Hi
i want to control 2led with one pushbutton so when i click the pushbutton the two led turn on and when click the pushbutton again led1 turn off and led2 turn off after 5 sec so please what the code will be
Hi
If you find a website where you can just ask people to write code for you for free, please let me know!
Please read this first: How to use this forum
Pieter
Untested code. Written from minimal specs, with lots of assumptions. Use at your own risk.
Assumptions:
LEDs are wired to pins 2 and 3, with current limiting resistors.
Push button is wired between pin 4 and ground.
You don't care if the button is held down for more than 5 seconds. It will immediately turn the LEDs back on.
The Arduino doesn't have anything else useful to do. Delays and spin loops are used with no excuses.
const byte led1Pin = 2; // Modifiy these to the pins you are using.
const byte led2Pin = 3;
const byte pushButtonPin = 4; // Using internal pull-up.
pinMode(ledPin1, OUTPUT);
digitalWrite(led1Pin, LOW); // Start the LEDs off
pinMode(led2Pin, OUTPUT);
digitalWrite(led2Pin, LOW);
pinMode(pushButtonPin, INPUT_PULLUP);
while (digitalRead(pushButtonPin) == HIGH); // Wait for first button press
digitalWrite(led1Pin, HIGH); // Turn on both LEDs
digitalWrite(led2Pin, HIGH);
delay(20); // debounce
while (digitalRead(pushButtonPin) == LOW); // Wait for first button release
while (digitalRead(pushButtonPin) == HIGH); // Wait for second button press
digitalWrite(led1Pin, LOW); // Turn off first LED
delay(5000); // Wait 5 seconds
digitalWrite(led2pin, LOW); // Turn off second LED
