Control 8X8 LED display with 4094
I am new to this. I am looking for a code which uses two 4094 shift registers to control 8X8 LED display. Could someone assist me please? Thanks, Ranak
you should be able to use examples using a 74xx595, as they appear to be quite similar in control
mainly the pinout and specs are different
Thanks. I'll try with that.
Thanks to tutorial with 74HC595 I was able to figured it out actually. Thanks for the advice. I’m getting there… Hopefully should be able to publish the work online.
Cheers.
sounds great, good luck!
