics"}}
{"level":"info","msg":"Required tool","time":"2022-09-25T22:24:14+01:00","tool":{"ToolName":"xpack-arm-none-eabi-gcc","ToolVersion":"10.3.1-2.3","ToolPackager":"STMicroelectronics"}}
{"dir":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\libraries","level":"info","location":"ide","msg":"Adding libraries dir","time":"2022-09-25T22:24:14+01:00"}
{"dir":"C:\\Users\\piter\\AppData\\Local\\Arduino15\\packages\\STMicroelectronics\\hardware\\stm32\\2.3.0\\libraries","level":"info","location":"platform","msg":"Adding libraries dir","time":"2022-09-25T22:24:14+01:00"}
{"dir":"e:\\Projects\\Electronics\\Arduino sketches\\libraries","level":"info","location":"user","msg":"Adding libraries dir","time":"2022-09-25T22:24:14+01:00"}
daemon INFO {"level":"info","msg":"Resolving include SrcWrapper.h for arch stm32","time":"2022-09-25T22:24:16+01:00"}
{"level":"info","lib":"SrcWrapper","msg":" found better lib","prio":"64C","time":"2022-09-25T22:24:16+01:00"}
root INFO Executing 'arduino.languageserver.notifyBuildDidComplete' with {"buildOutputUri":"file:///c%3A/Users/piter/AppData/Local/Temp/arduino-sketch-7C6358B094B4F1125F7253C8FFABD93C"}
daemon INFO {"level":"info","msg":"Searching tools required for board STMicroelectronics:stm32:GenF1","time":"2022-09-25T22:24:21+01:00"}
{"level":"info","msg":"Required tool","time":"2022-09-25T22:24:21+01:00","tool":{"ToolName":"CMSIS","ToolVersion":"5.7.0","ToolPackager":"STMicroelectronics"}}
{"level":"info","msg":"Required tool","time":"2022-09-25T22:24:21+01:00","tool":{"ToolName":"STM32Tools","ToolVersion":"2.1.1","ToolPackager":"STMicroelectronics"}}
{"level":"info","msg":"Required tool","time":"2022-09-25T22:24:21+01:00","tool":{"ToolName":"xpack-arm-none-eabi-gcc","ToolVersion":"10.3.1-2.3","ToolPackager":"STMicroelectronics"}}
daemon INFO {"level":"info","msg":"Tool required for upload","time":"2022-09-25T22:24:21+01:00","tool":{"version":"5.7.0","systems":[{"os":"i686-mingw32","Resource":{"URL":"https://github.com/stm32duino/ArduinoModule-CMSIS/releases/download/5.7.0/CMSIS-5.7.0.tar.bz2","ArchiveFileName":"CMSIS-5.7.0.tar.bz2","Checksum":"SHA-256:0b04b0f214e483bcc360cda985cddc0de8031714019ceabcda4770d510b82bfe","Size":26151901,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/stm32duino/ArduinoModule-CMSIS/releases/download/5.7.0/CMSIS-5.7.0.tar.bz2","ArchiveFileName":"CMSIS-5.7.0.tar.bz2","Checksum":"SHA-256:0b04b0f214e483bcc360cda985cddc0de8031714019ceabcda4770d510b82bfe","Size":26151901,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/stm32duino/ArduinoModule-CMSIS/releases/download/5.7.0/CMSIS-5.7.0.tar.bz2","ArchiveFileName":"CMSIS-5.7.0.tar.bz2","Checksum":"SHA-256:0b04b0f214e483bcc360cda985cddc0de8031714019ceabcda4770d510b82bfe","Size":26151901,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/stm32duino/ArduinoModule-CMSIS/releases/download/5.7.0/CMSIS-5.7.0.tar.bz2","ArchiveFileName":"CMSIS-5.7.0.tar.bz2","Checksum":"SHA-256:0b04b0f214e483bcc360cda985cddc0de8031714019ceabcda4770d510b82bfe","Size":26151901,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/stm32duino/ArduinoModule-CMSIS/releases/download/5.7.0/CMSIS-5.7.0.tar.bz2","ArchiveFileName":"CMSIS-5.7.0.tar.bz2","Checksum":"SHA-256:0b04b0f214e483bcc360cda985cddc0de8031714019ceabcda4770d510b82bfe","Size":26151901,"CachePath":"packages"}},{"os":"all","Resource":{"URL":"https://github.com/stm32duino/ArduinoModule-CMSIS/releases/download/5.7.0/CMSIS-5.7.0.tar.bz2","ArchiveFileName":"CMSIS-5.7.0.tar.bz2","Checksum":"SHA-256:0b04b0f214e483bcc360cda985cddc0de8031714019ceabcda4770d510b82bfe","Size":26151901,"CachePath":"packages"}}]}}
{"level":"info","msg":"Tool required for upload","time":"2022-09-25T22:24:21+01:00","tool":{"version":"2.1.1","systems":[{"os":"i686-mingw32","Resource":{"URL":"https://github.com/stm32duino/Arduino_Tools/releases/download/2.1.1/STM32Tools-2.1.1-windows.tar.bz2","ArchiveFileName":"STM32Tools-2.1.1-windows.tar.bz2","Checksum":"SHA-256:385f1495a70613ca6771c0f824e420f44e27b1433b0b449aaade1dde63b35e68","Size":2587832,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/stm32duino/Arduino_Tools/releases/download/2.1.1/STM32Tools-2.1.1-mac.tar.bz2","ArchiveFileName":"STM32Tools-2.1.1-mac.tar.bz2","Checksum":"SHA-256:417bc75ebf19060083e29cf65f7a9f71a6903b7fd158c154057ed723c5e847a1","Size":486815,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/stm32duino/Arduino_Tools/releases/download/2.1.1/STM32Tools-2.1.1-linux.tar.bz2","ArchiveFileName":"STM32Tools-2.1.1-linux.tar.bz2","Checksum":"SHA-256:35ecc3914e8a0a45de229111cc45b8cb39a8e0a8c66313562fd51977a7ab3dee","Size":480360,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/stm32duino/Arduino_Tools/releases/download/2.1.1/STM32Tools-2.1.1-linux.tar.bz2","ArchiveFileName":"STM32Tools-2.1.1-linux.tar.bz2","Checksum":"SHA-256:35ecc3914e8a0a45de229111cc45b8cb39a8e0a8c66313562fd51977a7ab3dee","Size":480360,"CachePath":"packages"}}]}}
{"level":"info","msg":"Tool required for upload","time":"2022-09-25T22:24:21+01:00","tool":{"version":"10.3.1-2.3","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://github.com/xpack-dev-tools/arm-none-eabi-gcc-xpack/releases/download/v10.3.1-2.3/xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-arm.tar.gz","ArchiveFileName":"xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-arm.tar.gz","Checksum":"SHA-256:cf152bb008697143b802a85fffffc2c9b562bc1e6d0984ad02d4ee1f1bb91790","Size":169168939,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://github.com/xpack-dev-tools/arm-none-eabi-gcc-xpack/releases/download/v10.3.1-2.3/xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-arm64.tar.gz","ArchiveFileName":"xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-arm64.tar.gz","Checksum":"SHA-256:6e3ee605079ba084836cd057022e16c28605f4068042cd14397976b836ea1a21","Size":174454524,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://github.com/xpack-dev-tools/arm-none-eabi-gcc-xpack/releases/download/v10.3.1-2.3/xpack-arm-none-eabi-gcc-10.3.1-2.3-win32-ia32.zip","ArchiveFileName":"xpack-arm-none-eabi-gcc-10.3.1-2.3-win32-ia32.zip","Checksum":"SHA-256:c98fc443d7ef3524d42a40b6635e8b99c736efac77729f8a70463bb9ba19bc85","Size":180590105,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://github.com/xpack-dev-tools/arm-none-eabi-gcc-xpack/releases/download/v10.3.1-2.3/xpack-arm-none-eabi-gcc-10.3.1-2.3-darwin-x64.tar.gz","ArchiveFileName":"xpack-arm-none-eabi-gcc-10.3.1-2.3-darwin-x64.tar.gz","Checksum":"SHA-256:eb9218eaafb74a05fab9cbbeb49fd4fe7b85c6ba411aefc66f681a5a862e8d8e","Size":173440158,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://github.com/xpack-dev-tools/arm-none-eabi-gcc-xpack/releases/download/v10.3.1-2.3/xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-x64.tar.gz","ArchiveFileName":"xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-x64.tar.gz","Checksum":"SHA-256:559dcf1c2dfddac513110fe23da0ef254032c09967eaa901f075515d51818719","Size":175646740,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://github.com/xpack-dev-tools/arm-none-eabi-gcc-xpack/releases/download/v10.3.1-2.3/xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-ia32.tar.gz","ArchiveFileName":"xpack-arm-none-eabi-gcc-10.3.1-2.3-linux-ia32.tar.gz","Checksum":"SHA-256:8a6621590ac2f0b33fc71f1c501af6b60e900fc3d895a11f20de850cd4f55ca3","Size":179184840,"CachePath":"packages"}}]}}
{"level":"info","msg":"Tool required for upload","time":"2022-09-25T22:24:21+01:00","tool":{"version":"7.3.0-atmel3.6.1-arduino7","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-arm-linux-gnueabihf.tar.bz2","Checksum":"SHA-256:3903553d035da59e33cff9941b857c3cb379cb0638105dfdf69c97f0acc8e7b5","Size":34683056,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:03d322b9df6da17289e9e7c6233c34a8535d9c645c19efc772ba19e56914f339","Size":38045723,"CachePath":"packages"}},{"os":"x86_64-apple-darwin14","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-apple-darwin14.tar.bz2","Checksum":"SHA-256:f6ed2346953fcf88df223469088633eb86de997fa27ece117fd1ef170d69c1f8","Size":36684546,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-w64-mingw32.zip","Checksum":"SHA-256:a54f64755fff4cb792a1495e5defdd789902a2a3503982e81b898299cf39800e","Size":52519412,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:954bbffb33545bcdcd473af993da2980bf32e8461ff55a18e0eebc7b2ef69a4c","Size":37176991,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avr-gcc-7.3.0-atmel3.6.1-arduino7-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:bd8c37f6952a2130ac9ee32c53f6a660feb79bee8353c8e289eb60fdcefed91e","Size":37630618,"CachePath":"packages"}}]}}
{"level":"info","msg":"Tool required for upload","time":"2022-09-25T22:24:21+01:00","tool":{"version":"6.3.0-arduino17","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-armhf-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:2a8e68c5d803aa6f902ef219f177ec3a4c28275d85cbe272962ad2cd374f50d1","Size":219631,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-aarch64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:6cf948f751acfe7b96684537f2291c766ec8b54b4f7dc95539864821456fa9fc","Size":229852,"CachePath":"packages"}},{"os":"x86_64-apple-darwin12","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-apple-darwin12.tar.bz2","Checksum":"SHA-256:120cc9edaae699e7e9ac50b1b8eb0e7d51fdfa555bac54233c2511e6ee5418c9","Size":279045,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:accdfb920af2aabf4f7461d2ac73c0751760f525216dc4e7657427a78c60d13d","Size":254271,"CachePath":"packages"}},{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:5c8cc6c17db9300e1451fe41cd7178b0442b4490ee6fdbc0aed9811aef96c05f","Size":244550,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","ArchiveFileName":"avrdude-6.3.0-arduino17-i686-w64-mingw32.zip","Checksum":"SHA-256:e99188873c7c5ad8f8f906f068c33600e758b2e36cce3adbd518a21bd266749d","Size":328460,"CachePath":"packages"}}]}}
{"level":"info","msg":"Tool required for upload","time":"2022-09-25T22:24:21+01:00","tool":{"version":"1.0.6","systems":[{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.6_Linux_32bit.tar.gz","ArchiveFileName":"mdns-discovery_v1.0.6_Linux_32bit.tar.gz","Checksum":"SHA-256:0bee82c1020e7d5f2b6c89a6f61890c7314f755fb3a1be8d124890f9c43912e4","Size":2395184,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.6_Linux_64bit.tar.gz","ArchiveFileName":"mdns-discovery_v1.0.6_Linux_64bit.tar.gz","Checksum":"SHA-256:7fc938a4d5c3c96e62d071d98b72bbdf45c8f92c399636ba78f8d67c4e78324f","Size":2468081,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.6_Windows_32bit.zip","ArchiveFileName":"mdns-discovery_v1.0.6_Windows_32bit.zip","Checksum":"SHA-256:892b19cd795a22a29f52d94118198134be214cc1e2a75f90ae09b04c6582d2ce","Size":2588028,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.6_Windows_64bit.zip","ArchiveFileName":"mdns-discovery_v1.0.6_Windows_64bit.zip","Checksum":"SHA-256:8f0fa04089c44536360714eb2881b40cf773bf4af17604b6a93b1dab211aa8bc","Size":2633871,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.6_macOS_64bit.tar.gz","ArchiveFileName":"mdns-discovery_v1.0.6_macOS_64bit.tar.gz","Checksum":"SHA-256:211a02f641c9eeb9bd2d8f2efe5f980ec5c2271a224424a60916fac033d65454","Size":2418658,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.6_Linux_ARMv6.tar.gz","ArchiveFileName":"mdns-discovery_v1.0.6_Linux_ARMv6.tar.gz","Checksum":"SHA-256:51be90c06202e8a744909f74076eef05e6d25ac83b7645d1d101981bc79d20d5","Size":2298815,"CachePath":"packages"}},{"os":"arm64-linux-gnueabihf","Resource":{"URL":"https://downloads.arduino.cc/discovery/mdns-discovery/mdns-discovery_v1.0.6_Linux_ARM64.tar.gz","ArchiveFileName":"mdns-discovery_v1.0.6_Linux_ARM64.tar.gz","Checksum":"SHA-256:334ab7f295ff02a98f523b20e1007fb31fab24c064618ac196d2fcbf2ee35dc0","Size":2301721,"CachePath":"packages"}}]}}
{"level":"info","msg":"Tool required for upload","time":"2022-09-25T22:24:21+01:00","tool":{"version":"1.3.2","systems":[{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.3.2_Linux_32bit.tar.gz","ArchiveFileName":"serial-discovery_v1.3.2_Linux_32bit.tar.gz","Checksum":"SHA-256:86890adaedf38bcb62ceba904f94fb383ee7e9524d8d767bf3bb8032f0f4ca3f","Size":1588777,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.3.2_Linux_64bit.tar.gz","ArchiveFileName":"serial-discovery_v1.3.2_Linux_64bit.tar.gz","Checksum":"SHA-256:a18efd5eb4c085131ea2df63c10cb0df0e1b6d0de38761a71e94cb0fa40a08c3","Size":1630523,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.3.2_Windows_32bit.zip","ArchiveFileName":"serial-discovery_v1.3.2_Windows_32bit.zip","Checksum":"SHA-256:03045731c39009d99e1527f4127cc2595e434d923eccef025f5d5fdd82b2803d","Size":1814067,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.3.2_Windows_64bit.zip","ArchiveFileName":"serial-discovery_v1.3.2_Windows_64bit.zip","Checksum":"SHA-256:94ef68fb35d9ffed75f1c46607932d614d3d5b4722faf69487c6d433f7374868","Size":1843894,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.3.2_macOS_64bit.tar.gz","ArchiveFileName":"serial-discovery_v1.3.2_macOS_64bit.tar.gz","Checksum":"SHA-256:369e84d34cdee39277e840e7bdaf8393f3c10eefbd9934c9535cf57c4aaa3b20","Size":1699050,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.3.2_Linux_ARMv6.tar.gz","ArchiveFileName":"serial-discovery_v1.3.2_Linux_ARMv6.tar.gz","Checksum":"SHA-256:89ccc9bd3d22cfc1eec242fe00a34da2cba29c0008eb34d36509aea2c5a2819f","Size":1531250,"CachePath":"packages"}},{"os":"arm64-linux-gnueabihf","Resource":{"URL":"https://downloads.arduino.cc/discovery/serial-discovery/serial-discovery_v1.3.2_Linux_ARM64.tar.gz","ArchiveFileName":"serial-discovery_v1.3.2_Linux_ARM64.tar.gz","Checksum":"SHA-256:3209edd3dd783d6d9b8c7957a83fb0315648b9c45b916c6a8297d2e247816206","Size":1531863,"CachePath":"packages"}}]}}
{"level":"info","msg":"Tool required for upload","time":"2022-09-25T22:24:21+01:00","tool":{"version":"5.8-arduino11","systems":[{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-i686-pc-linux-gnu.tar.bz2","ArchiveFileName":"ctags-5.8-arduino11-pm-i686-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:3e219116f54d9035f6c49c600d0bb358710dcce139798ad237de0eef7998d0e2","Size":106930,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-x86_64-pc-linux-gnu.tar.bz2","ArchiveFileName":"ctags-5.8-arduino11-pm-x86_64-pc-linux-gnu.tar.bz2","Checksum":"SHA-256:62b514f3aaf37b5429ef703853bb46365fb91b4754c1916d085bf134004886e3","Size":111604,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-i686-mingw32.zip","ArchiveFileName":"ctags-5.8-arduino11-pm-i686-mingw32.zip","Checksum":"SHA-256:106c9f074a3e2ec55bd8a461c1522bb4c90488275f061c3d51942862c99b8ba7","Size":116455,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-x86_64-apple-darwin.zip","ArchiveFileName":"ctags-5.8-arduino11-pm-x86_64-apple-darwin.zip","Checksum":"SHA-256:bf74807260ddf0e1fc94d67e9cd8a41b7c0a2f0bee03e254e6975139b37ef250","Size":118296,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-armv6-linux-gnueabihf.tar.bz2","ArchiveFileName":"ctags-5.8-arduino11-pm-armv6-linux-gnueabihf.tar.bz2","Checksum":"SHA-256:098e8dc6a7dc0ddf09ef28e6e2e81d2ae181d12f41fb182dd78ff1387d4eb285","Size":95271,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"https://downloads.arduino.cc/tools/ctags-5.8-arduino11-pm-aarch64-linux-gnu.tar.bz2","ArchiveFileName":"ctags-5.8-arduino11-pm-aarch64-linux-gnu.tar.bz2","Checksum":"SHA-256:89b6f8adb7b7124ebe2eb30970ea77c754cd2239e0d8a6b0102ae2a36416c6ef","Size":100819,"CachePath":"packages"}}]}}
{"level":"info","msg":"Tool required for upload","time":"2022-09-25T22:24:21+01:00","tool":{"version":"4.8.3-2014q1","systems":[{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/gcc-arm-none-eabi-4.8.3-2014q1-arm.tar.bz2","ArchiveFileName":"gcc-arm-none-eabi-4.8.3-2014q1-arm.tar.bz2","Checksum":"SHA-256:ebe96b34c4f434667cab0187b881ed585e7c7eb990fe6b69be3c81ec7e11e845","Size":44423906,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/gcc-arm-none-eabi-4.8.3-2014q1-windows.tar.gz","ArchiveFileName":"gcc-arm-none-eabi-4.8.3-2014q1-windows.tar.gz","Checksum":"SHA-256:fd8c111c861144f932728e00abd3f7d1107e186eb9cd6083a54c7236ea78b7c2","Size":84537449,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"http://downloads.arduino.cc/gcc-arm-none-eabi-4.8.3-2014q1-mac.tar.gz","ArchiveFileName":"gcc-arm-none-eabi-4.8.3-2014q1-mac.tar.gz","Checksum":"SHA-256:3598acf21600f17a8e4a4e8e193dc422b894dc09384759b270b2ece5facb59c2","Size":52518522,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/gcc-arm-none-eabi-4.8.3-2014q1-linux64.tar.gz","ArchiveFileName":"gcc-arm-none-eabi-4.8.3-2014q1-linux64.tar.gz","Checksum":"SHA-256:d23f6626148396d6ec42a5b4d928955a703e0757829195fa71a939e5b86eecf6","Size":51395093,"CachePath":"packages"}},{"os":"i686-pc-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/gcc-arm-none-eabi-4.8.3-2014q1-linux32.tar.gz","ArchiveFileName":"gcc-arm-none-eabi-4.8.3-2014q1-linux32.tar.gz","Checksum":"SHA-256:ba1994235f69c526c564f65343f22ddbc9822b2ea8c5ee07dd79d89f6ace2498","Size":51029223,"CachePath":"packages"}}]}}
{"level":"info","msg":"Tool required for upload","time":"2022-09-25T22:24:21+01:00","tool":{"version":"1.3.0","systems":[{"os":"i686-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_386.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_386.tar.bz2","Checksum":"SHA-256:3e7f59d6fbc7a724598303f0d3289d0c4fd137a8973437980658379a024887b2","Size":2633516,"CachePath":"packages"}},{"os":"x86_64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_amd64.tar.bz2","Checksum":"SHA-256:aa45ee2441ffc3a122daec5802941d1fa2ac47adf5c5c481b5e0daa4dc259ffa","Size":2716248,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm.tar.bz2","Checksum":"SHA-256:1888587409b56aef4ba0ab0e6703b3dccba7cc3a022756ba9b908247e5d5a656","Size":2567435,"CachePath":"packages"}},{"os":"aarch64-linux-gnu","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-linux_arm64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-linux_arm64.tar.bz2","Checksum":"SHA-256:835ed8f37cffac37e979d1b0f6041559592d3d98be52f0e8611b76c4858e4113","Size":2472427,"CachePath":"packages"}},{"os":"i386-apple-darwin11","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-darwin_amd64.tar.bz2","ArchiveFileName":"arduinoOTA-1.3.0-darwin_amd64.tar.bz2","Checksum":"SHA-256:d5d0f82ff829c0e434d12a2ee640a6fbd78f893ab37782edbb8b5bf2359d119e","Size":2766116,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"http://downloads.arduino.cc/tools/arduinoOTA-1.3.0-windows_386.zip","ArchiveFileName":"arduinoOTA-1.3.0-windows_386.zip","Checksum":"SHA-256:051943844eee442460d2c709edefadca184287fffd2b6c100dd53aa742aa05f6","Size":2768948,"CachePath":"packages"}}]}}
{"level":"info","msg":"Tool required for upload","time":"2022-09-25T22:24:21+01:00","tool":{"version":"2021.2.27","systems":null}}
{"level":"info","msg":"Tool required for upload","time":"2022-09-25T22:24:21+01:00","tool":{"version":"0.10.0","systems":[{"os":"i686-pc-linux-gnu","Resource":{"URL":"https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.10.0_Linux_32bit.tar.gz","ArchiveFileName":"serial-monitor_v0.10.0_Linux_32bit.tar.gz","Checksum":"SHA-256:6a43e7adeea8a5cf8dc9d9e29c517c0e50473ed0ca12bdec71aacd1d4d6dfb55","Size":1933674,"CachePath":"packages"}},{"os":"x86_64-pc-linux-gnu","Resource":{"URL":"https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.10.0_Linux_64bit.tar.gz","ArchiveFileName":"serial-monitor_v0.10.0_Linux_64bit.tar.gz","Checksum":"SHA-256:14c26e3fbe372d5d49423a359f77e759bb04d5257f5abebe978b425e99899230","Size":1982657,"CachePath":"packages"}},{"os":"i686-mingw32","Resource":{"URL":"https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.10.0_Windows_32bit.zip","ArchiveFileName":"serial-monitor_v0.10.0_Windows_32bit.zip","Checksum":"SHA-256:829665a8a2785f75c208f17d5727d7a7b430b2d21066320ccd71fd9edd81621b","Size":1962322,"CachePath":"packages"}},{"os":"x86_64-mingw32","Resource":{"URL":"https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.10.0_Windows_64bit.zip","ArchiveFileName":"serial-monitor_v0.10.0_Windows_64bit.zip","Checksum":"SHA-256:475d37bafb4162e1262d865c2a96d284c93e13c9b69824b6f98b82e99927f1ff","Size":1992824,"CachePath":"packages"}},{"os":"x86_64-apple-darwin","Resource":{"URL":"https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.10.0_macOS_64bit.tar.gz","ArchiveFileName":"serial-monitor_v0.10.0_macOS_64bit.tar.gz","Checksum":"SHA-256:ff66a542f3019b763e0e9c0c39147d92aa0b9a88e9abf293c5307052ce29ad5f","Size":1880624,"CachePath":"packages"}},{"os":"arm-linux-gnueabihf","Resource":{"URL":"https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.10.0_Linux_ARMv6.tar.gz","ArchiveFileName":"serial-monitor_v0.10.0_Linux_ARMv6.tar.gz","Checksum":"SHA-256:5d70865edcfef27d4f532f5ae9a3663f2c82b9cfd03cec3c140bb3b8174794e1","Size":1864090,"CachePath":"packages"}},{"os":"arm64-linux-gnueabihf","Resource":{"URL":"https://downloads.arduino.cc/monitor/serial-monitor/serial-monitor_v0.10.0_Linux_ARM64.tar.gz","ArchiveFileName":"serial-monitor_v0.10.0_Linux_ARM64.tar.gz","Checksum":"SHA-256:63ebf7ed642b0c03f77822876531a59aaea47415abd5b54e90c2f50e80b74cde","Size":1865509,"CachePath":"packages"}}]}}
daemon INFO {"level":"info","msg":"Searching tools required for board STMicroelectronics:stm32:GenF1","time":"2022-09-25T22:24:22+01:00"}
{"level":"info","msg":"Required tool","time":"2022-09-25T22:24:22+01:00","tool":{"ToolName":"CMSIS","ToolVersion":"5.7.0","ToolPackager":"STMicroelectronics"}}
{"level":"info","msg":"Required tool","time":"2022-09-25T22:24:22+01:00","tool":{"ToolName":"STM32Tools","ToolVersion":"2.1.1","ToolPackager":"STMicroelectronics"}}
daemon INFO {"level":"info","msg":"Required tool","time":"2022-09-25T22:24:22+01:00","tool":{"ToolName":"xpack-arm-none-eabi-gcc","ToolVersion":"10.3.1-2.3","ToolPackager":"STMicroelectronics"}}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: COM19","time":"2022-09-25T22:24:24+01:00"}
daemon INFO {"level":"info","msg":"from discovery builtin:serial-discovery received message type: add, port: COM19","time":"2022-09-25T22:24:25+01:00"}
discovery-log INFO {"eventType":"add","port":{"matchingBoardsList":[],"port":{"address":"COM19","label":"COM19","protocol":"serial","protocolLabel":"Serial Port (USB)","propertiesMap":[["pid","0x5740"],["serialNumber","6D7644954948"],["vid","0x0483"]]}},"error":""}
root INFO - New port is available on COM19 Serial Port (USB)
root ERROR ---- !!!SLOW!!! DURATION: installed took 127.734 ms. Args: [{"fqbn":"STMicroelectronics:stm32:GenF1"}] ----
monitor-service INFO starting monitor
daemon INFO {"level":"info","monitor":"serial-monitor","msg":"Starting monitor process","time":"2022-09-25T22:24:25+01:00"}
daemon INFO {"level":"info","monitor":"serial-monitor","msg":"Monitor process started successfully!","time":"2022-09-25T22:24:26+01:00"}
{"command":"HELLO 1 \"arduino-cli 0.27.1\"","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-09-25T22:24:26+01:00"}
daemon INFO {"error":false,"event_type":"hello","level":"info","message":"OK","monitor":"serial-monitor","msg":"received message","time":"2022-09-25T22:24:26+01:00"}
daemon INFO {"command":"DESCRIBE","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-09-25T22:24:26+01:00"}
daemon INFO {"error":false,"event_type":"describe","level":"info","message":"OK","monitor":"serial-monitor","msg":"received message","time":"2022-09-25T22:24:26+01:00"}
daemon INFO {"command":"QUIT","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-09-25T22:24:26+01:00"}
daemon INFO {"error":false,"event_type":"quit","level":"info","message":"OK","monitor":"serial-monitor","msg":"received message","time":"2022-09-25T22:24:26+01:00"}
{"level":"info","monitor":"serial-monitor","msg":"Killing monitor process","time":"2022-09-25T22:24:26+01:00"}
{"error":"TerminateProcess: Access is denied.","level":"error","monitor":"serial-monitor","msg":"Sent kill signal","time":"2022-09-25T22:24:26+01:00"}
daemon INFO {"level":"error","monitor":"serial-monitor","msg":"stopped decode loop: EOF","time":"2022-09-25T22:24:26+01:00"}
daemon INFO {"level":"info","monitor":"serial-monitor","msg":"Killing monitor process","time":"2022-09-25T22:24:26+01:00"}
daemon INFO {"error":"TerminateProcess: Access is denied.","level":"error","monitor":"serial-monitor","msg":"Sent kill signal","time":"2022-09-25T22:24:26+01:00"}
daemon INFO {"level":"info","monitor":"serial-monitor","msg":"Monitor process killed","time":"2022-09-25T22:24:26+01:00"}
daemon INFO {"level":"info","monitor":"serial-monitor","msg":"Starting monitor process","time":"2022-09-25T22:24:26+01:00"}
{"command":"CONFIGURE dtr on","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-09-25T22:24:26+01:00"}
{"error":false,"event_type":"configure","level":"info","message":"OK","monitor":"serial-monitor","msg":"received message","time":"2022-09-25T22:24:26+01:00"}
{"command":"CONFIGURE parity none","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-09-25T22:24:26+01:00"}
daemon INFO {"error":false,"event_type":"configure","level":"info","message":"OK","monitor":"serial-monitor","msg":"received message","time":"2022-09-25T22:24:26+01:00"}
{"command":"CONFIGURE rts on","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-09-25T22:24:26+01:00"}
{"command":"CONFIGURE stop_bits 1","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-09-25T22:24:26+01:00"}
daemon INFO {"command":"CONFIGURE baudrate 9600","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-09-25T22:24:26+01:00"}
{"command":"CONFIGURE bits 8","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-09-25T22:24:26+01:00"}
daemon INFO {"command":"OPEN 127.0.0.1:26055 COM19","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-09-25T22:24:26+01:00"}
daemon INFO {"command":"QUIT","level":"info","monitor":"serial-monitor","msg":"sending command","time":"2022-09-25T22:24:36+01:00"}
daemon INFO {"level":"info","monitor":"serial-monitor","msg":"Killing monitor process","time":"2022-09-25T22:24:36+01:00"}
[3464:0925/222450.478:ERROR:gpu_init.cc(453)] Passthrough is not supported, GL is disabled, ANGLE is
monitor-service WARN failed starting monitor to COM19 using serial
daemon INFO {"level":"error","monitor":"serial-monitor","msg":"stopped decode loop: EOF","time":"2022-09-25T22:24:56+01:00"}
daemon INFO {"error":"exit status 1","level":"error","monitor":"serial-monitor","msg":"Waiting for process end","time":"2022-09-25T22:24:56+01:00"}
{"level":"info","monitor":"serial-monitor","msg":"Monitor process killed","time":"2022-09-25T22:24:56+01:00"}
monitor-service ERROR Error: 2 UNKNOWN: Port monitor error: timeout waiting for message
at Object.callErrorFromStatus (C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\call.js:31:26)
at Object.onReceiveStatus (C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\client.js:409:49)
at Object.onReceiveStatus (C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\client-interceptors.js:328:181)
at C:\Users\piter\AppData\Local\Programs\Arduino IDE\resources\app\node_modules\@grpc\grpc-js\build\src\call-stream.js:187:78
at processTicksAndRejections (node:internal/process/task_queues:78:11)
monitor-service INFO monitor to COM19 using serial closed by server
monitor-service INFO monitor to COM19 using serial closed by client
