control analog signal using xbee and arduino uno
i need to read any analog sensor like variable resistance and show it in another board on lcd
i try to control digital signal and i success in this code
Receiver
int LEDredPin =12;
int LEDgreenPin = 13;
 pinMode(LEDredPin, OUTPUT);
 pinMode(LEDgreenPin, OUTPUT);
  if (Serial.available()) {	//If there is data in the Serial Line
    int dataByte = Serial.read();
          if(dataByte == 'H'){
              digitalWrite(LEDredPin, HIGH);
              digitalWrite(LEDgreenPin, LOW);
          if(dataByte == 'L') {
            digitalWrite(LEDgreenPin, HIGH);
            digitalWrite(LEDredPin, LOW);
Transmitter
const int sw1=2;
const int sw2=3;
  pinMode(2,INPUT);
  pinMode(3,INPUT);
  if(digitalRead(sw1)==1)
  Serial.print('H');
  if(digitalRead(sw2)==1)
Serial.print('L');
but when i try to make analog signal i failed like this code
transmitter
  Serial.println(analogRead(A0));
Receiver
#include <LiquidCrystal.h>
LiquidCrystal lcd(7,8,9,10,11,12);
  lcd.begin(16, 2);
       lcd.setCursor(0, 1);
       lcd.print(dataByte);
A digital pin only needs a single character (‘H’ or ‘L’) to print its state, but an analogue read will return a value 0…1023, which your “Serial.println” will convert to an ASCII string “0\n”…“1023\n”, but you’re only reading and interpreting a single character.
