Control 32x32 LED matrix with Processing
Hi, I have a 32x32 array in Processing with some arbitrary functions. How do I display what I created in Processing on my 32x32 LED RGB matrix via the arduino uno?
The Processing code is show below:
int a,sCol,b;
    int red = color(255,0,0);
    int green = color(0,255,0);
    int blue = color(0,0,255);
    int yellow = color(255,247,3);
    int cols = 32;
    int rows = 32;
    MyRect[][] grid = new MyRect[cols][rows];
      size (1000,800);
      smooth();
      for (int i =0; i < cols; i++) {
        for ( int j = 0; j< rows; j++) {
          grid[i][j] = new MyRect (i*21+20,j*21+20,20,20,i,j);
    void draw() {
      background(#BCBCB8);
      noFill();
      stroke(0);
      rect(780,10,190,600);
      String s = "  Colour Pallet";
      stroke(#FFFFFC);
      fill(#9625E3);
      textSize(20);
      text( s, 800,40);
      String s1 = "Selected Colour";
      stroke(#FFFFFC);
      fill(#9625E3);
      textSize(20);
      text( s1, 800,330);
       String z = "LED property controller";
       stroke(#FFFFFC);
       fill(#9625E3);
       textSize(25);
       text( z, 220,720);
      fill(red);//(0,0,255);
      rect(850,70,40,40);
      fill(green);//(0,255,0);
      rect(850,120,40,40);
      fill(blue);//(255,0,0);
      rect(850,180,40,40);
      fill(yellow);
      rect(850,240,40,40);
      fill(sCol);
      rect(850,350,40,90);
      for (int i = 0; i < cols; i++) {
          grid[i][j].draw();
    void mousePressed() {
      if (mouseX > 365) {
        a = get(mouseX,mouseY);
        if (a == red || a == green || a == blue || a == yellow) sCol = a;
    class MyRect {
      float x, y, wide, high, bi, bj;
      color b;
      MyRect(float x, float y, float wide, float high, float bi, float bj) {
        this.x = x;
        this.y = y;
        this.wide = wide;
        this.high = high;
        this.bi = bi;// column number
        this.bj = bj;// row number
        b = color(0);
      void draw() {
        if(over()) {
          stroke(255,0,255);
          if(mousePressed) {
            if (mouseButton == LEFT) { b = sCol; }
            if (mouseButton == RIGHT) { b = color(0); }
        } else { stroke(255); }
        fill(b);
        rect(x, y, wide, high);
      boolean over() {
        if (mouseX >= x && mouseX <= x+wide &&
          mouseY >= y && mouseY <= y+high) {
          return true;
        return false;
Left click is to select colour and right to deselect.
Any help would be appreciated.
