Robin2 has an excellent post on basic controls of stepper motors that require only pul and dir pulses. I need to run a Nema 17 42CMOB 1.8 degrees/2.5 A with a DMC422S (I have the pdf on this but it will not upload). Beautiful equipment and I'm afraid of hurting it. It seems I will need about 24 volts, I'm hoping to make do with 18 because that's the limit of my power source.
Robin2 describes how to address the pul and dir outputs. I need also to address the en, enable, output. It seems with a steady voltage. Can someone explain how to do that?
I would also like to know which pins to use on a Mega board to address pul, dir and en.
I am going to try to do this with no acceleration or deceleration, unless I hear it just won't work. The stepper has 0.8 Nm holding torque, and my application is something like 0.1, and I need only low speed, less than 2rps, and for my application the acceleration and deceleration would introduce a lot more work.
If anyone can help, thanks!
