control 8 printers with one card?
I am extremely new to Arduino and to electronics.
I work at a theatre company. I need to control 8 printers. I have broken down used printers so that all I need to do is supply about 7.5V to a 12V DC motor that's in the printer. Running at 12V is too fast. The goal is to make paper beautifully rain from the sky for about 10 min.
How do I do that? Can one Arduino control that many? How do I supply more than 5V? Is it possible for the sequence in the programing to have 2 motors run at the same time? Can the card supply power to more than one motor at a time?
Any advice will be much appreciated. Thank you!
What an interesting application. It would be great to see some videos when it's done.
A key concern is how much current the motors are drawing. There are several motor driver shields and modules that you can buy for Arduino and they are roughly segmented by the maximum current they can provide (here is ours for example).
If the motors only will ever turn in one direction you could conceivably drive 8 motors from one Arduino using a multi-channel transistor driver like the ULN2803. Driving multiple motors at the same time is certainly no problem from a programming point of view.
To supply more than 5v you will need an external power supply. Do not count on "the card" (I'm assuming you mean the Arduino) to supply power to your motors. That's what a motor driver is for, and you will need external power for that.
The Ruggeduino: compatible with Arduino UNO, 24V operation, all I/O's fused and protected
Why not just have an external supply on a power strip, and just turn the power on, and then back off?
http://www.mpja.com/prodinfo.asp?number=16012+PS
Or have the 7.5V be turned on/off with a arduino controlled relay circuit.
I have been assigned to program this project and i have hit a wall. I have limited experience in a class setting playing around with arduino so i am using that experience o lead me in programming and set up.
So first of all I am using this circuit to control the motors. [Arduino for Beginners: Controlling a 12V DC motor/fan with an Arduino]
Its a series of optisolators and relays to get the 12v power. (external Power supply)
I have been using some blink tutorails to get the language down. I am using LED@HIGH for a period of time to represent the printers printing. I can get them to cycle but stopping is a problem. I want to stop them at the exact moment of a buttom press. Currentlly the loop has to cycle through all 8 at least once after the button is pressed in order to stop. SHould I move this over to the programming area? Anything to assit will be amazing.
int switchPin2 = 2;
int switchPin = 1;
int led1Pin = 13;
int led2Pin = 12;
int led3Pin = 11;
int led4Pin = 10;
int led5Pin = 9;
int led6Pin = 8;
int led7Pin = 7;
int led8Pin = 6;
int val;
int val2;
int buttonState;
int lightMode = 0;
pinMode(switchPin, INPUT);
pinMode(led1Pin, OUTPUT);
pinMode(led2Pin, OUTPUT);
pinMode(led3Pin, OUTPUT);
pinMode(led4Pin, OUTPUT);
pinMode(led5Pin, OUTPUT);
pinMode(led6Pin, OUTPUT);
pinMode(led7Pin, OUTPUT);
pinMode(led8Pin, OUTPUT);
Serial.begin(9600); // Set up serial communication at 9600b
buttonState = digitalRead(switchPin); // read the initial state
void loop(){
val = digitalRead(switchPin); // read input value and store it in val
delay(100); // 10 milliseconds is a good amount of time
val2 = digitalRead(switchPin); // read the input again to check for bounces
if (val == val2) { // make sure we got 2 consistant readings!
if (val != buttonState) { // the button state has changed!
if (val == LOW) { // check if the button is pressed
if (lightMode == 0) { // if its off
lightMode = 1; // turn lights on!
if (lightMode == 1) { // if its all-on
lightMode = 2; // make it blink!
if (lightMode == 2) { // if its blinking
lightMode = 3; // make it wave!
if (lightMode == 3){ // if its waving,
lightMode == 0; // turn light off!
buttonState = val; // save the new state in our variable
// Now do whatever the lightMode indicates
if (lightMode == 0) { // all-off
digitalWrite(led1Pin, LOW);
digitalWrite(led2Pin, LOW);
digitalWrite(led3Pin, LOW);
digitalWrite(led4Pin, LOW);
digitalWrite(led5Pin, LOW);
digitalWrite(led6Pin, LOW);
digitalWrite(led7Pin, LOW);
digitalWrite(led8Pin, LOW);
if (lightMode == 1) { // all-on test
digitalWrite(led1Pin, HIGH);
digitalWrite(led2Pin, HIGH);
digitalWrite(led3Pin, HIGH);
digitalWrite(led4Pin, HIGH);
digitalWrite(led5Pin, HIGH);
digitalWrite(led6Pin, HIGH);
digitalWrite(led7Pin, HIGH);
digitalWrite(led8Pin, HIGH);
if (lightMode == 2) { // test done
delay(100);
if (lightMode == 3) { // "wave"
I'd have to say a little time spent learning about arrays would probably help ou a great deal - the way your code is at the moment, it's hard to see the forest for the trees.
Can you use the no delay blink code to control an array??
I think I just answered that question in another thread.
This shield (from Sparkfun) will drive two high voltage motors (up to 41v at 30A).
I guess you need 4 arduinos and 4 shields.
