My goal is to control a servo depending on the distance.
Example: At a distance of 40 mm, the servo moves to 0°; at 4000 mm, the servo moves to 180°.
I have now uploaded the complete sketch for distance detection with Arduino Nicla Vision to Nicla.
You can find an example from this tutorial here:
[https://docs.arduino.cc/tutorials/nicla-vision/proximity]
Result: OK - the LED now flashes depending on the distance.
In the Arduino IDE:
I select -> Board -> Arduino Mbed OS Nicla boards -> Nicla Vision
Then I find the servo example under File -> Examples -> Servo -> Sweep
My questions:
How do I integrate this servo sketch into the Nicla Vision sketch mentioned above?
Does anyone have experience with this and can kindly help me?
...and here is the sketch for distance detection with Arduino Nicla Vision:
#include "VL53L1X.h"
VL53L1X proximity;
bool blinkState = false;
int reading = 0;
int timeStart = 0;
int blinkTime = 2000;
Wire1.begin();
Wire1.setClock(400000); // use 400 kHz I2C
proximity.setBus(&Wire1);
pinMode(LEDB, OUTPUT);
digitalWrite(LEDB, blinkState);
if (!proximity.init()) {
Serial.println("Failed to detect and initialize sensor!");
while (1);
proximity.setDistanceMode(VL53L1X::Long);
proximity.setMeasurementTimingBudget(10000);
proximity.startContinuous(10);
reading = proximity.read();
Serial.println(reading);
if (millis() - timeStart >= reading) {
timeStart = millis();
blinkState = !blinkState;
...and here the sketch for the servo:
/* Sweep
by BARRAGAN <http://barraganstudio.com>
This example code is in the public domain.
modified 8 Nov 2013
by Scott Fitzgerald
https://www.arduino.cc/en/Tutorial/LibraryExamples/Sweep
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// twelve servo objects can be created on most boards
int pos = 0; // variable to store the servo position
myservo.attach(9); // attaches the servo on pin 9 to the servo object
for (pos = 0; pos <= 180; pos += 1) { // goes from 0 degrees to 180 degrees
// in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15 ms for the servo to reach the position
for (pos = 180; pos >= 0; pos -= 1) { // goes from 180 degrees to 0 degrees
In the meantime, I have tried the attached script with the help of GTP.
The servo only jerks and does not do what it should:
Namely, depending on the distance, it swivels back and forth between 0 and 180 degrees.
Can anyone help me?
#include <Servo.h>
VL53L1X proximity;
Servo myservo;
int reading = 0;
int timeStart = 0;
Wire1.begin();
while (1);
// Servo-Steuerung basierend auf der Entfernung
int servoPosition = map(reading, 40, 4000, 0, 180);
// Erhöhen Sie die Schritte beim Durchlaufen der Servo-Positionen
for (int pos = myservo.read(); pos <= servoPosition; pos += 2) {
myservo.write(pos);
delay(50); // Verzögerung erhöhen
for (int pos = myservo.read(); pos >= servoPosition; pos -= 2) {
myservo.write(pos);
