Hey guys, hope you're all OK.
I was tasked with a proof of concept of a DIY temp. control unit and I cannot figure this out. I was tasked at keeping a volume of water at 37 degrees C in a flow circuit. The water is being pumped from a sump up into a header tank which contains a weir/overflow to send the water back down into the sump via gravity. Total height of no more than 1m.
I have a kettle element which was connected to a mains switch via a 3 pinned computer power lead, I've wired to an extension chord which is wired to the relay, something like this (LINK REMOVED - AC WALL MAINS -> PLUG -> EXTENSION SOCKET -> RELAY -> ARDUINO). I apologise for not having any photos, I took everything apart in my frustrations at an earlier time.
Please refer to my crude depiction below re electric circuit and what im trying to create:
So what I am attempting to achieve is to have the arduino read temperature of the water and turn on the heating if below set point and turn on cooling circulation to fan/peltier if too hot
My issue is I do not know how to power the peltier and the fan. Do I use a 8.3A power source at 12V or 24V in form of an adapter like a laptop charger or opt for one of those 'LED drivers'
I understand I will need to probably switch to a 8 channel relay but if all 5 components are connected to mains then I may as well hook up a 5 gang extension to a wire and somehow wire that to the relay. Something tells me its not going to be that simple however.
I am really stuck on how to power the Peltier and the fan, I think switching the relay is the quickest and easiest way of doing this in my limited time. I wanted to add some push buttons but If i go for 5 channels required i think i may quickly run out of enough input pins.
I do also want to wire some sort of push button thing to the arduino so it can override the setting of low or high to relay
I hope this makes sense and I am open to any and all ideas. I am a bit desperate at the moment and if there are differnet ways to do this I am more than happy to consider but please do realise i need the quickest way possible. I have a day or two in which to order some extra parts if necessary but nothing after that. I appreciate any suggestions you may have and even reasons as to why not to do it this way would be very much appreciated.
I hope my discombobulated thoughts made enough sense for you to figure out what I am attempting here, if not, please ask and I will do my best to explain.
I appreciate you taking the time out to read this and providing me with some much needed guidance.
Stay safe all and thank you again,
Harry
