control 2*8x8 LED matrix by 3*74HC595N
I used three 74HC595N to control two 8x8 LED matrix and its work. For more, I would like to expend the LED from 2 to 10, like a 80x8 LED stick. So that, I had been tried to expend my program from 2 to 10. However, I discovered that the frequency of LED is too low which occurred flashing but the delay time going to the lowest - 30us(not work if lower that 30us). How can I fix it?
Here is the code before change:
int latchPin1 = 2;
int clockPin1 = 4;
int dataPin1 = 3;
int latchPin2 = 5;
int clockPin2 = 7;
int dataPin2 = 6;
int words[3][5]={
{124,18,17,18,124},
{127,73,73,73,54},
{62,65,65,65,34}
char msg = “ABCCBA”;
int length;
int i;
int j;
int k=0;
int get;
int msgCode[20];
int msgCode2[120];
get=msg[0];
while(get!=0) {
get=msg*;*
  • if(get==0) {*
  • length=i;*
  • Serial.print(length);*
  • Serial.print("\n");*
  • break;*
    _ msgCode*=get;_
    _ Serial.print(msgCode);
    Serial.print(" = “);
    for(int j=0; j<=4; j++) {
    msgCode2[i*6+j]=words[msgCode-65][j];
    Serial.print(msgCode2[i*6+j]);
    Serial.print(”, “);
    i++;
    msgCode2[i*6-1]=0;
    Serial.print(msgCode2[i*6-1]);
    Serial.print(”\n");
    for(int i=0; i<=length6-1; i++) {
    Serial.print(msgCode2*);
    Serial.print(", ");
    for(int i=0; i<=7; i++) {
    msgCode2[length6+i]=0;
    length+=1;
    int massageCode={124,18,17,18,124};
    pinMode(latchPin1, OUTPUT);
    pinMode(clockPin1, OUTPUT);
    pinMode(dataPin1, OUTPUT);
    pinMode(latchPin2, OUTPUT);
    pinMode(clockPin2, OUTPUT);
    pinMode(dataPin2, OUTPUT);
    for(int j=0; j<=7; j++) {
    digitalWrite(latchPin1, LOW);
    digitalWrite(latchPin2, LOW);
    shiftOut(dataPin1, clockPin1, MSBFIRST, msgCode2[j]);//data per column*
    * shiftOut(dataPin2, clockPin2, MSBFIRST, 255);//display blank in LED matrix 2*
    * shiftOut(dataPin2, clockPin2, MSBFIRST, 255-(1<<j));//display some pattern in LED matrix 1*
    * digitalWrite(latchPin1, HIGH);
    digitalWrite(latchPin2, HIGH);
    delayMicroseconds(500);
    shiftOut(dataPin1, clockPin1, MSBFIRST, msgCode2[j+8]);//data per column*
    * shiftOut(dataPin2, clockPin2, MSBFIRST, 255-(1<<j));//display some pattern in LED matrix 2*
    * shiftOut(dataPin2, clockPin2, MSBFIRST, 255);//display blank in LED matrix 1*
    k++;
    if(k==20) {
    int msgCode3=msgCode2[0];
    for(int l=0; l<=length6-2; l++) {
    * msgCode2[l]=msgCode2[l+1];
    msgCode2[length6-1]=msgCode3;
    * k=0;
    }[/quote]
    How about 10 LED matrix? This is the display command for last LED matrix only! It will be lag if copy and paste it 10 times:
    > shiftOut(dataPin2, clockPin2, MSBFIRST, 255-(1<<j));//display some pattern in LED matrix 10
    > shiftOut(dataPin2, clockPin2, MSBFIRST, 255);//display blank in LED matrix 9
    > shiftOut(dataPin2, clockPin2, MSBFIRST, 255);//display blank in LED matrix 8
    > shiftOut(dataPin2, clockPin2, MSBFIRST, 255);//display blank in LED matrix 7
    > shiftOut(dataPin2, clockPin2, MSBFIRST, 255);//display blank in LED matrix 6
    > shiftOut(dataPin2, clockPin2, MSBFIRST, 255);//display blank in LED matrix 5
    > shiftOut(dataPin2, clockPin2, MSBFIRST, 255);//display blank in LED matrix 4
    > shiftOut(dataPin2, clockPin2, MSBFIRST, 255);//display blank in LED matrix 3
    > delayMicroseconds(30);
    > }_
Use SPI instead of shiftOut.
This post may help... http://arduino.cc/forum/index.php?topic=38155.0;wap2
