blh64:
Please post your entire sketch
//---------Fuzzy 2.1 prelauch----------
//-----iNPUT SETPOINT-------
float inputec;
float inputph;
//----INPUT ERROR---------------
float ph;
float hasilec;
//----------fuzzy declare-------------
#include <Fuzzy.h>
Fuzzy *fuzzy = new Fuzzy();
//----fuzzy input Error pH-----
FuzzySet *LN = new FuzzySet(-2, -2, -1.5, -1);
FuzzySet *FN = new FuzzySet(-1.5, -1, -1, -0.5);
FuzzySet *SN = new FuzzySet(-1, -0.5, -0.5, 0);
FuzzySet *ZERO01 = new FuzzySet(-0.5, 0, 0, 0.5);
FuzzySet *sp = new FuzzySet(0, 0.5, 0.5, 1);
FuzzySet *FP = new FuzzySet(0.5, 1, 1, 1.5);
FuzzySet *LP = new FuzzySet(1, 1.5, 2, 2);
//----Fuzzy input error EC----
FuzzySet *N6 = new FuzzySet(-2, -2, -1.8, -1.6);
FuzzySet *N5 = new FuzzySet(-1.8, -1.6, -1.6, -1.4);
FuzzySet *N4 = new FuzzySet(-1.6, -1.3, -1.3, -1);
FuzzySet *N3 = new FuzzySet(-1.2, -1, -1, -0.8);
FuzzySet *N2 = new FuzzySet(-1, -0.7, -0.7, -0.4);
FuzzySet *N1 = new FuzzySet(-0.6, -0.4, -0.4, -0.2);
FuzzySet *ZERO02 = new FuzzySet(-0.4, -0.2, 0, 0);
//----Fuzzy Output phD-----
FuzzySet *ZERO1 = new FuzzySet(0, 0, 0, 2);
FuzzySet *SEBENTAR1 = new FuzzySet(10, 20, 20, 30);
FuzzySet *SEDANG1 = new FuzzySet(20, 30, 40, 50);
FuzzySet *LAMA1 = new FuzzySet(40, 50, 60, 60);
//---Fuzzy Output phU------
FuzzySet *ZERO2 = new FuzzySet(0, 0, 0, 2);
FuzzySet *SEBENTAR2 = new FuzzySet(5, 10, 10, 15);
FuzzySet *SEDANG2 = new FuzzySet(10, 15, 20, 25);
FuzzySet *LAMA2 = new FuzzySet(20, 25, 30, 30);
//---Fuzzy Output ABMIX------
FuzzySet *ZERO3 = new FuzzySet(0, 0, 0, 2);
FuzzySet *SEBENTAR3 = new FuzzySet(20, 40, 40, 60);
FuzzySet *SEDANG3 = new FuzzySet(40, 60, 80, 100);
FuzzySet *LAMA3 = new FuzzySet(80, 100, 120, 120);
//---------- EC declare---------------
#include <Wire.h>
#include "DFRobot_EC10.h"
#include <EEPROM.h>
int EC_PIN = A2;
float voltage, ecValue, temperature = 25;
DFRobot_EC10 ec;
//-----------PPM declare --------------
#include <EEPROM.h>
#include "GravityTDS.h"
#define TdsSensorPin A1
GravityTDS gravityTds;
float temperatureppm = 25;
float tdsValue = 0;
//--------------pH declare---------------
#include <Wire.h>
#include <EEPROM.h>
float ph_H;
int pHSense = A0;
int samples = 5;
float adc_resolution = 1024.0;
//---------POMPA-----------
int pump1 = 5;//pin D5
int pump2 = 6;//pin D6
int pump3 = 7;//pin D7
float pompa1;
float pompa2;
float pompa3;
unsigned long prev_pump1 = 0;
unsigned long prev_pump2 = 0;
unsigned long prev_pump3 = 0;
unsigned long initiate_start = 0;
int pump_state1 = false;
int pump_state2 = false;
int pump_state3 = false;
//-------Deklarasi Fungsi--------
#include "Fuzzy_Rules.h"
#include "Fuzzy_Set.h"
#include "PH.h"
#include "TDS.h"
//----FUZZY INITIATE-------
sets();
rules();
//-----PH INITIATE---------
//-----PPM INITIATE----------
gravityTds.setPin(TdsSensorPin);
gravityTds.setAref(5.0); //reference voltage on ADC, default 5.0V on Arduino UNO
gravityTds.setAdcRange(1024); //1024 for 10bit ADC;4096 for 12bit ADC
gravityTds.begin(); //initialization
//-----Pin Output-----
pinMode(pump1, OUTPUT);// Ph Up
pinMode(pump2, OUTPUT);// Ph Down
pinMode(pump3, OUTPUT);// AB-MIX
//---normally open------
digitalWrite(pump1, LOW); // Ph Up
digitalWrite(pump2, LOW); // Ph Down
digitalWrite(pump3, LOW); // AB-MIX
//-------------Fungsi Read sensor-----------
hasilppm();
ph_s();
ph = inputph-ph_H;
hasilec = inputec - tdsValue;
hasilec = random(-200, 0) / 100.0;
ph = random(-200, 200) / 100.0;
Serial.print("pH ");
Serial.print(ph);
Serial.print(" ");
Serial.print("EC ");
Serial.print(hasilec);
Serial.println("");
Serial.print(ph); Serial.print(" ");
Serial.print(hasilec); Serial.print(" ");
Serial.println(" ");
fuzzy->setInput(2, hasilec);
fuzzy->setInput(1, ph);
fuzzy->fuzzify();
float pompa1 = fuzzy->defuzzify(1);//pHDOWN
float pompa2 = fuzzy->defuzzify(2);//pHUP
float pompa3 = fuzzy->defuzzify(3);//ABMIX
//-----------PUMP ALGORITHM--------------------
long int pompa01 = pompa1*1000;//interval pump1
long int pompa02 = pompa2*1000;//interval pump2
long int pompa03 = pompa3*1000;//interval pump2
unsigned long intiate_start = millis();
//pompa1
if(intiate_start-prev_pump1 > pompa01)
pump_state1 = !pump_state1;
if(pump_state1)
digitalWrite(pump1, HIGH);
prev_pump1 = initiate_start;
//pompa2
if(intiate_start-prev_pump2 > pompa02)
pump_state2 = !pump_state2;
if(pump_state2)
digitalWrite(pump2, HIGH);
prev_pump2 = initiate_start;
//pompa3
if(intiate_start-prev_pump3 > pompa03)
pump_state3 = !pump_state3;
if(pump_state3)
digitalWrite(pump3, HIGH);
prev_pump3 = initiate_start;
Serial.println("Result= ");
Serial.println("");
Serial.print(" Pompa1 pHDOWN: ");
Serial.println(pompa01);
Serial.print(" pompa2 phUP : ");
Serial.println(pompa02);
Serial.print(" pompa3 ABMIX : ");
Serial.println(pompa03);
Serial.println("");
Serial.println("");
Serial.println("");
delay (2000);
