Hi everyone,
I recently bought an Arduino Uno, and I'm a complete newbie. I need to control the speed of a single-phase induction motor (input: 80W, output: 40W, no more than 1kW, 220V, 50Hz).
I'm trying to create a project where the Arduino adjusts the frequency in a uscc sk200E speed controller to make the motor run faster or slower based on how close or far someone is to the echolocation system.
Is this possible?
Could someone help me with the connections, the code, and anything else I might need for this project?
thanks alot ..
Do you also need help breathing? The forum helpers are not a free project team. You need to do 99% of the work and then we can help you with the last 1%. Show us a wiring diagram, a photo of a hand drawn circuit is fine. Then post your code between code tags. If you have error logs also post that between code tags.
I recommend seeking help from someone local who has experience with mains power and electronics. They should also be familiar with the applicable electrical codes. Mistakes in this area can cause serious injury or even be fatal.
