Dear All,
My requirement is to control 4 LEDs over a bluetooth signal. Signal will be a character or a number.
I need to turn on the first led with default brightness when received the character ‘o’
turn off the first led and turn on second when received the character ‘g’
turn off the second led and turn on third when received the character ‘y’
change the brightness level of the current led when received a number ‘0 - 9’
turn off the current led when received character ‘f’
I was hoping to do this with the simple code below but it seems it needs more than that.
Really appreciate any guide on this. Thanks in advance.
/ include header for bluetooth
#include <SoftwareSerial.h>
// define RX,TX ports
SoftwareSerial mySerial(10,11);
char temp;
int output;
int brightness;
//open serial communications and wait for port open
Serial.begin(9600); //start serial output
pinMode(3,OUTPUT); //white led
pinMode(5,OUTPUT); //green led
pinMode(6,OUTPUT); //yellow led
pinMode(9,OUTPUT); //red led
Serial.println("Start"); //print start in serial
mySerial.begin(9600); //start serial recieve
output = 3;
brightness = 0;
if(mySerial.available()) {
temp=mySerial.read();
Serial.println(temp);
if(temp=='o'){
output = 3;
brightness = 50;
analogWrite(output,brightness);
if(temp=='w')
output = 3;
if(temp=='g')
analogWrite(output,LOW);
output = 5;
analogWrite(output,brightness);}
if(temp=='f')
brightness = 0;
if(temp=='y')
output = 9;
if(temp=='r')
output = 9;
if(temp=='0')
brightness = 25;
if(temp=='1')
if(temp=='3')
brightness = 102;
if(temp=='6')
brightness = 178;
if(temp=='9')
brightness = 255;
if(Serial.available())
mySerial.write(Serial.read());
