Hi all,
I am new in this forum and also in arduino coding. Right now I have made a Star Tracker using 28byj48 stepper motor, arduino nano and some gears. Its basic function is its shaft rotates 1 revolution/24 hrs with a load of a camera (2.5kg).
It has 3 buttons to control its rotation speed (fast, slow, stop). I have written a code to run it properly with stepper.h library with the help of some nice guys.
But now I found that AccelStepper.h library can run this motor more smoothly with more power. Can you please help me to modify this code to run the stepper with AccelStepper.h library? And also, to display its current speed in a LCD display board?
Thanks in advance.
The code is as follows:
#include <Stepper.h>
//ULN2003
const int speedPBInc =2;//define input pin
const int stopPB=3;//define input pin for Stop push button
const int speedPBDec =4;//define input pin
const int motorPin[] ={8, 10, 9, 11};
const int direction =0;//0 for CW, 1 for CCW;
const int stepsPerRevolution = 200; // change this to fit the number of steps per revolution
int speedStep = 1;
int stepMinimum = 40;
int stepMaximum = 161;
int stopType =0;//0=fully stopped , 1=hold (consumes energy)
int currentSpeed=115;
int currentSPR=stepsPerRevolution;
#define START 1 //
#define STOP 0
#define CW 1
#define CCW -1
#define MotorInterfaceType 8
int motorStopState=START;//change if you need to
// initialize the stepper library on pins 8 through 11:
Stepper myStepper(stepsPerRevolution, motorPin[0], motorPin[1], motorPin[2], motorPin[3]);
myStepper.setSpeed(115);
// initialize the serial port:
pinMode(speedPBInc, INPUT_PULLUP);
pinMode(stopPB,INPUT_PULLUP);
pinMode(speedPBDec,INPUT_PULLUP);
//attachInterrupt(digitalPinToInterrupt(stopPB), stopMotor, FALLING);
updateState();
if(!motorStopState)
currentSPR =0;
}else{
currentSPR =stepsPerRevolution;
myStepper.setSpeed(currentSpeed);
if(direction ==1)
myStepper.step(-currentSPR);
}else{
myStepper.step(currentSPR);
}//loop
void updateState()
if(digitalRead(stopPB) ==LOW)
motorStopState =1-motorStopState;// stop the motor
if(motorStopState ==STOP)
stopMotor();
if(digitalRead(speedPBInc) ==LOW)
motorStopState = START;
currentSpeed += speedStep;
if( currentSpeed >=stepMaximum ) currentSpeed =stepMaximum ;
if(digitalRead(speedPBDec) ==LOW)
currentSpeed -= speedStep;
if( currentSpeed <stepMinimum ) currentSpeed =stepMinimum ;
}//updateState end
void stopMotor()
if(stopType ==0)
for(int i=0; i<4; i++)
digitalWrite(motorPin[i], LOW);
