I want to control the rotation of the round plate with the sensorss of the smartphone using 1Sheeld.
The smartphone is in position a) and can rotate around the X axis.
Arduino will be use this information to rotate a round plate (gray color) with a servo (red circle).
What I'm going to use for this purpose, Gyroscope or Accelerometer sensor?
And which servo motor would be best suited given the high accuracy?
I get 9 values from smartphone over OSC (3axis accel, 3axis gyro, 3axis magnetometer).
What I really need here is sensor fusion algorithm in processing using these 9 sensors values...
potter3366:
You need to describe what you're trying to do in more detail. What has "high accuracy"?
How much does the round plate rotate? What sort of precision do you want.
You'll likely have better control using the accelerometer than using the gyros. The amount the phone is tilted one way or the other would be a relatively easy thing to figure out.
