Hey guys,
I have a cytron dual motor control and I was wonder if it possible to control more than one motor with a pwm signal. The motor controller test code uses a direction and pwm pins and then I am splitting the two pins on the arduino to the four pins on the motor controller board. Will this damage my boards?
here is the test code sample and here is the motor control board I am using 10Amp 5V-30V DC Motor Driver (2 Channels)
This example shows how to drive a motor using the PWM and DIR pins.
This example only shows how to drive a single motor for simplicity.
For dual channel motor driver, both channel work the same way.
CONNECTIONS:
Arduino D3 - Motor Driver PWM Input
Arduino D4 - Motor Driver DIR Input
Arduino GND - Motor Driver GND
AUTHOR : Kong Wai Weng
COMPANY : Cytron Technologies Sdn Bhd
WEBSITE : www.cytron.io
EMAIL : support@cytron.io
#include "CytronMotorDriver.h"
// Configure the motor driver.
CytronMD motor(PWM_DIR, 3, 4); // PWM = Pin 3, DIR = Pin 4.
// The setup routine runs once when you press reset.
// The loop routine runs over and over again forever.
motor.setSpeed(128); // Run forward at 50% speed.
delay(100);
motor.setSpeed(255); // Run forward at full speed.
delay(100);
motor.setSpeed(0); // Stop.
delay(100);
motor.setSpeed(-128); // Run backward at 50% speed.
delay(100);
motor.setSpeed(-255); // Run backward at full speed.
delay(100);
delay(1003);
