Control a mosfet with two seperate switches
Greetings.
needless to say i am a rookie in electronics but i try (lol). I've made a sketch for controling a standard mosfet with a switch to drive a higher power load..However the ideal plan is to switch that load with either one switch, or the other or both at the same time and i am not sure if this would work or not...Better be safe than sory..I will post the sketch below and i would appreciate any feedback if my sketch would actually do what i want?
Yes, switches in parallel will act as you want.
Wonderfull, thank you
Just a little bigger for all to see;
Oh yes, sorry
Not that it really makes any difference but FYI, ALL GND symbols SHOULD be facing DOWN NOT up.
Power is ABOVE, GND is BELOW, figuratively speaking, meaning power pins are shown at the top of devices
and GND pins are shown at the bottom . Your resistor with the GND facing up is RED FLAG. It says "NEEDLESS
TO SAY, I'M A ROOKIE !" (no pun intended)
will make sure to always put the ground at bottom from now on
