Control a Relay using network time.
Hi all,
I hope this is the correct forum section for my newbie question.
I got the following project:
I need a relay switch on and off a certain times during the day.
To make sure the time is correct I want to use an NTP server where the Adruino can update the time say once a day just to keep in sync.
So:
-Network Time Sync
-Timer set to several times during a day repeating every weekday.
-Relay that is switching a device on and off
I got an Adruino Uno Starter Kit wit an Uno Rev.3
A realy is also in the kit.
Any ideas would be great.
What are you using to connect to the network? Ethernet shield or what?
rr01:
And where is this NTP server, on the 'Arduinos' local network or elsewhere ?
That project could be difficult for a beginner.
I would suggest a board with ESP8266 WiFi module, like a NodeMcu.
Example code for what you want to do here.
Leo..
