Control 2 servos with Serial Monitor
Hi, I’m trying to create a system in which I input into the serial monitor 2 angular coordinates( e.g. (178. 45)) and the ardunio will set 2 servos, one to the x coordinate and another to the y coordinate. Until now, I have found some code that allows me to do it with one servo, but I can’t figure out how to modify it to input (x,y) and the Arduino will identify two numbers x and y.
My code until now:
String readString;
#include <Servo.h>
Servo myservo; // create servo object to control a servo
myservo.writeMicroseconds(1500); //set initial servo position if desired
myservo.attach(9); //the pin for the servo control, and range if desired
Serial.println(“STARTING LTELESCOPE POSITIONING SYSTEM”); // so I can keep track of what is loaded
while (Serial.available()) {
char c = Serial.read(); //gets one byte from serial buffer
readString += c; //makes the string readString
delay(2); //slow looping to allow buffer to fill with next character
if (readString.length() >0) {
Serial.println(readString); //so you can see the captured string
int n = readString.toInt(); //convert readString into a number
// auto select appropriate value, copied from someone elses code.
if(n >= 500)
Serial.print("writing Microseconds: ");
Serial.println(n);
myservo.writeMicroseconds(n);
Serial.print("writing Angle: ");
Serial.println(n);
myservo.write(n);
Serial.print(“Last servo command position: “);
Serial.println(myservo.read());
readString=””; //empty for next input
Thanks
Forget then stupid String class. You have some idea how long the data stream will be. After all, it hardly makes sense to send 1298.333333333, 67.9988466644626663 to control two servos that need integer values.
So, create a char array that is large enough to hold the expected data and a NULL terminator. Store the data as it arrives, appending a NULL after each character, until the end of packet marker arrives. Then, use strtok() and atoi() to parse and convert the string to useful data.
Servo test code for more than one servo.
//zoomkat 11-22-12 simple delimited ',' string parse
//from serial port input (via serial monitor)
//and print result out serial port
//multi servos added
String readString;
#include <Servo.h>
Servo myservoa, myservob, myservoc, myservod;  // create servo object to control a servo
  //myservoa.writeMicroseconds(1500); //set initial servo position if desired
  myservoa.attach(6);  //the pin for the servoa control
  myservob.attach(7);  //the pin for the servob control
  myservoc.attach(8);  //the pin for the servoc control
  myservod.attach(9);  //the pin for the servod control
  Serial.println("multi-servo-delimit-test-dual-input-11-22-12"); // so I can keep track of what is loaded
  //expect single strings like 700a, or 1500c, or 2000d,
  //or like 30c, or 90a, or 180d,
  //or combined like 30c,180b,70a,120d,
  if (Serial.available())  {
    if (c == ',') {
      if (readString.length() >1) {
        Serial.println(readString); //prints string to serial port out
        if(n >= 500)
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.writeMicroseconds(n);
          if(readString.indexOf('b') >0) myservob.writeMicroseconds(n);
          if(readString.indexOf('c') >0) myservoc.writeMicroseconds(n);
          if(readString.indexOf('d') >0) myservod.writeMicroseconds(n);
          Serial.println(n);
          if(readString.indexOf('a') >0) myservoa.write(n);
          if(readString.indexOf('b') >0) myservob.write(n);
          if(readString.indexOf('c') >0) myservoc.write(n);
          if(readString.indexOf('d') >0) myservod.write(n);
         readString=""; //clears variable for new input
    else {
